How F'd is this head?
Old Feb 24, 2009 | 12:08 PM
TwoKSiR's Avatar
Default How F'd is this head?
This is a buddy's head. He had another guy build the motor and I stareted helping after the motor was in.
Ok so the car kept jumping timing so I tore into the head and found this. The 12mm's were torqued to around 20 ft. lbs. I have a snap on digital torque wrench so I used those to take the cams off and it was reading 20 when they broke loose.
Here's the damage. Can it be fixed?
And to make things worse I think there miss matched cam caps. He bought the head used and the guy who built it didn't check. There seems to be a little bit of a ridge where the cams meet the head.
Old Feb 24, 2009 | 12:30 PM
mmuller's Avatar
Mad Scientist
Default Re: How F'd is this head?
sure it can be fixed.. is it worth it? maybe if the head is ported by chuck norris.
Old Feb 24, 2009 | 03:44 PM
Gunns's Avatar
Thats classic.
Sadly I have nothing to condribute.
Old Feb 24, 2009 | 05:18 PM
srmofo's Avatar
eeekkk! that sucks....unfortunately unless you know someone in the machinig business, it will probaly be cheaper to buy another head
Old Feb 24, 2009 | 07:56 PM
418whpturboD's Avatar
bummer.. 20 ft lbs lucky they didnt break.. mine were tourqed to 12 ft lbs and had one break off..
Old Feb 24, 2009 | 08:01 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Dover heads of Greenville SC does line bores for 125 dollars- If a bearing is needed they charge for the bearing itself. So it comes down to the work already done to the head.
In my opinion, I wouldnt run something that an idiot messed around with ya know? Its so easy just to go and find a OEM head never been touched and go from there.
Old Feb 24, 2009 | 08:37 PM
TwoKSiR's Avatar
Its a ported head with 5 angle and 1mm oversized valves.
Old Feb 24, 2009 | 09:01 PM
iwanttokillgod's Avatar
and now its a paper weight
Old Feb 24, 2009 | 09:14 PM
N1 Andy's Avatar
R.I.P. Andy
then get it align honed and call it a day.
Old Feb 24, 2009 | 09:42 PM
Scott_Tucker's Avatar
FYI, break away torque is usually higher than what they were originally torqued to so that does not indicate that when they were originally tightened they were torqued to 20 ft/lbs.
ep3man
Jul 2, 2010 01:01 PM
DTRcivic
10
Jun 26, 2004 09:33 AM
Eg6_JDM
Oct 21, 2002 05:47 PM
JDMvtecDRAGSTA
Apr 18, 2002 12:07 PM
