PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Damn snow...snapped my rear axle any idea how much it will be to fix...help
  2. Another prelude with 6500 rev limit ant vtec-less. Ideas please!
  3. Does the F22 fuel filter fit in H22?
  4. will not start... Need New ECU?
  5. Another prelude with 6500 rev limit ant vtec-less. Ideas please!
  6. 92 lude brake problem
  7. air bag
  8. h22a4 engine problem
  9. 5th gen vibration
  10. H23a vtec blue top questions.
  11. h22 into h23 question
  12. Igntion systems check with JDM dizzy
  13. JDM H22 Trans Rebuild
  14. cel 22
  15. battery cable gauge?
  16. Need an answer ASAP! H22a1 rod vs h22a4 rod
  17. temp gauge problem
  18. Need help with H22A Setup
  19. decoding the ecu serial code
  20. 92si broken rear sway mount
  21. Code 43 (searched)
  22. oil change question
  23. cv axle boot leaking
  24. how much hp can stock valves hold?
  25. turbo setups
  26. Need help with d.e.q
  27. H22 - vtec not working
  28. 2000 Prelude, Headlight bulbs die quick
  29. got a leak, can anyone help
  30. TPS and Throttle body
  31. 98 Prelude driver door will not unlock
  32. car wants to die with foot down in lower gears
  33. vtec- can u hear it engage?
  34. Oil in Spark plug holes
  35. radio static
  36. Piston pin oiling H23VTEC considerations
  37. f22 swap to a h23
  38. a little vtec help?
  39. h23 no compression
  40. What wheels, and what are the specs
  41. reving low with A/C on
  42. Walbro fuel pump on stock 92 prelude H23
  43. h23 alternator and radiator interchangeable capability
  44. JDM swap question
  45. how to check CEL
  46. Need help!!
  47. Exhaust Help
  48. extra metal on strut towers?
  49. after swap- no tach!?!?
  50. REPOST://Oxygen Sensor Wire Help!!!!
  51. my lude wont start f22 swap h23
  52. H22A Adjustable Fuel Pressure Regulator Which Brand
  53. Warped Timing Balancer Belt Drive Pulley?
  54. F22 to H23
  55. o2 Sensor help!!!
  56. Phearable ECU Shift light
  57. ATTN people that installed a walbro 255 fuel pump
  58. No power steering + friend driving= 5th gen down
  59. need help with clutch/ tranny prob please need help asap
  60. Burning oil?
  61. H22a timing belt on edge of cams ..help
  62. 92-96 Sunroof
  63. Stalling Out
  64. H23 IM Ops Check
  65. valve gap length
  66. egr issue
  67. 98 H22 into 97 Harness question
  68. Tein H-Tech springs
  69. got some questions????
  70. In need of some info on my harness
  71. 96 obd2a-obd1... help?
  72. pic request of location of head bolts(search is down)
  73. Please help!!!! 98 lude wont start
  74. My ebay "front lip"....
  75. 5Th Gen Tranny in to 4th Gen Issue. HELP!
  76. Starter problem *video*
  77. Your lude in the wet
  78. speedo
  79. Heater not working?
  80. Trouble removing camshaft holders
  81. Weird Stutter/Backfire
  82. wiring diagram and how to use volt meter please help
  83. H23 wrist pin size
  84. need help bad...jdm h22a swap
  85. suspension question
  86. Check-engine light...Code P0420
  87. 97 Lude need help!!!
  88. Best H22 (FI) in the westcoast?
  89. RPM goes down then up when pressing the gas pedal?
  90. Brake pedal clicking?
  91. prelude rough idle
  92. Parking lights out aswell as dimmer NEED HELP ASAP
  93. EGR Port Cleaning
  94. CEL Questions
  95. H22 Swap (Accessory Related)
  96. finally did an exhaust....well kinda
  97. JDM Intersection\Cornering Lights, install ?????
  98. sluggish when the car is warmed up.
  99. can i wire back up lights to a switch?
  100. mahle
  101. JDM H22A > H22A1,4 fitment question
  102. prelude shock mount torque spec
  103. does anybody have pics of prelude on tl rims
  104. stock h22 vtec head can hold?
  105. window wont go down.....
  106. heat doesn't work
  107. Swapping obd1 internal coil into obd2 external h22
  108. spoiler LED
  109. 300$ Plus Serice for Keys
  110. vtech not working
  111. Just had clutch installed and now wierd noise
  112. I need help with Mugen bodykit for a 5th Gen.
  113. Clutch??
  114. car not starting but battery not drained?
  115. Please Help, Leaking Coolant
  116. 97-01 Prelude Questions
  117. fidanza flywheel
  118. Bad master cylinder/Clutch?
  119. Pic. of my new gauges
  120. 1998 Prelude :: Timing belt skipped some teeth
  121. 1997 prelude valve cover torque settings
  122. Vibration and Squeeling/whine, Rear Balancer Shaft Pulley
  123. Help Me Evaluate My Car For Sale
  124. Black 5th Gen in Jax
  125. are there any C.A.R.B Legal turbos
  126. H22 Tuning
  127. what hp gains with 5-8 lbs of boost would you expect to get
  128. Power locks going on and off
  129. I have a weird sound coming from my car
  130. slipping act clutch after 700 miles
  131. Where is block drain bolt on H22a?
  132. Where do i find seat rails?
  133. Sponge-like piece in windshield washer reservoir?
  134. New to Honda need some help
  135. High pitch whine from under hood!?
  136. valve cover nut won't come off!! ?
  137. whats my next best upgrade
  138. 4th gen Belts
  139. gold dr20s 15x7 0 offset on BB2. fit ok?
  140. Unorthodox pulley worth it?
  141. How to check/change manual tranny fluid
  142. h23 spark plug cover
  143. body kit help?
  144. 4th Gen Climate Control Buttons Won't Switch or Lights won't come on.
  145. Pelude help!!
  146. Seat Rail Dimensions for `97-`01
  147. help with h22 block
  148. High Flow Fuel Filter..?
  149. Cat-Back exhaust hitting rear lower control arm!
  150. How to change auto tranny fluid
  151. rims?
  152. 99 prelude died while driving and wont start??
  153. e85 h23vtec
  154. Whats this mark on my crank Pulley
  155. performance radiator
  156. Idle Problems with my 91 Si
  157. ECU and electrical prob wont pass emissions!
  158. Crazy_Mystery_Problem - Wont start up
  159. 225/50/16 rubs need advice
  160. HELP!!! 93 prelude nonvtec h23a sparkplug diagram
  161. f20c pistons
  162. Fitch Fuel Catalyst
  163. throwing code 4-8 on ABS
  164. snapped a shifter cable
  165. DOES ANYONE know this PART!!!
  166. 5th gear grinding
  167. 2nd gear transmission issue!!!
  168. MSD SS coil and cap
  169. Whats up guys
  170. b series plug wires on h22 ?
  171. help plz, Radius rod bolt stuck!
  172. Whats wrong with my starter?
  173. RomPirate's 5spd Swap Resource Thread
  174. Quick ECU question
  175. Tranny FLUID Level Questions ('92 AUTOMATIC Lude):
  176. ABS help fast!!!!
  177. prelude reverse lights not coming on!!
  178. Check out this 4th gen...
  179. does the 5th gen. prelude
  180. H22 swap, KS problems
  181. 5th gen door
  182. 97 Base trans...
  183. h22 pull
  184. Catch Can: Result
  185. H22A1 runs without evap hoses but not with.
  186. H22A Engine Harness
  187. Rear Brake issue
  188. no power to anything
  189. going turbo
  190. Mahle gold pistons for boost on h22a, your opinions?
  191. Fuel injector question
  192. DH-Racing Billet Mega-Flow H22A Intake Manifold
  193. Help with my Drive side Door
  194. P13 ECU Q30 Blown up
  195. Changing IM
  196. Harmonic Balancer/ crank shaft pulley
  197. drivers window came off track how do i fix it
  198. car makes a whistling sound when accelerating
  199. H23 idle problems
  200. Type S intake manifold any good??
  201. h22 flywheel torque spec?
  202. Missfire, Guess its time for plugs
  203. dont know what to get
  204. obd1
  205. Seats
  206. Data link conector in BB4...
  207. Question about a car I just bought for my brother.
  208. 89 Prelude Tech Help!!! plz
  209. what RPM should i set my v-tec to engage
  210. Help finding c27 engine number
  211. 92-96 prelude vtec socal needed for test fit
  212. Best paint
  213. how come no b18c
  214. H23 intake manifold, only aftermarket one is OBX crap?
  215. car bogs down just doesnt want to go.
  216. Name this color!!!
  217. h22 help
  218. 97-01 wheel bolt patter
  219. Oil Leak. Bottom half covered n tranny covered in oil.
  220. Headlight removal 101
  221. 4th gen dosn't idle right
  222. SPOON Sports P13 ECU & Mods
  223. Good ways to restore lost power?
  224. front lip?
  225. 88 preude need help
  226. Turbo Management
  227. i wanna replace my fluid filled mount
  228. Where to find replacement 3rd LED brake light
  229. cold air intake help
  230. 92 Prelude - VTech header to 2.0 engine?
  231. 4th gen prelude power programmer
  232. H22 PSP Ground
  233. Turbo header
  234. manual tensioner
  235. My build is almost complete!!!
  236. no fuel?
  237. Need help with my Prelude 93 lights
  238. Really weird problem.
  239. exhaust.
  240. 93 prelude tranny!!!????
  241. replacing the oil pan on a 97
  242. cheap turbo kit
  243. H22/H23 jdm bluetop vtec oil pressure
  244. Engine lacks power
  245. H22 oil leak PLS help!!!!
  246. knocking noise when i turn on the car
  247. My timing belt is walking out help me out, H22/H2B set-up
  248. Broken adjuster ball on rocker arm h23a1
  249. www.BeneGoods.com,nike dunk sb,jordan fusions,air max shoes,nike free
  250. ticking noise when gas pedal is pressed
