Rough start!!!!
Old Feb 7, 2009 | 05:21 AM
lyzer227's Avatar
Default Rough start!!!!
ok here is my problem everytime when the engine is cold lets say in the morning i go to start my car (EG coupe w/ 94 LS motor) and it takes a while to start. engine is cracking but no start when the car does start after so many cranks the car runs rough way below idle car sounds like it wants to turn off, lets say 300 rpm. then i try to give it gas when at low idle and the car shuts right off but if i leave it to idle low for a 2-3 min the car jumps to normal idle. this olny happens when the engine is cold if say i start my car and go some where turn the car off then get back in the car the it starts up fine. if anyone has any info it would really help. thanks!
Old Feb 7, 2009 | 12:02 PM
fcm's Avatar
fcm
Old Fart
Default Re: Rough start!!!!
PGM-FI Main Relay, first thing I would check...
http://www.tegger.com/hondafaq/mainrelay.html
Cold solder connections or poor connections are effected by temperature ans temp. drops metal contracts and connections can become poor or broken completely.
The above link to the "fix" is easy to do and should be done if for no other reason then to eliminate the PGM-FI Main Relay as the problem.
You could also get a fuel pressure gauge and install it, that way you can see what the pressure is when you are having the starting/idling problem, good pressure at all times will only indicate that the fuel pump relay, [and connections to the circuit board] in the PGM-FI Main Relay are good, not if the injector relay and connections are good, [also in the PGM-FI Main Relay].94
lyzer227
Sep 11, 2009 01:03 PM
lyzer227
15
Feb 17, 2009 12:42 PM
iceman24
Sep 19, 2005 02:50 PM
delguiner
Sep 25, 2004 01:45 PM
EK45VTi
Jul 30, 2004 03:40 AM
