EGT or AEM UEGO
Old Feb 4, 2004 | 08:39 PM
Team 4R's Avatar
Default EGT or AEM UEGO
i had been planning on getting an egt gauge to monitor my a/f ratio while driving and using a wideband o2 sensor for tuning with the aem ems and a laptop........ but now aem has come out with this gauge controller (pic) and i'm wondering if i should just pass up on the egt gauge and go straight for this unit..... this way i will have a wideband o2 sensor as well as a way to monitor my a/f ratio while driving... and on top of that it is an aem piece so it should be exactly compatible with the ems...........
so, i guess what i'm asking is: would an egt gauge have any advantage that this gauge cannot provide? thanks in advance.
Old Feb 5, 2004 | 10:44 AM
Team 4R's Avatar
Default Re: EGT or AEM UEGO (Team 4R)
bump for a little guidance
Old Feb 5, 2004 | 10:48 AM
notsure's Avatar
i would like to know too, the only thing that i can input is that on piston engine airplanes an egt is almost standard. thats how we control the a/f mixture to maximize performance or economy. where would you install an egt, and can it be done for each cyl?
Old Feb 5, 2004 | 11:15 AM
rtype11's Avatar
Default Re: EGT or AEM UEGO (notsure)
get both if possible its double the insurance, there is generally accepted rules for EGT placement for accuracy it is a simple formula that eludes me right now, but basically once you have a baseline your fine. I think that a large section of HT members agree that you usually end up having to stick it where it is most convenient and accesible, but usually no more than 6 inches from Ex mani flange.
I know that Motec has an EGT that monitors individual exhaust primaries - large dollars!
Old Feb 5, 2004 | 01:42 PM
Team 4R's Avatar
as far as placement i believe the accepted position is ~3inches from the head on your #3 exhaust runner......... reason being that cylinder runs the hottest.
Old Feb 5, 2004 | 03:21 PM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team 4R &raquo;</TD></TR><TR><TD CLASS="quote">as far as placement i believe the accepted position is ~3inches from the head on your #3 exhaust runner......... reason being that cylinder runs the hottest.</TD></TR></TABLE>
1" from the #3 cylinder.
Old Feb 5, 2004 | 04:06 PM
fox297's Avatar
I didn't know EGT measures A/F ratio! If it can, I don't see how it can be as accurate as a wideband O2. I think most people who has EGT use it to set their ignition timming, not A/F ratio.
Old Feb 5, 2004 | 04:09 PM
Austin's Avatar
Default Re: (fox297)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 &raquo;</TD></TR><TR><TD CLASS="quote">I didn't know EGT measures A/F ratio! If it can, I don't see how it can be as accurate as a wideband O2. I think most people who has EGT use it to set their ignition timming, not A/F ratio.</TD></TR></TABLE>
Ignition timing will affect A/F ratio. Changing the Fuel, or Timing will change the A/F ratio, as well as changing the EGT.
Austin
Old Feb 5, 2004 | 06:21 PM
Matty.'s Avatar
&lt;------ just learned something new....
Old Feb 5, 2004 | 09:28 PM
boostn420's Avatar
Default Re: EGT or AEM UEGO (gumtape_deathmatch)
When I install egt's the directions for autometer says 2" from the head or 2" in front of the turbo. so thats where I put them even if its a pain in the ***.
clinton32385
Jul 11, 2008 09:58 AM
phearable
Jan 9, 2008 03:23 AM
mtber
26
Jul 20, 2007 09:49 PM
mtber
Jul 18, 2007 04:09 PM
prostreetonline
Jun 8, 2006 08:19 PM
