Ignition coil problems
Old Nov 7, 2014 | 08:26 AM
DaOnE51T's Avatar
Default Ignition coil problems
I just replaced my coil on my gsr swapped civic and after a few minutes of idling it shut off. I couldn't get the car restarted so I checked if the coil had spark and it did not again. What would cause the coil to break so fast?
Old Nov 7, 2014 | 11:02 AM
hybridmiklo's Avatar
Default Re: Ignition coil problems
there could be an abnormal amoint of resistance or a short. Make sure there is no oil where the coil is. Inspect the wires to make sure they are not arching. check plugs to make sure the gap is correct and there is still an electrode. Also are you running a jumper harness? and check the resistance of the coil on primary and secondary to make sure they are within spec and its not the ignition module that is failing you
Old Nov 7, 2014 | 12:11 PM
DaOnE51T's Avatar
I am running a jumper harness. How do I check the resistance of the coil on the primary and secondary?
Old Nov 8, 2014 | 08:19 AM
DaOnE51T's Avatar
Ok. I tested the resistance. The primary was within spec but the secondary was not.
JDM_EK4_Coupe
Apr 17, 2007 08:25 AM
JDM_EK4_Coupe
Apr 15, 2007 08:00 PM
loki2323
Sep 3, 2005 11:44 AM
toooslow
Aug 20, 2003 09:12 PM
loki2323
Jun 17, 2002 07:08 AM
