diffrence between type-R and GSR Crank shafts
Old Feb 17, 2004 | 06:32 PM
crxsirvtec's Avatar
Default diffrence between type-R and GSR Crank shafts
hey..
i would like to know the diffrence between the 2 crank shafts..
since both motors are the same displacement..
thanks
Old Feb 17, 2004 | 09:01 PM
crxsirvtec's Avatar
Default Re: diffrence between type-R and GSR Crank shafts (crxsirvtec)
Old Feb 17, 2004 | 09:03 PM
boostn420's Avatar
that being the case dont you think its safe to assume nothing.
Old Feb 19, 2004 | 03:00 PM
88strippedhatch's Avatar
they are not the same under close inspection you would think that they are. The counter weights are different somebody on here had a pic and photo shopped it to show the differences clearly
Old Feb 19, 2004 | 03:06 PM
Dan GSR's Avatar
Default Re: diffrence between type-R and GSR Crank shafts (88strippedhatch)
ITR on left GSR on right
courtesy of D and sgt
Old Feb 19, 2004 | 03:47 PM
dfoxengr's Avatar
Default Re: diffrence between type-R and GSR Crank shafts (Dan GSR)
counterweights only
Old Mar 3, 2004 | 06:56 AM
rodimus's Avatar
Default Re: diffrence between type-R and GSR Crank shafts (hybridvteceg)
so basically, the type r crank has heavier counterweights, but more stable at higher rpms, right?
realistically, you can get a gsr crank, get it balanced and maybe micropolished..and wouldn't that be better than a type r due to the weight factor?
Old Mar 3, 2004 | 08:45 AM
mmuller's Avatar
Mad Scientist
Default Re: diffrence between type-R and GSR Crank shafts (EVOL)
here some more pic:
katmans pic
Old Mar 8, 2004 | 06:52 AM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">so basically, the type r crank has heavier counterweights, but more stable at higher rpms, right?
realistically, you can get a gsr crank, get it balanced and maybe micropolished..and wouldn't that be better than a type r due to the weight factor?</TD></TR></TABLE>
Old Mar 9, 2004 | 06:34 PM
jrcrx's Avatar
this guy with the pictures of the crank knows his ****!!!!!
Old Mar 9, 2004 | 07:24 PM
jeremy.'s Avatar
Default Re: diffrence between type-R and GSR Crank shafts (jrcrx)
type r crank is a bit heavier
zacatkings
Feb 11, 2008 08:50 PM
b17integra
Jun 13, 2004 02:05 PM
b17integra
Jun 11, 2004 04:08 PM
