Location of VSS on 2014 CR-V?
Old Oct 28, 2014 | 06:23 AM
fcm's Avatar
fcm
Old Fart
Default Location of VSS on 2014 CR-V?
Installing meter for a cab, need to know where I can find VSS.
Normally get info like that off Mitchell On Demand, but very confusing on the 2014, may be data only and the meter only has pos.(+) or neg.(-) input for VSS. 94
Old Oct 30, 2014 | 10:12 PM
slowcivic2k's Avatar
Default Re: Location of VSS on 2014 CR-V?
I don't think there is a VSS, I think it uses the output speed sensor for vehicle speed. If that is the case you will need to divide the signal by the differential ratio to get true vehicle speed.
Old Nov 1, 2014 | 06:45 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Slowcivic2k is correct. This vehicle uses the output speed sensor for the VSS signal. The output speed sensor is located on top of the trans underneath the air cleaner.
(Use the 2011-2012 MY in your service info for more details)
Old Nov 4, 2014 | 05:32 PM
fcm's Avatar
fcm
Old Fart
Yea got it figured out, had to install a pulse generator, easy wire up to the OBD diag. port. 94
blaze.1
Sep 10, 2009 06:24 AM
thannon2
22
Jan 20, 2009 08:04 PM
aziaticvang
Jan 13, 2008 06:35 PM
aws140
Aug 17, 2005 07:08 PM
rschoener
May 16, 2002 07:32 AM
