What is this wire/hose for?
Old Feb 17, 2004 | 09:24 AM
kevinoneill's Avatar
Default What is this wire/hose for?
It is attached to the valve cover of my b16 just behind the oil cap, and splits, one to the intake and other goes down.
What is this? I had a hella time trying to take it of, looks to be on there very snug.
Old Feb 17, 2004 | 10:13 AM
np0r's Avatar
Default Re: What is this wire/hose for? (issues4)
I believe (correct me if im wrong) that hose is to let air out kinda like a vacuum so it can breathe. You can replace that hose with breather if u want.
Old Feb 17, 2004 | 12:55 PM
TIRENECK's Avatar
Default Re: What is this wire/hose for? (JDM2NR)
are you sure you have a b16? sounds like a Ls.
Old Feb 17, 2004 | 02:19 PM
Rtype16's Avatar
Default Re: What is this wire/hose for? (TIRENECK)
This is the breather hose. It actually doesn't spilt off but is two different lines. One going from the breather on the valve cover back to your intake and the other is a water line coming from the intake manifold area to the throttle body.
Old Feb 17, 2004 | 03:28 PM
eyeamvic's Avatar
Default Re: What is this wire/hose for? (Rtype16)
What he said.
And DON'T replace the hose with a breather. It's there for a reason, just messing up your PCV system and doing NO gains. Search for it if you want to know why.
Old Feb 17, 2004 | 07:57 PM
boostn420's Avatar
Default Re: What is this wire/hose for? (eyeamvic)
one is the coolant from the TB to the intake manifold. The other is the pcv system. You can get rid of it if you want just get 2 new hoses to replace it with.
Old Feb 18, 2004 | 08:12 PM
Default Re: What is this wire/hose for? (boostn420)
Ah thanks guys. I forgot to hit "email me".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK &raquo;</TD></TR><TR><TD CLASS="quote">are you sure you have a b16? sounds like a Ls.</TD></TR></TABLE>
are you sure you buddy icon is big enough?
Dekorum
Oct 15, 2013 01:45 PM
houstondigital
Aug 29, 2005 11:48 AM
mugenspoongsr
Jul 1, 2005 08:35 PM
Shizznaz
Feb 25, 2005 06:28 PM
