B16 running rich
Old Oct 21, 2014 | 02:30 PM
joiv21's Avatar
Default B16 running rich
I just got the car in a trade so basically I'm getting to deal with someone else's problem. I put plugs and wires in it when I first got it and after about 1000 miles they started to foul out. I can smell gas real strong going down the road and it backfires like someone's shooting a .22 cal rifle. It's got 44psi fuel pressure so I know it's not pressure. When I gradually climbing the Rpms sometimes it chokes up but if I floor it it'll run fine. Just wanting some ideas I've already swapped ecus with another stock one and the problem is still there. Just wanting some ideas to try
Old Oct 21, 2014 | 03:09 PM
holmesnmanny's Avatar
Check for exhaust leak using seafoam
Check mechanical timing
Old Oct 22, 2014 | 05:07 AM
joiv21's Avatar
Default Re: B16 running rich
Would an exhaust leak really make it run that ruff. Because it does have an exhaust leak
Old Oct 23, 2014 | 03:37 AM
ballistic1350's Avatar
Lol where is the exhaust leak?
Old Oct 23, 2014 | 04:36 AM
LTCxD2B's Avatar
Check your injectors ... See if they are stock ... Or stuck open .... Are there any check engine codes ?
Old Oct 27, 2014 | 09:38 AM
joiv21's Avatar
The exhaust leak is where the cat meets the header. But it's quit runnin rich all the sudden and idle perfect
bc77711
Honda Civic (2006 - 2015)
Oct 11, 2015 03:41 PM
EgGriff
Mar 17, 2005 04:15 PM
ItalynStylion
Feb 19, 2005 10:57 AM
Pee Wee
Jul 11, 2004 07:20 PM
turbogsr13z
Apr 16, 2002 09:45 AM
