crank pulley HELP!!!!!!!!!!!!!!!!! are they interchangeable????
Old Feb 18, 2004 | 04:45 PM
Death_to_Thieves's Avatar
Default crank pulley HELP!!!!!!!!!!!!!!!!! are they interchangeable????
can I use any other crank pulley on my 92 GSR?? MIne broke trying to take it off and they want like 200 something at the dealer. Can I use like a b16 one or a ls crank pulley??? Please help
Old Feb 18, 2004 | 04:47 PM
IN VTEC's Avatar
Default Re: crank pulley HELP!!!!!!!!!!!!!!!!! are they interchangeable???? (8000KReV)
Depnds on the power steering pulley on the crank. If it's V-belt type, then you need to use a corresponding B16 crank pulley.
If it's a 4-rib pulley for the PS, then you can use any B-series pulley. You may need to get different length belts to accomodate differing pulley sizes for the AC, PS, and alternator.
Old Feb 18, 2004 | 05:26 PM
Default Re: crank pulley HELP!!!!!!!!!!!!!!!!! are they interchangeable???? (IN VTEC)
I think the power steering one is a v type belt. and the other 2 are ribbed belts. is the power steering belt the one on the end?? towards the wheel? the smallest one??
if it is then yeah i believe its a v belt. can I use a pulley off a new civic si? like a 99 or 00. how do you feel about those lightened underdrive pulleys?? you recommend them or no? my engine is a b17a just incase I forgot to mention it
Old Feb 18, 2004 | 05:30 PM
IN VTEC's Avatar
Yeah, the one on the end is the PS pulley.
I'm pretty sure you can't use the newer '99-'00 Civic Si B16A2's crank pulley.
Don't use aftermarket aluminum pulleys. Possible big headache.
Old Feb 19, 2004 | 03:32 AM
which ones can I use?? Am I stuck going to the dealer??
Old Feb 19, 2004 | 05:33 AM
Padawan's Avatar
Darth ModerVader
Search the forums for information on "lightweight" or "solid" crank pulleys, and if you decide that you want one after reading the threads, Unorthodox Racing has 2nd gen. Integra pulleys in their Specials/For Sale section for a very good price.
-Chris, who sits back and waits for Ross to show up.
Old Feb 19, 2004 | 05:46 AM
IN VTEC's Avatar
You might wanna check to see if you can convert the PS pump to 4-rib, either by changing out the pulley or changing out the entire pump.
Old Feb 19, 2004 | 07:26 AM
vtecb20coupe's Avatar
B A N N E D
and if you don't have a ps pump?
Old Feb 19, 2004 | 08:47 AM
IN VTEC's Avatar
Default Re: crank pulley HELP!!!!!!!!!!!!!!!!! are they interchangeable???? (vtecb20coupe)
Then it doesn't matter which crank pulley you use as along as you get the belt lengths to match.
Old Feb 19, 2004 | 01:45 PM
turbohondask's Avatar
i have one for sale please pm 25 dollars 30 shipped and it is has no chips in it, came of a 92 ls
miguel329
May 2, 2010 10:09 PM
bow tie
Oct 17, 2008 01:18 PM
B18cFreak
Mar 13, 2007 01:54 PM
Death_to_Thieves
Jan 7, 2004 04:55 PM
fe519
Feb 16, 2003 03:41 PM
