View Full Version : Honda Prelude
- oil level
- Timing / Belt Diagrams & ?
- Jdm H22a Swap - Need Help ASAP
- 2001 stock dyno... need advice
- jdm power folding mirrors.
- tune up
- spark plug wires, need help!
- dumb question......
- Resetting your headlights factory position??
- good ridge g-stop brake lines
- Alignment question
- H22A is acting up part 2
- rattle/buzz at partial throttle
- All Prelude Gurus! need help before dealership screws me
- please help dont know whats wrong with my car
- H22 Turbo Cams?
- 97 prelude sport shifter
- valve stems (for wheels)
- h22 swap.... electrical overheating????
- IAC Location
- High Flow CAT for 3rd gen
- okay possible idea on what may be wrong with idle surging on car.
- Problem with A/C and idle on 4th gen...please look
- Cam gears, Cams and a VAFC?
- JDM Strut bar or Spoon strut bars
- H22A timing belt generic part number?
- Whats the best camshafts?
- Overrevved (Bent Valves?)
- ????question for people with h23 gude cams????
- Tranny Clicking...
- Neuspeed Race -vs- Eibach Pro kit?
- Prelude/accord Cats
- My H22 makes still some noise...PLEASE HELP
- About Tanabe Springs
- another prelude fubared
- Timing Belt & Balancer Belt Install?
- missing tranny bolts from my prelude?
- 4th gen Master Brake Cylinder questions (and need to know the size)
- 215/40/18 will it rub?
- output diameter of dc sports header??
- Seal and weatherstrips from factory are damaged...
- Board needs more moderation again...
- problem with 92 lude
- 5th gen h22a head on 4th gen h22a block
- Cam Gear adjustment
- engine rebuild
- obd1 P28 computer, obd1 h22a 345cc injectors, do i need the resistor box ?
- Please help 5th gen suspension query
- HELP! WTF is this cable, and why can't I shift!?
- higher compression same time??
- help!!!
- water pump go bad
- airbags
- smog test! when can an engine pass!!?
- CAI on 98 prelude
- My Car is not starting well....help!!!
- Exhaust Soundclip website
- is this prelude worth it?
- Dyno results!!!
- Remote Entry
- Valve adjustment on 5th gen...
- TOP coilovers for 5th Gen???
- HELP I HAVE A QUESTION ON SUSPENSION LOOK HERE!!!!!
- My Car Has Slowed down.....
- prelude vacuum box question very urgent.
- Best engine for prelude
- Terrible Vtec hesitation/studdering
- HyperRods for H23?!
- Turbo kits for H23???
- Help - quick tire question - !!!!!!!!!!!!!!1
- Wrecked my 4th gen
- Should timing belt vibrate? (H22 engine)
- best way to put the ps & alternator belt back on
- Fuel pump: "main relay" vs. "fuel shut-off relay"
- k20a typer on a 5th gen...?
- 5th gear grind & wheel off-set and other things...
- ABS Pressure switch
- strange vtec oil pressure CEL
- i need a peice for my VSS, FAST!!! anyone have tranny peices around??
- oxygen sensor heater
- prelude trunk flip?
- 3" piping catback for 5th gen?
- I am officially part of the group...
- JDM H22 Motor- VENOM Nitrous Kit- anyone have one of these kits installed??
- what i will need for a 5spd swap?
- Transmission Code
- fuel pump mabye
- forgot to greas a couple of things
- Turn signal dilemma
- on about my swap question about the black box
- Degreeing in your camshafts
- engine swap histeria
- Birth place of your Lude...
- How to best identify 97+ prelude injectors (obd2.2)?
- How To Get To Intake Mani. Bolt?
- h23 motor diagram???
- where should my fuel boost be at
- General Prelude question....
- Tire selection (different than the tire help below)
- man ive just about had it with this freakin ilin problem
- best year prelude ?????
- Tire question please help.
- V-AFC
- Checking A/F ratio?
- 5th gen: Anyone else get a clicking sound from their driver's side seat?
- Prelude v-8
- 1988 Prelude starter question? Please HELP!!!
- Kinda Wierd Audio Install Question (4th gen)
- A/C Compressor
- Check engine: code 36
- Selling my car.
- 17" tires on a 4th gen
- steering wheel not centered
- clutch recomendations
- belt length 4 no a/c
- does jdm lsd fit on the usdm tranny?
- Rear suspension question
- Phantom Grip
- springs rates...
- Another stolen car / Reroute the hood cable?
- could it be that the Clutch is slipping?
- Will this work?
- Car stalling out.
- Cam Tech
- Feeler
- Loss of Power
- Solo short shift adapter??
- need a wiring diagram for 94 prelude VTEC (h22 jdm)
- What size injectors do i need????
- WTB : 5th gen high pressure fuel line
- question for the boosted luders
- HELP! w/ my 92 Prelude SI
- opinion needed...
- where r the hook ups on a iceman cai?
- Sport Shift....
- Any1 Selling their Prelude in the Bay Area?
- Is the H23 Crank Forged?
- H&R Sport Springs
- Mugen header + misc. stuff is ready for install! (56K beware!)
- 1st mod?
- h22 questions about the stock engine
- which parts to buy - 93 h22a1 ( prelude v-tec )
- H22A1 + P72 + VAFC?
- 93 Si exhaust
- conversion??
- H22 swap
- Thread size for the header stud?
- U tube
- I am buying a prelude, things to look out for?
- age affect hp?
- s2000 OEMs on my 5th GEN
- do 4th gen interiors change throughout the years?
- secondary butterflies
- Thanks!!!
- Hi all .......Who do you think would win?
- car is sitting still
- fuel pressure
- Pressure Plates?
- will the egr sensor affect my cars performance if not hooked up?
- Are 4G and 5G brake lines the same ?
- My car totalled by some idiot...
- RHD FRONT CLIP need help
- h22 in civic bouncing with skunk 2 coilover
- What is a good price to install Quaife, Clutch and Flywheel?
- H22a Cam Choice
- Turbo 92 S, h22 swap, nitrous?
- Rsx Seats Istalled! How to...
- Will H23 Tranny fit on H22A Engine?
- forced induction
- ticking probs
- Springs
- Got my tokicos and h&r sports in and ORDERED MY OEM KIT!!!!
- what kind of supercharger is best for a 2000 prelude
- 4th gen fog light installation instructions
- auto-x in the rain..... fun for all
- Is this the camber kit I should get
- okay got car running right but looking at A/f ratio guage running lean
- help with carfax for new prelude im buying
- cf valve cover for h22?
- why did it whistle??????????????????
- h22 questions
- emission questions
- can someone please help w/ ac on h22a in civic
- Looking for a Prelude baseball style hat
- what colors was the 92-96 prelude available in?
- aem vs hks
- lude springs question
- h23a w/ FI or h22a..?
- Rust on Cam Lobes?
- H22 tranny case VS. H23 tranny case????
- Many 2nd Gen lude owners in the forum??
- 97+ prelude stereo
- how to gain hp out of a 98 prelude
- Any of you 4th genners with the legend caliper upgrade, please read
- 97+ Prelude's airflow
- FS: 5th gen seat brackets
- H23 flywheel
- h23 euro tranny on usdm h22?
- anyone know the stock wheel size
- PGM-F1 = S or SI
- Modifying my GReddy header to a 2.5'' collector?
- n acura prelude compared to rsx type-s, integra gs-r
- suspension problem
- help no vtec!!!!!!
- Preludes on TV
- adjusting valves
- Tanabe Sustec STB
- Neuspeed Strut Bar? Is it Worth it?
- Swaping motors.....
- prelude shift linkage help: asap!
- how do you connect a autometer cobalt water temperature gauge?
- h22 on the highway
- Turbo Parts?
- JACKSON RACING SUPERCHARGER: INSTALLATION QUESTION
- RS*R exhaust, good or bad?
- m2a4 h22a jdm tranny
- m2b4 Tranny Questions?
- IC
- Question on spindle nut
- will euro r tranny fit the ss with no problem?
- Valve Reliefs on Pistons
- DO NOT SELL ANY ITEMS TO USER "BRAWL" David Worthers
- Prelude new generation ;))
- Help, I'm lost with suspension bushings
- Questions about SE
- H22 auto tensioner to manual tensioner install (picture intesive)
- simple brake question
- carsound or random hi flow cat?
- What does you thinking about does'ing this for your 4th gizzen?
- SMSP header question....
- People with Suspension Techniques sway bars. What's your opinion of them??
- ****Prelude Specifications and Stats****
- motor rpms at idle
- does anyone live close to south carolina to help...............
- Transmission Experts
- Header Install
- Can p28/72 bypass o2 sensors?
- H22 lags at low rpm's
- Let me know what you guys think about this(brake related)
- Roll cage for a 4th gen prekude
- PLEASE HELP ASAP!
- Organizing a group buy of ViS carbon fiber hoods! All makes, models, and designs.
- Would we consider the prelude a classic??
- Need pics of carbon fiber hood on 5th gen
- Leather Seats
- Prelude engine
- Please Help... Urgent!
- will front and back seat from vtec model fit in si
- Hondata ?"s
- 5gen-anyone know where I Can get carbon fibre trunk for closer to 400 than 600? Please
