gauge pods on the pillar
Old Feb 21, 2004 | 02:39 PM
KiNG $h!t's Avatar
Default gauge pods on the pillar
did you guys drill a hole into your pillar for the guage wires or run them somewhere else? I didn't really see how i could run them through the pillar and where they come out at the bottom. Also, did you drill the pod into the pillar or use double sided tape? Thanks for any help!
Old Feb 21, 2004 | 04:42 PM
dfoxengr's Avatar
Default Re: gauge pods on the pillar (this guy 2fast)
i dont have them, but you should drill into ur pillar to run wires, and 2side tape will work to hold it on.
Old Feb 22, 2004 | 04:04 PM
kash's Avatar
you have to drill in your pillar to mount your pod with the rivets the gave you. And also you have to drill your pillar to run the wire through, What I did is I line the pod where I wanted to go and then I marked inside the gauge holes where I want the wire to go,then I drill the holes using a unibit and that's it for mounting your pod
Old Feb 23, 2004 | 09:53 AM
regime's Avatar
Default Re: gauge pods on the pillar (kash)
they make the 3 pod ones that take the place of the whole peice of trim.. those are pretty cool (at least i know they do for the crx)
but drilling thru the trim is your stock trim is the "right" way of doing it. so pretty much ^ what they said haha
crazyhouse2011
Feb 5, 2013 09:26 AM
KiNG $h!t
Mar 8, 2004 06:31 AM
HONDA-2NR
Feb 24, 2004 04:31 PM
Caoboy
Jan 22, 2004 06:48 PM
