new tire question
Old Feb 18, 2004 | 10:21 PM
N~FaMouSKhMerBoi's Avatar
Default new tire question
ok i've been runnin on the same tires for like over a year..the front are getting bald but the back are fine, this is a 98 civic coupe...and i notice that since my front are gettin bald...at high speen (i.e. freeway driving) the front is shaky...so i was wondering if i just replace the front 2 tires..will the shaking go away..or do i need to replace all at the same time?
Old Feb 19, 2004 | 05:48 AM
doublejz's Avatar
Default Re: new tire question (N~FaMouSKhMerBoi)
the shaking may just be from your tires wearing and becoming out of balance. If the tires aren't really bad, you might be able to get them re-spin balanced and be on your way. But yes replacing the tires should get rid of the shaking if it is only the front tires that are wearing and became out of balance.
Old Feb 19, 2004 | 09:05 AM
Afazz's Avatar
Default Re: new tire question (doublejz)
The shaking could also be due to an alignment problem, which could have caused the tires to go bald in the first place. If the fronts wore out a lot faster than the rears (and you're not doing burnouts on every corner ), i'd have the alignment checked when you get new tires.
Modified by Afazz at 6:51 PM 2/20/2004
Old Feb 19, 2004 | 10:37 AM
doublejz's Avatar
Default Re: new tire question (Afazz)
true
Vtec04
Jan 22, 2017 05:55 AM
Evolution-93-Ex
Feb 17, 2008 09:34 AM
IsweatHONDA
Aug 22, 2006 09:13 AM
JCritt
Apr 7, 2006 12:31 AM
Cypher0117
11
May 5, 2005 05:44 PM
