Input Shaft Bearing
Old Feb 17, 2004 | 06:33 PM
B18B EK's Avatar
Default Input Shaft Bearing
My tranny has recently started to make a noise. When in neutral and the clutch not pressed in it makes this terrible helicopter like noise, when pressed in-no more noise. I have searched and alot of the posts say it is the input shaft bearing. I do believe this is what it is, but I want to be sure that that is the only thing. Could it be anything else? I am going to bring it to a tranny shop to get it fixed. Just want to get more info.
Modified by B18B EK at 3:59 AM 2/18/2004
Old Feb 17, 2004 | 07:42 PM
B18B EK's Avatar
Default Re: Input Shaft Bearing (B18B EK)
Bump
Old Feb 18, 2004 | 05:51 AM
JimBlake's Avatar
I had a clutch throw-out bearing that made a loose rattling noise when it was unloaded. The noise went away when you disengaged the clutch. That's a possibility; here's something to check...
Engine running, in neutral, clutch engaged (pedal up). It'll be making noise. Now suddenly disengage the clutch (press down the pedal). A noisy throw-out bearing will get quiet instantly. The tranny input shaft will take maybe 2 or 3 seconds to coast to a stop. How quickly does YOUR noise stop??
Old Feb 18, 2004 | 08:21 AM
B18B EK's Avatar
Default Re: Input Shaft Bearing (JimBlake)
That's what I thought it might be also, the throw out bearing. When I press in the clutch pedal the noise goes away immediately. So it might just be the throw out bearing? I hope so. Wouldn't driving conditions change if it was the input shaft bearing?
Old Feb 18, 2004 | 08:24 AM
mmuller's Avatar
Mad Scientist
On mine it made the same exact helicopter noise when clutch not pressed.
Replaced throw-out bearing and the noise stopped.
Old Feb 18, 2004 | 08:33 AM
B18B EK's Avatar
Default Re: Input Shaft Bearing (mmuller)
Sweet, easy fix compared to popping the tranny open. Now I won't be scared to drive my car.
Old Feb 18, 2004 | 09:12 AM
onefstek's Avatar
my car its been doing that for the last year. im going to replace the trow out bearing when im doing my built up, so no worrys about driving it like that. 98ctr
Old Feb 18, 2004 | 10:52 AM
MightyMouseTech's Avatar
Default Re: (98ctr)
Both the throw-out bearing and the input shaft bearings can make similar noises, youi can tell the diff if you know what you are doing, but this can't be done over a board like this.
Although, I usually find it is the input shaft bearings if the car has been driven agressively at all, and the driver can't properly rev match (which is 99% of the drivers out there).
Old Feb 18, 2004 | 12:49 PM
onefstek's Avatar
Default Re: (MightyMouseTech)
Thats verry true, but if you have a bit of experience you can tell in real life. Or worth a try. 98ctr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">Both the throw-out bearing and the input shaft bearings can make similar noises, youi can tell the diff if you know what you are doing, but this can't be done over a board like this.
Although, I usually find it is the input shaft bearings if the car has been driven agressively at all, and the driver can't properly rev match (which is 99% of the drivers out there).</TD></TR></TABLE>
Old Feb 19, 2004 | 09:06 AM
B18B EK's Avatar
Default Re: (98ctr)
Are civic si throw out bearings the same as integra ls throw out bearings. They're both b sries trannies so I could only assume so. There aren't any acura dealerships around here.
Old Feb 20, 2004 | 10:50 AM
onefstek's Avatar
Default Re: (B18B EK)
yes they are. 98ctr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B EK &raquo;</TD></TR><TR><TD CLASS="quote">Are civic si throw out bearings the same as integra ls throw out bearings. They're both b sries trannies so I could only assume so. There aren't any acura dealerships around here.</TD></TR></TABLE>
Old Feb 20, 2004 | 07:08 PM
Mohudsolo's Avatar
Default Re: (98ctr)
If just pressing the clutch down a little bit makes the sound go away, I would bet on the throwout bearing. The input bearing will usually sound different depending on how much load the trans is under, louder under heavier load and quieter under light load.
Old Feb 20, 2004 | 07:19 PM
fourthgenhatchB17's Avatar
Default Re: (Mohudsolo)
Well if you are going to drop the tranny to check/replace the throw out bearing, check for input shaft play by wiggling it up and down or side to side. There should be no play. If there is, then the input shaft bearing inside the trans is going out.
integra_101
Oct 16, 2013 01:29 PM
MikesEJ1
May 27, 2013 04:05 PM
092eg6
Jul 9, 2010 12:32 PM
Jdm_Eg686
15
Oct 9, 2007 12:19 PM
