Fuel pump power source?
Old Oct 26, 2014 | 01:42 AM
siblues's Avatar
Default Fuel pump power source?
I am planning on upgrading the wiring to my fuel pump in the next few days after my pump comes in the mail.I understand how to wire up the relay and everything needed to make it work but my question is where would you guys choose to get power or to connect the dedicated power wire?I see tons of threads on here either saying to run it directly from the battery or the alternator post.I was planning on using the battery post but I jjust wanted to ask if the alternator would be a better choice?My understanding is the alternator constantly chabges voltage so that doesnt seem to make sense to me so I figured I would ask in here.FCM if you have time chime in buddy I hate always having to pm you and taking up your time lol.
Old Oct 26, 2014 | 06:52 AM
MotoCARR's Avatar
Default Re: Fuel pump power source?
Run it right to the battery, no benefit going to the alternator.
Old Oct 26, 2014 | 06:53 AM
yungkhmer's Avatar
I forgot what size gauge i used but mines is connected straight from the battery with an inline fuse about 5 inches away. Relay is a must, don't forget to wire it up correctly.
Old Oct 26, 2014 | 06:56 AM
MotoCARR's Avatar
Definitely. Always fuse 6-12" from a power source!
Old Oct 26, 2014 | 01:15 PM
siblues's Avatar
Thanks guys that's what I was planning on doing.I just don't understand why soo many people say to wire it up directly to the alternator.
Old Oct 27, 2014 | 07:57 AM
rudebwoy's Avatar
I run dual pumps and use a 75 amp relay directly to the battery and the trigger is the original pump wire.
Old Oct 28, 2014 | 03:55 PM
fcm's Avatar
fcm
Old Fart
As mentioned, direct to the batt., or the alt. it makes no differance, [voltage is the same] either way a fuse or fusable link as close to connection point as possible, but within a few inchs is required. 94
Old Oct 28, 2014 | 04:55 PM
siblues's Avatar
Thanks alot guys.I already have the stuff on the way and I will put all of your advice to use.
Mike Lowwryyy
Sep 5, 2013 03:39 AM
siVix
Aug 3, 2011 06:28 PM
IntegraTypeR
Feb 6, 2007 09:23 AM
The Tea-father
Jul 12, 2005 11:23 PM
