View Full Version : Honda Prelude
- Loan $??
- any idea what this is
- New clutch-pedal adjustment issues and slippage...
- ECU
- Please Help!! (Another H22 oil consumption question. Sorry.)
- weird transmission noise??
- Running a base traction bar on an SH model
- tein coilovers
- head gasket...
- clutch engagement problem
- SMOKE Coming from Catch Can
- Port and polish, how long do they last?
- EGR & IACV block-off plates.
- Driver window not working on 93 Si.
- dirt track honda
- Balance Shafts removed...excess parts to remain?
- How do I put in my aftermarket water temp gauge?
- getting some new rimss
- Stuck! Help PLEASE!!!
- jdm h22
- Spoiler brake light bulbs not working
- Oil Squirters h22
- Custom Piston Machining
- Quick HELP............F seris driveshafts on an h22?
- Standard plug gap for zfr6f-11
- oil pressure issues
- gear- neutral without the clutch?!
- questions on coil over sleeves
- new Espelir cat-back..LOUD! but will it tame down after some time?
- Steering tight on right turns
- (4th gen) JDM Healights....Headaches.
- Timing Belts, tensioners, voltage issue and more...
- will this accord tranny fit on my prelude motor
- liq gasket..
- H22A VTEC solenoid assembly.
- BBmoto Exclusive Exhaust Mykizism Fab
- pulleys
- ECU fuse
- Trying to find out what turbo i have, and looking for tom from Ludespeed
- Tranny oil leaking...car stumbles and dies when put in gear.
- Do you use oem or aftermarket oil? and why?
- I need a pic of where the idle screw is.
- 98 prelude
- running rich?
- Carbon Fiber sunroof Group BUY !
- Will any P14 work on the SI 4ws?
- h23 to h22 question
- FRM Sleeves = Expensive
- h22 no fuel?
- OEM shock spring seat dilemma
- clutch line rubbing
- 00 front lips
- anyone considering tokico read this
- wich aem pencil coils for the h22?
- Using 75w-90 in the tranny?
- f22b dohc???? what intake manifold gasket do i use on it?
- 02 sensor issue/tuning suggestion?
- slight oil leak.
- 98 Prelude Emblem Deck Lid
- Question about non GC Konis, getting race prepped and working w/ GC's
- Oil Leak on Exhaust?
- so many clutches....wuts goin on?
- Need to replace the ecu on a 94 si
- what's up on 95 Prelude pops out of 3rd gear??
- Identifying a leak (back passenger brakes)
- How to apply 5v to TPS off car?
- Prelude brake light issue question
- Crower Stage 2 cams VS. Skunk2 Stage 2
- WOW!!! cant find these side skirts anywhere!!!
- Trying to Get Rid Of Antenna on My 1992 Prelude?!?!?!?
- B18 Swap onto a 92 Lude
- What's better Hondata S300 with P28 or P72 on H22A motor
- fuel pressure regulator
- Auto-Manual Conversion
- hopupracing.com question
- Various problems with h22a swap(93 Si)
- No GAS for half a second...and then I look like a fool
- residue in radiator
- tranny or clutch issue...please help
- Good to Know but not recommended
- Adjusting speedometer and tach on EL gauges
- VSS and tranny problem
- Replaced master cyl - no brakes when engine is started
- issue with 1999 base model
- F22 guys
- what's it called?
- 5th gen black light housings?
- Teaser
- pins for vtec
- Car not cranking
- horsepower??
- ????????what do i do with my harness for jdm h22???????
- Prelude type s Info needed!
- Window Problem: 95 prelude vtec: window went down, and wont come back up. motor still works!
- so..i had my cv axels replaced..
- manual tensioner conversion on h22a4
- I have a check engine of speed sensor, I lost my vtec and my mph cluster doest work( my RPM is worki
- Stretched Headbolts causing oil/coolant mix?
- bushings?
- 2002 Civic Hatchback ep3 rims on a prelude
- Failing Georgia emissions, any ideas?
- car wont start after compression test. im left clueless. ideas anyone?
- Getting a prelude today.
- 5th gen shifter cables
- vss issues
- should i do my own suspension?
- no parking lights?
- will this offset fit the 4th gen?
- spark plug question?
- what wrong with my clutch?
- BDL throttle body, which one would work best for this setup?
- weird problem with my prelude
- MECHANIC PLEASE, ATLANTA< PRELUDE HELP NEEDED
- Speedometer/odometer function is intermittent. VSS location?
- HKS EXHAUST
- take tranny out or keep it in? just look and see...
- 1992 Honda Prelude SR
- ATTS -> base swap?
- JDM H22 Backfiring!?
- Weather Stripping and Tail Light Gaskets??
- Best injectors for All motor.
- Swaybar Mount fixes
- Tuning Built H22
- suspension question
- CCA
- acura integra ls mesh wheels
- Compression Result: 180 - 180 - 180 - 180. Good or bad?
- h22 internals in a h23 block, possible?
- 5th Gen - Which Caliper(s) to buy? Stock or Aftermarket???
- obd2 distributor picture
- need help please
- douse this model really exists
- Upper Rad Support
- a/c want to put back in car
- 4th gen vss question
- sputtering miss
- both front calipers fail within weeks of each other?
- Quick question about catalytic converters Sorry searched
- Trunk Help
- Measurments of trunk space in a 1998 prelude?
- which setup is best???
- whats the diffrence in the 4th gen. prelude base and sh
- will a 98 f23 5th gear swap into a 5th gen tranny?
- need help
- Oil Drain Bolt thread size
- Hey guys I need a little help......
- still having the same problem with speakers
- is the p13 ecu differant than the jdm ecu?
- not to sound stupid...
- swaping out f22 , h23a1 goin in
- Axle nut size(in MM) for 93 Prelude Si?
- Valve cover O rings - replacement options?
- S2000 Start Button Question
- so cal only TEST FITS
- Car turns off immediatly after being started.
- car drives unstable?
- h23 trans topspeed?
- JDM Conversion Too Far, Need Help Though!
- Rim size/type suggestions for 5th Gen
- still need help with 4ws
- Question about JDM Fron end for BB6 Prelude (5th Gen)
- Looking for contact info on car for sale...
- Exhaust leak
- Volt Exhaust
- Headers for a JDM f22b DOHC ????? 93 prelude si??
- 1988-1989 prelude not starting
- Speaker wiring issue
- H22 exhaust flanges
- Wtb: H22 Intake manifold
- ABS light on my 5th gen prelude
- running p28 knock sensor q
- Poor mileage question
- 95 Prelude pops out of 3rd gear??
- Clutch pedal stuck to the floor...how difficult to replace Slave Cylinder?
- Exhaust
- axle questions. .
- NEED SOME HELP!!! H22a with chipped P06 ecu would this work.
- 96 honda prelude h22a fullswap
- misfires and catalytic efficiency problems
- update: 11 years owned: 155k miles on 5th gen
- Auto-Cerm
- Knock sensor and CEL
- 92 lude Si problem
- please help. i need to get new wheel well moldings. or i think thats what its called.
- my valves are knocking help
- High Fuel Pressure..
- Which exhaust to use.
- Anyone hear from 4bidden about the shortshifter?
- Slick50 high mileage fuel system cleaner
- h22 to jdm h22 swap problems
- engine light after coolant bypass mod
- code 43, EXTREMELY high idle, possible o2??
- Weird and Random cut outs while driving.
- Iacv Plumbing
- random misfire codes...help!
- 93 prelude overheating
- map sensor diagram
- Tranny Questions.....4th gen m2s4
- Idle Surge Issue
- HOW TO: Convert OBD2 h22a4 to OBD1 h22a1/h23a1 distributor
- h22a1 harness
- Prelude noob problem
- What is this part called?
- taking the engine out?
- Turbo H23 Owners!
- Preplexing Issue
- How many hp can a stock clutch handle?
- HELP?
- So cal Tuning and Performance shops
- Key chime wont stop, and doors keep unlocking themselfs.. ideas?
- Valve SEAL A and SEAL B which is for WHAT SIDE?!
- suggestions
- Bad knock and "shimmy" coming from left front wheel well
- tranny bolts
- Hydrolocking question...
- --------> Tokico Illumina Dilema, if you own a set please chime in :D
- need help...car randomly died while driving
- Question for the H22 owners.
- Been a while, getting back into the Honda game?
- Misfire in all 4 But runs fine
- Please Opinions neeed...
- Prelude noob help
- Auto to Manual belt tensioner conversion on H22 - bracket problem...
- V-tec sputtering
- Euro R Crank pulley fits H22A?
- car turns off randomly
- bog problem?? h22 turbo
- F23 head F22A bottom.
- For those who have a 94-95 Accord lip on their 4th gens.....
- H22a water pump water leaking
- i need picture references
- Check engine light!!!! Please help
- Auto lsd in a USDM 5 speed?
- need help...94 lude h22a
- Is using a 96 POH accord vtec ecu healthy on a H23A Vtec in a 96 Prelude PLEASE HELP
- help!!!!
- whats the differance between long block and short block?
- Total Love for the Lude but...?
- Help removing useless rear seats
- Tires
- Is this block salvageable ?
- Balance shaft belt adjuster bracket (Replacement Bolt)
- smaller crank pulley on h22
- what do yall think of this h22? !! PLEASE HELP !!
- slack in brake pedal? not another cyclinder!?!?!?!?!?
- Dynoed Today.. Lost ~20whp and ~14 tq :( (BUT WHY?!)
- installing dynamat ??? (Opinions and Help)
- lips for my 3g
- 4ws codes and cel codes blink together????
- putting RSX TYPE S steering wheel on 4th gen?
