b18c1 noises
Old Nov 4, 2014 | 04:27 PM
The Wangle's Avatar
Default b18c1 noises
this video is of my engine warm after getting back from class. The noise is freaking me out. I don't think it's rod knock as that should be more audible when i let off the gas rather than when i hold on it. Let me know what you think. This has me stumped.
Old Nov 6, 2014 | 10:49 PM
slowcivic2k's Avatar
Default Re: b18c1 noises
Sounds like the transmission shaft bearings are loose, and the bearings are grinding on the races. When did this noise start, and when were the conditions when you noticed it.
The hollow sound is iconic to the transmission or clutch. You might consider using a stethoscope to help pinpoint the general area of the noise.
Old Nov 7, 2014 | 06:16 PM
The Wangle's Avatar
I can't say for certain when it started, though I first noticed it after I drove the car real hard. I had just finished a tune-up and test drove it to the gas station. After reaching operating temp I got on it real hard shifting somewhere in the 7k rpm range. Shifted hard first to second, then second to third and the car cut out. Had to have it towed. Took the battery out to charge since I spent 20 minutes cranking the car while waiting for the tow. Car started right up after charging battery but have noticed the sound since.
Old Nov 7, 2014 | 08:32 PM
holmesnmanny's Avatar
Just to be absolutely certain, push the clutch completely down. If the noise goes away the issue is the tranny. If the noise stays the issue is not the tranny.
Eyger
Honda Civic (2001 - 2005)
Sep 10, 2008 12:10 PM
chueflee
Nov 13, 2007 10:36 AM
ThatsMyEG
10
Aug 7, 2006 08:43 PM
Touge Tuning
Jul 4, 2006 09:13 AM
FK00GSR
Jul 19, 2005 05:23 PM
