b series question
Old Feb 23, 2009 | 07:34 AM
efn91's Avatar
Icon2 b series question
i have an ef with a b16a swap that is about three or four years old and have had no problems. about a week ago, the car started being hard to start, it would turn over fine just wouldnt start, also, as im drivin the car feels like it shuts of then starts right back up? any ideas on what it may be?
Old Feb 23, 2009 | 08:52 AM
mouab18c1's Avatar
Default Re: b series question
check your spark plugs, wires, distributor
Old Feb 23, 2009 | 11:10 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^
Ignition, [spark] or fuel.
It's an older car so I would have a close look at the PGM-FI Main Relay, [**** to problems in older cars] this may help... http://www.tegger.com/hondafaq/mainrelay.html I have repaired or replace it on more then a few Honda/Acura, including my 94LS and my sisters 92 Civic. 94
Old Feb 23, 2009 | 01:19 PM
efn91's Avatar
how would i go about checking the distributor?
Old Feb 23, 2009 | 04:05 PM
fcm's Avatar
fcm
Old Fart
Hard to do when the problem is intermittent, but you can check for the obvious, remove cap and inspect condition of rotor and cap contact points, check for moisture, cracks or carbon arks inside the cap, make sure all connections to coil and ICU are good.
You should also make sure there is no moisture down the spark plug "tubes" or on the ends of the spark plug leads. 94
eskimo10
Jun 13, 2009 06:55 AM
drtile
Jan 2, 2008 03:17 PM
live_again_integra
Jan 4, 2007 05:42 PM
S2KILLA
Nov 29, 2006 06:00 AM
AzntaggeR
Feb 25, 2004 12:02 AM
