Log In
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 [252] 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. i got broadsided last night--prelude tranny question
  2. H23 parts please help
  3. Does the jdm h22a pistons have floating pins??
  4. wheel question (searched)
  5. H-series cams vs. B-series cams, how can you tell?
  6. H23 valve clearances
  7. Can't get rc injectors in!!
  8. Need all info\help I can get on civic forums
  9. Help with C & R install
  10. rebuilt H23 won't start
  11. ps foaming
  12. Mystery connector (Prelude owners, you have an idea?)
  13. how bad is it really
  14. help! car won't start unless i push start it
  15. any ideas??? slight drivetrain vibration, and no speedo
  16. HELP! car shakes like a mad man!!!
  17. HELP! valve cover nut won't come off!
  18. Seat Belts
  19. tranny blues
  20. Vibrations on steering wheel, brake, gas pedals.
  21. I JUST CRASHED!!!!!!!
  22. good shops in so cal for h22a swap?
  23. vafc and 440 injectors
  24. Aftermarket Throttle body
  25. Wide Band o2 sensor
  26. Clutch problem, please help
  27. should I hold out?
  28. Autocross news
  29. planning to put a turbo kit
  30. Adjusting timing on Fidanza flywheel
  31. 4th gen interior picture request...(leather interior comparison!)
  32. florida shops question
  33. tapping noise problem
  34. obd2 to ob1 problem
  35. h23/h22 short block parts interchangable?
  36. aem fuel rail and other stuffs install
  37. JRSC install for 97SH
  38. Will 5 lug 5 spoke accord fit 5 lug 5th gen LUD ????????????????
  39. lowering springs
  40. 88 Prelude Si - Car won't start sometimes (main relay?)
  41. ideas for camber kits for the BB6
  42. will 5th gen lude aftermarket fit into 5th gen accord?
  43. Dyno Results - 200+
  44. PIC REQUEST: bottom shot of H22a1 head
  45. WTB: h22a block
  46. H22a questions
  47. adjusting throttle cable????
  48. Would I have any problems if......
  49. Need Progress Sway-bar info
  50. idoits at tire shop damaged my fuel tank
  51. quick Q: Do I have to remove wheels to intall rear anti roll bar?
  52. Spedometer is not running
  53. SMS header received
  54. SEIBON carbon parts?
  55. witch turbo manifold to buy ?
  56. h22 swap in a Prelude S automatic (already searched)
  57. Engine almost there!!!
  58. Really simple n00b question
  59. can u put h22a vtech head on to h23
  60. turbo probs need help
  61. Prelude for sale
  62. Exedy
  63. vtec h23 question
  64. How safe would this be ???
  65. anyone have vids of a 5th gen with an Apexi N1?
  66. h23 timing belt cover
  67. 85 Prelude engine swap
  68. need some help , preludes in trouble
  69. H22A Vtec engagement... already searched.
  70. Tokico HP or KYB GR2?
  71. I drove a euro-r equipped lude today- With weight reduction, questions on capability?
  72. Does anyone have an Apexi Dunk Catback on their 5th gen?
  73. 92-96 Prelude: Carbon Fiber Hoods
  74. OT> hopes for any Insite owners
  75. h23 cams ?
  76. low rev limiter/no vtec
  77. reving at idle
  78. 98 h22 ecu problem
  79. Can't get the damn fuel pump back in!!
  80. SHOULD I SLEEVE THIS BLOCK?
  81. JDM BLK housing 1pc headlights (stanley)...
  82. mounting WOT switch for n2o
  83. looking to buy my first lude have some Q's
  84. oil leak after reassembly
  85. Air Con
  86. New nitrous Q's (quick ones)
  87. h22 or h23
  88. GM Synchromesh... Has anyone used it?
  89. Relaiabilty issue on Turbo vs All Motor.
  90. Air Struts: how?
  91. Jun fully build turbo motor.
  92. Odometer problem...PLEASE help!!
  93. Ebay supercharger
  94. AEM V2 INTAKE FOR 5th GEN
  95. digital odometer
  96. Questions about exhaust and such.
  97. N2o or boost on sleeved block
  98. Which Clutch for 300hp Prelude?
  99. JDM headlights for gen4
  100. anyone know any shop in CA. (central valley) that can tune? hondata?
  101. must sell Gude race head package for B20a5
  102. Greddy SP II Exhaust For Sale Brand New Out Of The Box
  103. intake manifold?
  104. f22 to h22a
  105. auto vs stick
  106. Top Speed 4g vs 5g?!?!
  107. 92 prelude si backspacing??
  108. hmm what part is this? isn't something supposed to go here??
  109. h22 rods/pistons in a h23???
  110. Skunk2 cams or Type s cams for 97 lude?
  111. 95 Si Fender gaurds
  112. jun cams allmotor
  113. pcv egr location?
  114. 97-00 black widow spoiler
  115. H22a Tech questions
  116. Security question
  117. what is the OEM fuel pump flow rating in all year preludes and models ?
  118. Engine "flushing" machine....
  119. New product for those building their motor.
  120. Want a Front Crossmember mount for 93 civic w/ H22 using Hcp kit
  121. Transmission Pulling
  122. h22 crankshaft
  123. New product - For those building their engine.
  124. turbo or super ?
  125. anyone here want to trade a b16 SC for a h22 SC
  126. 1996 Prelude VTEC Model Question
  127. Are there any universal air bypass valves for an Injen RD1700 CAI
  128. Cannot decide on Tokico HP or KYB GR2!
  129. Breaker bar
  130. atts light?
  131. OBDII to OBDI...info
  132. Skunk2 Intake manifold, turbo cams
  133. SC LUDE/TURBOED LUDE
  134. Squeeze My LUDE!
  135. Got the prelude
  136. HELP jdm climate control ?????
  137. What i did with my taillights:
  138. Exterior molding problem...info plz
  139. 17in 5Zigen 5Zr Copse on 5th Gen
  140. jdm headlight install
  141. four secondary injectors
  142. h22 turbo
  143. Combo, HP?
  144. h22 trans
  145. 250+hp
  146. lights?
  147. car won't start until i rev what is the prob??
  148. Skunk 2 ,Stage II........h22a
  149. 4G axle interchangable?
  150. question about 4th gen tweeters..
  151. 1/4 mile and 0-60 96 prelude?
  152. Humor Me But how Do i Remove the front Bumper of a 95 SI
  153. Prelude Gen. 4 Foglights
  154. Failed emissions
  155. Diagnosis from my blown motor.
  156. anyone here want to trade a JRSC from a b16 for a JRSC for a 97 up lude????
  157. Euro R gears
  158. Price Question
  159. cap and rotor
  160. Do any of you have problem with freezing door?
  161. CF Intake Manifold
  162. Which Gen Motor ??
  163. help on compression test reading????
  164. Oil filter adapter - question
  165. obd1 h23a non-vtec
  166. Why does my Lude bounce on hard shifts?
  167. Shortshifter question: Forbidden v. PSPEC shifters (with PICS)
  168. anyone have crower stage 1 cams(63421)
  169. Quick question
  170. size of intercooler
  171. H22A4 rebuild
  172. Euro R tranny
  173. any way possible
  174. What The?
  175. Speedometer off? How can I tell?
  176. Modified H22 Inatke MAnifold.......Removed Diaphram assembley
  177. I got rear ended :(
  178. Take off the distributor cap?
  179. Just came back from the track today
  180. gm syncromesh in an h23 tranny
  181. Help! Which shocks should I get?
  182. Burning Plastic Smell
  183. Valve Adjustment, new........
  184. Getting Colder Air for N/A
  185. 5th gen crossmember q's (suspension guru's needed)
  186. radiator
  187. wiper relay....
  188. Help: Can't Shift into Gears
  189. Light in sunroof switch (5G)
  190. h22 question * * mounting STR fuel rail.........
  191. 4th gen bottoms out
  192. Antenna Problem.
  193. Help - Bad results after new pistons
  194. has anybody hooked up a fmu backwards on a 5th gen?
  195. anybody with the fmax kit for the 5th gen preludes...plz help!
  196. rear main seal...
  197. about the jdm h22 motor?
  198. motor blown in my Si, can i use an Accord F22???
  199. where can i find a JDM electronic climate control
  200. V-AFC or V-AFC II
  201. 2nd gen Vtec or 4th gen
  202. MSD SCI installation
  203. Exhaust Piping For H22 in 92 Si....
  204. answer to shock knocking for 4th gen yet?
  205. AEM CAI question
  206. What size tires?
  207. 90-91 B21 DOHC
  208. Looking for the short shifter <----made by member of the prelude forum
  209. MR2 Spyder vs. My Prelude
  210. car shakes during acceleration from 1st, 2nd, and 3rd gears
  211. Hondata INtake manifold gasket
  212. Gauge holder...
  213. Energy Suspention Motor Mount inserts
  214. N/A Motor Prelude VIdeos ?
  215. Still Having Problems With Oil Pressure Sending Unit
  216. grille
  217. h23a3 accord awd transmission on a 4th gen prelude
  218. what size piping?????
  219. 1988 prelude
  220. JDM fog light. what bulb do they use?
  221. 5th Gen Prelude - FAL Flexite Windows
  222. Does this test pipe look like it will bolt up direct?
  223. h22 tb???
  224. U2Q7 on board :) At last...
  225. AEM Pulleys
  226. h22a, h23a question
  227. Likes and Dislikes of Prelude
  228. Compression Check
  229. hood problems
  230. gtech tach good or not?
  231. To those who have installed DSM injectors
  232. timing belt install....problems and pictures
  233. H22a Prelude specific (golden opportunity Opinions please....)
  234. Clunking, not shock knock
  235. 5 lug converstion on a 4th gen...
  236. Spark Plug wire sequence on a Honda Prelude 94' Si DOHC
  237. Bare block...
  238. O.T. passwordJDM.com
  239. H22A Accord OBD1 VAFC-II setting HELP.
  240. DNX header
  241. help me take my wheels off
  242. Accord euro r (h22) help
  243. JRSC?s please help did search
  244. corner lights
  245. How many of you have set vtec to an earlier rpm?
  246. AEM V2 INTAKES
  247. what to ask for when getting head p&p?
  248. Buying a prelude...help
  249. Turn Signal
  250. Power loss
