need hi performance alignment specs..toe mainly.
Old May 1, 2003 | 09:03 PM
hicamjunkie's Avatar
Default need hi performance alignment specs..toe mainly.
im runing -2.2 front camber and -1.2 rear camber, this if for a daily driven street/ weekend track lap days 99 teg. im basically looking for toe info, i was told to do 1/8 to 3/16 toe out in the front and 0 in the rear. can anyone tell me if this is right.
Old May 1, 2003 | 09:52 PM
smokin rubber's Avatar
those sound like good #s to me. On my autoX and track only accord, I run 1/4 total toe out front, and zero rear.
You probably only want to run 1/8 total toe out in the front for a daily driven car.
Old May 1, 2003 | 11:36 PM
b19coupe's Avatar
Default Re: need hi performance alignment specs..toe mainly. (hicamjunkie)
Here is a quote from Tony1 who knows a little:
"Positive caster is a good thing in a race car, but you can't really do it on a honda w/o some pretty major modifications to the suspension. You should run a little negative camber, maybe .5 deg. or so, so that when the front lifts the camber is straight. I would also recommend 1/8" of toe in to help keep the car straight. If it still doesn't hook or go staight then the problem lies elsewhere..."
This is in reference to drag racing.
pwebb0207
Suspension & Brakes
Apr 5, 2011 06:04 PM
dvp
Feb 22, 2006 05:45 PM
Francesco
Honda S2000
32
Jan 30, 2006 08:33 PM
Understeer
Jul 11, 2005 05:09 AM
B18C5-EH2
25
Mar 31, 2004 07:28 AM
