Why do I need to do a valve adjustment if...
Old May 3, 2003 | 04:55 PM
B18EG6's Avatar
Default Why do I need to do a valve adjustment if...
Well I got the timing belt on today...started the car... and heard a LOT of ticking. If everything is at TDC, and stays at TDC....does this mean I need to do a valve adjustment?
This is the first time doing a valve adjustment myself, although I have watched others do it. I adjusted the intake's to .006, and the exhaust to .007. I did them in the correct order, 1342, and did it till I felt a slight drag on the feeler gauge. I made sure the screw did not loosen while I tightened the nut.
Why does my motor tick so loudly? Is it the stupid LMA's? Argh... I just wanna drive my car for once in 4 months .
Any suggestions? I only come back maybe once or twice a month.
Old May 3, 2003 | 05:50 PM
jcivic's Avatar
Default Re: Why do I need to do a valve adjustment if... (B18EG6)
are u getting spark on all the spark plug wires,cause my wass doing a loud ticking noise cause the car was running on 3 cylinders.the distributor cap was faulty,after i change it the engine started fine and the ticking was gone.
Old May 3, 2003 | 07:04 PM
Phat Corolla's Avatar
New User
You can safely tighten your valves to .001 closer than spec for extra quietness.
Old May 3, 2003 | 07:32 PM
VTECorona's Avatar
Default Re: Why do I need to do a valve adjustment if... (Phat Corolla)
My friend recently got a valve adjustment on his GSR at the Acura dealership and it was really ticky afterwards. Thats just how they sound I guess.
Old May 3, 2003 | 07:55 PM
B18EG6's Avatar
Default Re: Why do I need to do a valve adjustment if... (97RedTegGSR)
Yes I am getting spark to all 4 cylinders
Before I did all the work, my motor was nice and quiet though... This ticking is REALLLY loud, almost sounds like the valves hitting the pistons... but its not since everythign is at TDC.
Tomorrow I will go and maybe tighten them a little more if my damn back stops hurting from being bent over for the whole day...
Modified by B18EG6 at 3:23 AM 5/4/2003
Marcg611
Aug 24, 2008 08:04 AM
jdm4drSi
May 19, 2007 03:49 PM
redpeppers
Jul 26, 2005 02:33 PM
dacaveman
Jul 20, 2004 10:02 PM
supadupamikey
Aug 15, 2001 05:10 AM
