where to get a 12v power source for a gauge
Old Feb 1, 2004 | 07:46 PM
XxslayerxX's Avatar
Default where to get a 12v power source for a gauge
I have acouple autometer gauges and i was wonder where people get there 12v sources from. I was using a source from my fuse box till i found out the gauge stayed on all night and killed my battery. So i want to get power from a different source. What would be the best source to power 3 gauges?
Old Feb 1, 2004 | 07:51 PM
boostn420's Avatar
Default Re: where to get a 12v power source for a gauge (XxslayerxX)
On the fuse box under the dash there are a few male spades above the fuses. Those have B+, ign +, and a power for lights. You can run all the wires to them. You just need a volt meter to figure out which connectors are what.
hondatim's Avatar
there are a few different 12v sources from under dash fuse box. A couple of these are constant 12v supplies and a couple of these are switched 12v. You'll need a 12v test light to determine which are which.
Old Feb 1, 2004 | 07:52 PM
hondatim's Avatar
Default Re: where to get a 12v power source for a gauge (boostn420)
you beat me to it boostn420
Old Feb 1, 2004 | 08:16 PM
boostn420's Avatar
Default Re: where to get a 12v power source for a gauge (hondatim)
damn the same minute too.
Old Feb 1, 2004 | 08:20 PM
hondatim's Avatar
Yeah, crazy isn't it?
Old Feb 1, 2004 | 08:21 PM
XxslayerxX's Avatar
ok thanks. If i have a voltmeter what would i set it to and how would i test it? Do i just touch it with the red plug or do i use the black plug too?
Old Feb 1, 2004 | 08:33 PM
hondatim's Avatar
Default Re: (XxslayerxX)
set meter to VDC (volts direct current) and touch red lead to terminal on fuse block while touching black lead to body ground.
crist488
Oct 10, 2009 09:45 AM
ExVtec
Honda S2000
17
Mar 18, 2009 05:19 PM
xelloss
Nov 10, 2008 01:50 AM
civiceg500
10
Dec 29, 2004 03:14 PM
It's*BOLO!!
Apr 21, 2003 09:03 PM
