vtec mechanism failed?
Old Oct 6, 2014 | 02:04 PM
flangemastermike's Avatar
Default vtec mechanism failed?
Had a strange problem at the weekend. just finished a turbo b18c build and was the first time at the track.
was doing a burnout and when the revs came down it cut out and wouldnt idle or run at all. When looking at it today i am getting no compression at all on cylinder 2. Some how the rocker arms have jammed down leaving the valve open slightly.
Removed the cams and used a screw drive to lift the rocker arms, they sprung up and the valves sealed again. when i took the rockers off to look at it seems the vtec piston that slides to lock the rocker arms is seized solid and would not return home.
I have never seen these go wrong like this before, I can fix it easy enough but i am confused how it happened and how to make sure it doesnt happen again, Was revving the engine to 8700 which is stock for the import b18c.
Compared to a working arm from cylinder 1
Anyone had anything similar?
Old Oct 7, 2014 | 04:45 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: vtec mechanism failed?
Yes, but I wouldn't say it is common though. Are you sure all dowels went in the same way they were taken out? Have you looked for contamination or debris? Anyway, holy **** you have some funky wear on the tips of your valve stubs! Are you sure you don't have a oiling issue?
Old Oct 8, 2014 | 06:48 PM
4drboostking's Avatar
Weird. Isnt there just a spring behind that dowel?
Old Oct 9, 2014 | 05:39 AM
Well i got to the bottom of the problem. When i was rebuilding the engine one of the cam cap bolts had snapped and i got the bolt drilled out.
I had cleaned the head out but obviously not well enough. found this tiny bit of metal behind the vtec piston which was stopping it returning fully. I looks to be part of the threaded bolt that has remained inside the long rod the rockers pivot on.
I dont think there are any other oiling problems and yeah the wear is a bit strange on the stubs. Apart from this the engine was running great.
will get it back together tonight and hopefully not done any more damage. Fingers crossed!
Nex7aR
Feb 16, 2017 08:48 AM
majdi
Engine Management and Tuning
14
Jan 3, 2011 04:56 PM
tysonboy
Jul 15, 2009 10:19 AM
brodsterH22
Apr 10, 2003 03:19 PM
