Few questions on ls/vtec dowels
Old Feb 6, 2009 | 07:10 AM
96Spec Ek's Avatar
Default Few questions on ls/vtec dowels
I am about to do a final assembly on my build and was wondering if the cylinder head is shaved and block is decked would the dowels need to be shaved down as well?
Old Feb 6, 2009 | 08:57 AM
ekb16's Avatar
Default Re: Few questions on ls/vtec dowels
i dont think so
Old Feb 6, 2009 | 08:59 AM
mouab18c1's Avatar
dowel pins are just to hold your head so it aligns with the block
Old Feb 6, 2009 | 09:58 AM
96Spec Ek's Avatar
Yes I know that, just wanted to make sure the height of the dowel does not need to be modified.
Old Feb 6, 2009 | 10:13 AM
CerealKiller's Avatar
It depends on how much the head and / or block where shaved or decked. If it's minimal then you should have no problems.
Old Feb 6, 2009 | 02:10 PM
96Spec Ek's Avatar
Thanks, yeah the block and head were just shaved slightly just for better head gasket sealing. Sounds like I should be good then.
Old Feb 6, 2009 | 03:04 PM
ALLxMOTOR EG's Avatar
Vietnamese!
yea you should be good to go GL .
Old Feb 6, 2009 | 08:12 PM
4thgenHB157's Avatar
you just got both resurfaced so your ok on that, if you shaved it enough that the dowls would bottom out, you would have more issues then that, like valves to close to pistons, and timing belt unable to tension properly, you have no worrys, if your that concerned, you could clay the pitons and measure that way, good luck with the build.
K20teggg95
Oct 22, 2011 10:41 AM
88 EF Hatch
11
Jul 16, 2009 10:14 AM
RACING INTEGRATION
May 22, 2006 03:31 PM
Brian_92GSR
Aug 27, 2002 01:25 PM
