Bore sizing question...
Old May 4, 2003 | 10:55 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Bore sizing question...
I know there are people running 85mm blocks. GE will sleeve your block to 85mm and Mr Gasket even makes an 85mm head gasket for the B16's. The question I have is I have talked to some people who say to not go larger then 84mm. I guess the question I have is, is this more because of the head or the actual block. Meaning yes you won't have a problem sleeving the block to 85mm, BUT deschrouding the head to 85mm is a no go or does it have something to do with the block itself. Also for the people here running 85mm bore blocks, have you guys ran into problems opening the head up to 85mm? Thanks.
Old May 4, 2003 | 01:52 PM
dfoxengr's Avatar
Default Re: Bore sizing question... (Mr Milano)
i am building an 86mm and am not opening the combustion chambers...
Old May 6, 2003 | 07:38 AM
Mr Hammond's Avatar
a/k/a Jomo
Anyone else?
Old May 6, 2003 | 09:00 AM
Al Bundy's Avatar
I'm gonna get 84.5 mm but not deshroud the head. Reason is because if my block somehow blows, I can just swap in my spare b18c block without worries
Old May 6, 2003 | 09:21 AM
All Motor Rex's Avatar
I believe that people say to stay 84mm, so that in case you have a problem and and the cylinder walls get scarred, you still have room to go up a bore size instead of having to re-sleeve. 85mm will be fine. Good luck.
Old May 9, 2003 | 07:16 PM
rodimus's Avatar
Default Re: Bore sizing question... (Al Bundy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Al Bundy &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna get 84.5 mm but not deshroud the head. Reason is because if my block somehow blows, I can just swap in my spare b18c block without worries</TD></TR></TABLE>
lol wish i had a "spare b18c" ...good chit
D.Sanchez
Jul 11, 2011 10:44 AM
Topdawgg
Aug 3, 2010 11:44 AM
nick91civicsi
Feb 2, 2008 08:56 AM
viet_boi_racin
Jun 10, 2007 01:17 PM
98Psi ITR
Mar 27, 2003 10:02 AM
