LS VTEC Help! desperatley needed
Old Feb 22, 2009 | 01:03 PM
lsdb1's Avatar
Default LS VTEC Help! desperatley needed
I have a friend who is trying to steup his ls vtec oil line. The fitting to the block is connected and he used a hole that was up top to feed the oil into the head. He unscrewed a screw and was used as a plug apparently and connected the oil line to it. Now his problem is that it's leaking from the block. He used teflon tape and it's tightened a lot. Now the thought is that i may be causing back pressure causing it to leak from the block. ANY HELP would be appreciated. He's trying to get this car on the road today lmk guys, and thanks a lot
Old Feb 22, 2009 | 01:38 PM
facelift1's Avatar
Banned
Default Re: LS VTEC Help! desperatley needed
are u sure he used the right plug
Old Feb 22, 2009 | 01:43 PM
Flashmn's Avatar
Cracked the threaded part on the block using an NPT plug, when he should of used a BSPT plug and now its leaking as a result.... thats my guess
Old Feb 22, 2009 | 01:45 PM
lsdb1's Avatar
so what is it he should do?
Old Feb 23, 2009 | 08:56 AM
mouab18c1's Avatar
back track....and redo it the correct way
Nisif
Sep 16, 2014 06:25 AM
libral00
Mar 30, 2008 09:57 AM
SLow-Side
Nov 21, 2004 03:14 PM
99B16Si
Nov 22, 2003 03:54 PM
tegmaniac
Apr 24, 2003 07:37 PM
