b18a vs b18b (Short Block Differences )
Old Feb 21, 2004 | 02:22 PM
Si Integra's Avatar
Default b18a vs b18b (Short Block Differences )
OK, here is all my questions. I am not sure if I am touching base on anything covered priorly, but I assure you I have searched fro a long time now.
I am curious what all, *every* difference is between the b18a and the b18b short blocks.
From what all I have been told depending on the obd of the short block, there is a sensor going to the water pump area, the oil pump is slightly different, and their is a nock sensor.
These are all very important questions for me because I am ust finishing my build and am thining I want to use the b18b shorty instead. I want the noc sensor the obd1 has to offer, as I am switching to the obdI harness.
Any info you can offer would greatly help.
Also, another reason for my possible change in short block is I amy be moving the engine into a 94+ chassis.
Old Feb 21, 2004 | 04:44 PM
dfoxengr's Avatar
Default Re: b18a vs b18b (Si Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Integra &raquo;</TD></TR><TR><TD CLASS="quote">
Also, another reason for my possible change in short block is I amy be moving the engine into a 94+ chassis.</TD></TR></TABLE>
they are botht he exact same mechanically. electrically, the newer ones have more sensors.
Old Feb 21, 2004 | 05:02 PM
Si Integra's Avatar
Default Re: b18a vs b18b (hybridvteceg)
What sensors might that be? And if they are identicle electicaly, how can they have more sensors?
Old Feb 21, 2004 | 05:17 PM
dfoxengr's Avatar
i said identical mechanically.PE a period ends a sentance
Old Feb 21, 2004 | 05:25 PM
Si Integra's Avatar
haha, ok smart ***. My bad; No need to get all cocky and correct my late-night ability to follow grammer
So, what sensors would be different? Can I put a b18a in a 94+ chasis, or will there be sensors etc with no place to go?
Old Feb 21, 2004 | 05:34 PM
dfoxengr's Avatar
smart-***, and late night, lol. its 930 where you are, aha
Old Feb 21, 2004 | 05:38 PM
Si Integra's Avatar
9:30 here, and that is late night for someone who has children
And yes, smart-***, you could have simply said, "aww, my bad; perhaps I did not convey my point better, I meant the mechanical factors are identical. Some of the sensors may not be useable on the b18a though."
Just a thought
Old Feb 21, 2004 | 05:40 PM
dfoxengr's Avatar
im not the one that misread a 4th grade reading level sentence. dont get mad becasue youre wrong newb.
Old Feb 21, 2004 | 05:53 PM
Si Integra's Avatar
newb. lmmfao..get a clue.
I have been surfing this as well as many other honda boards for a long time. Far from newb.
As for me getting mad, I was never bad, I just cannot understand why some silly jerk would get all cocky over my overlooking a period and not understanding the point you where aiming to make.
Nut, if it mes you feel better, then so be it. I missed a period and have now receeded into a 4th grade education bracet.
If anyone else would care to offer an intelligent responce that might assist in my quest for info, please do so.
Old Feb 21, 2004 | 05:55 PM
irev210's Avatar
um to answer the question, the difference in short blocks electrically-
B18A shortblock will have temp fan switch located on the back of the block, it has a green plug with two gold prongs sticking out of it. It has a black rubber boot with two wires that connects to it.
The OBD-1 fan switch 92+ is located on the water neck instead of on the back of the block. Take the water neck off any 92+ integra and ur good to go.
Old Feb 21, 2004 | 05:59 PM
Si Integra's Avatar
Default Re: b18a vs b18b (irev210)
Than you for a helpful reply! That helps a ton.
I can use one of my older 90-91 ls blocs instead of tracing down a b18b just for piece of mind
Are you 1% sure?
Old Feb 21, 2004 | 06:04 PM
Vera's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">i said identical mechanically.PE a period ends a sentance</TD></TR></TABLE>
a period also leaves you in the dog house
Old Feb 21, 2004 | 06:12 PM
f@sth@tch89's Avatar
Default Re: b18a vs b18b (Vera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vera &raquo;</TD></TR><TR><TD CLASS="quote">
a period also leaves you in the dog house </TD></TR></TABLE> lol
Old Feb 21, 2004 | 07:30 PM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Integra &raquo;</TD></TR><TR><TD CLASS="quote">Than you for a helpful reply! That helps a ton.
Are you 1% sure?
yes I am sure.
The bottom end is exactly the same.
The only other difference is on USDM 96+ B18B motors there is a Crank Angle Flux sensor which is located on the oil pump.
Mechanically the bottom ends are all the same though.
SO yes, your 90-91 B18A will work just fine
Old Feb 21, 2004 | 10:33 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">
yes I am sure.
SO yes, your 90-91 B18A will work just fine </TD></TR></TABLE>damn exactly what i said. now if u had heeded my advice, you would nt be in this predicament. oh well. your call. and if you want "piece" (peace), lol, of mind it doesnt matter which block you get as long as you correspond the ecu's
Old Feb 21, 2004 | 10:41 PM
Vera's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">damn exactly what i said. now if u had heeded my advice, you would nt be in this predicament. oh well. your call. and if you want "piece" (peace), lol, of mind it doesnt matter which block you get as long as you correspond the ecu's</TD></TR></TABLE>
and as long as your not in the dog house
Old Feb 22, 2004 | 02:29 PM
Si Integra's Avatar
What are you some kind of a grammar ****? lol
(F.Y.I. If you would have capitalized the begining of your sentences, perhaps it would have emphasized the begining of a new sentence. Rather than causing my oversight of a fourth grade punctuation.)
Never-the-less, I appreciate everyones assistance on this matter.
Spids5
Northern California (Sales)
Sep 9, 2008 04:56 PM
Si Integra
Sep 30, 2005 09:35 AM
