ignition ?'s
Old May 4, 2003 | 12:39 PM
turbo sol's Avatar
Default ignition ?'s
i am thinking about upgrading my ignition but i don twant to leave anythign out. I wanted to start out with just an external coil and then work into a BTM system when i get my turbo back on.
so… to make it an extral coil all i need is;
1.MSD blaster 2 coil?
2.MSD dist. cap with external coil lead?
is that all i need to make it an exreanl coil?
then when i upgrade to the BTM all i need to get is the BTM unit right?
thanks for the help guys.
Old May 4, 2003 | 08:51 PM
turbo sol's Avatar
Default Re: ignition ?'s (turbo sol)
no one knows?
Old May 5, 2003 | 06:38 AM
redzcstandardhatch's Avatar
something different
yeah, you need the coil itself, the blaster cap, and a little bit of wire. you take apart the distributer, take out the ignition coil, and run wires from the positive/negative on the coil to the external coil. very easy
honda_SiRII94
Apr 9, 2007 08:14 AM
Jonny Rocket
18
Jan 11, 2007 02:37 PM
Rodzknight
Jul 3, 2006 01:02 PM
marques4130
May 9, 2003 06:24 PM
