How do I set Cam timing afterhand?
Old Feb 21, 2009 | 12:21 PM
computer07's Avatar
Default How do I set Cam timing afterhand?
SO i pulled my head off of my integra to replace my pistons and rods via the engine still in the car... i did not set my cams to TDC before i pulled them. I rotated the crankshaft to get all of the rod caps even and the belt did not spin with the crankshaft. what are the steps I have to take to correct my cam timing?
Old Feb 21, 2009 | 02:24 PM
fcm's Avatar
fcm
Old Fart
Default Re: How do I set Cam timing afterhand?
Start by aligning the white notch on crank shaft pulley with the pointer on lower cover, making sure distributor is pointing a #1 cylinder, if not rotate crank 360 degrees and align notch, then rotate cam gears till "up" is in the 12 o'clock position and align timing marks on gears to pointer on back cover, install timing belt, your done.94
Old Feb 21, 2009 | 02:26 PM
Paul-R's Avatar
wait "engine still in the car" how did you connect the connecting rods to the crank shaft with out pulling the engine out ?
Old Feb 21, 2009 | 03:01 PM
Turbowa's Avatar
Drop the oil pan and remove the girdle. You'll have ample room to get them out through the top.
Old Feb 21, 2009 | 09:54 PM
Scott_Tucker's Avatar
What does afterhand mean?
boby5713
Honda Civic (2001 - 2005)
Nov 26, 2012 03:19 PM
revhardEK
Apr 5, 2012 09:03 AM
guyver13
10
Nov 28, 2011 08:58 PM
hybrid98
Jun 26, 2007 08:57 AM
b16ahybrid
Feb 1, 2006 04:56 AM
