Start engine outside of car
Old Nov 7, 2014 | 11:13 AM
NwAmH's Avatar
Default Start engine outside of car
so I am going to buy a d16z6 complete swap over. The engine is out of the car and I wanted to know what I need to hook up to start the engine outside of the car.
So far I know I need to have a source of fuel, and and for coolibg I can either hook up a radiator or I can put a garden hose inside the thermostat Inlet. Last, I do know that I need to hook up a battery to the starter motor. Will I need to run power to the engine harness or will it receive power from power being supplied to be starter motor?
Old Nov 7, 2014 | 11:26 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Start engine outside of car
Are you trolling or what?
Old Nov 7, 2014 | 01:10 PM
NwAmH's Avatar
No I'm not, just looking at engines on craigslist
Old Nov 7, 2014 | 02:04 PM
F22Master's Avatar
The short answer is: It cant be done.
Unless you are an electrical engineer, you wont understand the long answer..
The only thing you CAN do is check the compression.
Pull the plugs, hook up the tester, Give the starter 12v, and let it crank ~5 times.
Old Nov 7, 2014 | 08:05 PM
NwAmH's Avatar
Well I was under the impression that it could be done since many junkyards perform this procedure.
Old Nov 7, 2014 | 08:30 PM
holmesnmanny's Avatar
They dont start engines, they only perform compression tests, using the same procedure he just outlined.
And its not junkyards that do this its engine importers.
sasinorm01
Jul 18, 2018 04:07 AM
alfee
Apr 19, 2006 08:15 PM
pappabear
11
May 23, 2005 11:57 AM
sk8rmike
Jul 19, 2003 12:17 PM
