Please Help
Hi Guys Please help
I have a 2007 CRV and I was trying to install a radio using the pinout found on the net but seems that the wiring is different
This is what has happened
The car starts and goes perfectly no problems or warning lights
But when it is off the central locking, alarm, trunck doesnt open until the ignition is on what the hell
The interior lights do work and I can lock the car manually
Please help urgently
Thanks
Thanks
Need a Audio Wiring Diagram for 2007 Honda CRV Ex-L
Was driving without the radio for a few days and didnt have any issues
Anything you guys know of that I can reset or check I have removed the power and added it again, could this be a relay/fuse or anything
In all likelihood the radio is a module on the Controller Area Network grid. Removing it caused a disruption in communications between the nodes. Some aftermarket radios allow for communication,but most do not.
The link you posted is not a wiring diagram. Those are just connector pin outs. I suggest going to AllData DIY and buying a wiring diagram for your vehicle in order to properly troubleshoot this issue.
If you know of others with your similar vehicle and year, you can ask them what brand of radio they used....
Kendy
Audio / Security / Video
Jul 2, 2008 11:20 AM
