PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Over heating or not?
  2. Front Tow hook BB6...
  3. '94 Prelude Si a/c freon capacity specifications
  4. Amplifier under seat or in trunk?
  5. Vehilce Identification?
  6. can the rear shelf be removed?
  7. skunk2 intake manifold install... GRRRR!!!!
  8. Need some help. plz
  9. I couldnt find this on this site so Im asking. How do I find out what trim my prelude is?
  10. I need help. where can I find my plug to plug in my code reader?
  11. how much horsepower can a stock 97 prelude auto trans hold?
  12. Weird Noise on Start Up
  13. 87 prelude has no spark or fuel pressure
  14. cleaning bare block - FRM friendly chemicals?
  15. bb6 going obd1
  16. Abs code 53...
  17. Help diagnosing honda prelude 2001 problem!
  18. Help with head light
  19. Slick sizing
  20. Suspension/subframe USDM:JDM compatibility question...
  21. freeing up a "stiff) Ac compressor on car??
  22. Oil filter size
  23. JDM H22A Bell Housing and Oil Pan
  24. One quick question...
  25. bb6 SiR questions...
  26. transmission spool
  27. passenger headlight problem.
  28. h22a1 Prelude OBD1 CEL Code 43 -FUEL SUPPLY SYSTEM- HELP
  29. 89 main relay location and part number>
  30. Jumped Timing?
  31. Harness Bar
  32. mahle gold series valve relief ?
  33. Help finding cooling fan wires
  34. Can fuel injectors "whine" ?
  35. Simple IAB question
  36. would accord upper arms work in a 97-01 prelude
  37. Mr gasket fuel rail ! banjo bolt
  38. Worn out clutch or worse?? help!
  39. rear lip fittment for an exhaust bb4 series
  40. Question about my 2000 Honda Prelude transmission.
  41. Stuck clutch
  42. Turbo help!!!
  43. Cam seal/plug loosening & tightening sequence picture, dizzy oring
  44. valve cover center piece
  45. h23 vtec build question on timing
  46. tranny
  47. AEM V2 V Top Fuel Power Chamber Intake
  48. dead blinkers
  49. distributor problem-no spark
  50. s2000 steering wheel on honda prelude
  51. lowering springs question
  52. Aftermarket Fuel Guage
  53. AFR Shows a bit lean
  54. remove abs
  55. obd1-obd2 HARNESS SNAPPED
  56. 2000 Honda prelude h22a questions
  57. 92 Lude with a 94 Complete motor, trans, ecu, wiring harness
  58. building my own header
  59. Gauge Cluster
  60. 5thgen Part out ( picsNprice)
  61. HEADlight adjustment
  62. will tein s tech ruin struts?
  63. Help. CEL, no code, no VTEC. (H22A)
  64. 98 Predlude - JDM Swap wont start
  65. Type-R seats in BB6/5th generation...
  66. DIY port and polish write up?
  67. MFactory adjustable upper control arms
  68. horsepower
  69. Need help for replace HID.
  70. WHAT KIND OF INTAKE...
  71. NEW TO THE PRELUDE SIDE....
  72. Axle...
  73. PLEASE HELP **Another Prelude wont start**
  74. Are motegi racing rims worth it?
  75. can i put skunk2 cambers for a civic on a prelude?
  76. can i put skunk2 cambers for a civic on a prelude?
  77. AC & Cruise control DELETE PLUGS...
  78. Wheel Offset Question on a 5th gen. Can't find it in the Archived Content
  79. Stupid F^¢king Radiator Shop Guys
  80. best throttle body
  81. aftermarket overflow tank??
  82. 93 h23 clutch replacement...need to know
  83. MFactory catch can install
  84. axle stuck in tranny/diff
  85. 92 h22 jdm oil pump swap help!!!!!!!!!!!!!!!
  86. Putting a H22 head on a H23 block? Is this smart? PLEASE HELP!!
  87. What wuold happen if you run dry // low on MTF fluid ?
  88. tach is way off
  89. Need Help ASAP lame question
  90. 1987 Honda Prelude... Need Help BAD
  91. Suuuuurge!!!!!!!!!!!!!!
  92. 94 Prelude, crank and cam bolts torque spec needed
  93. custom body work...south florida?
  94. HELP: SUSPENSION PROBLEMS
  95. H22A1 Engine Code and Alternaotr question
  96. Radiator fan
  97. What is the best stock ECU tuning option?
  98. Headlight dimensions
  99. type s pistons
  100. 1995 Honda Prelude Paint Job
  101. best piggy-back for bb6 w i/h/e
  102. 5th gen's with coilovers, do you have this problem?
  103. h23 cams vs f22b cams
  104. Decoding abs code
  105. What am I missing?
  106. Base v. Type SH - outer tie rod ends
  107. my car only runs when the "D" connector is unplugged from the ECM
  108. crossmember / rear subframe connecter
  109. A/C problem
  110. anybody run 225/50/15 tires on their stock 4th gen Si / Vtec rims?
  111. Prelude H22 N/A Setup..!!
  112. DIY shocks install anywhere??
  113. And yet another Muffler thread
  114. Wont rev past 1k with chipped po6!! HELP
  115. Prelude coilover options
  116. clutch problem
  117. PICTURE REQUEST: SKUNK2 COILOVERS DROPPED ALL THE WAY
  118. Anyone know "The weather man" aka "Thekingpin"
  119. starter issues - possible starter clutch relay?
  120. Turbo lude
  121. 94 Prelude 2.2L Vtec Tips
  122. Anyway to remove interior A/C+Srs parts w/o dash removal- 5th gen
  123. 2001 Prelude won't stay running
  124. f22b SOHC into 4th gen.
  125. Coolant Temp Gauge hookup ...where to mount sensor
  126. Engine Block on a 5th gen prelude?
  127. fuel rail space need HELP!
  128. cant find any information regarding.....
  129. h22 help
  130. question about vtec solenoid
  131. Greddy Stencil for Front Mount Intercooler
  132. turboing a h22
  133. Oil Dipsticks.....
  134. 92-96 JDM Headlight Bulb Types
  135. Exhaust for 92-96 Prelude
  136. gas is 10% ethanol... good bad???
  137. 70mm throttle body sizing
  138. Code 9 CYL Cylinder sensor, Is going off. H22A4 00 prelude
  139. Oil Pressure
  140. Motor swap Question
  141. intermittant headlight failure
  142. Wiring IAB solenoid..
  143. iacv question???
  144. h22 header questin???
  145. Good rims?
  146. intake bypass
  147. f22b auto jdmh22a swap
  148. h22a4 block
  149. anyone use water bypass valve for there cold air intakes?
  150. hey guys are any of your cold air intakes this way..
  151. eazy compression
  152. My Complication of my swap.... (h23a1-h22a)
  153. Looking for stock 2000 Prelude type SH
  154. Soooo, my H22 is hydrolocked with gas. Calling all experts
  155. Prelude wont turn over from time to time
  156. need idle surge help
  157. throttle bodies
  158. What trannys will work in a 98 Prelude?
  159. 92 Rear Engine Mount Replacement ??
  160. timing belt
  161. 92 h23 engine knocking at high rpm
  162. h23a stalling when started
  163. timing belt tensioner
  164. stock wheels - offset?
  165. TEC HELP FOR 87 PRELUDE SI 2.0
  166. Carfax for a 4th gen lude
  167. stock 4th gen front sway bar size.
  168. Sound while driving
  169. new battery blown fuse
  170. 92 Si radiator swap
  171. Acids H22a Prelude Last Post on this BB1
  172. 5th gen caliper brackets
  173. catch can install? need help
  174. valves clanking while idle
  175. euro r trouble
  176. Timing Belt Replacement?????????
  177. 4th gen traction bars. whos running them
  178. need wide front fenders asap
  179. Will an accord? main relay fit a prelude
  180. Is it ok to run 185/60/15 tires on the fronts and 205/60/15 or the rear. 4th gen Si
  181. Hasport K-Series Conversion Mount Kit for 92-96 Prelude (BBK).
  182. Moates eXtreme Hulog question
  183. JDM heart transplant for the BB2
  184. jdm h22 oil pump swap
  185. Question on Intake manifold?
  186. Possible SH purchase, is this one worth it?
  187. 5th gen base model lower balljoint
  188. fuel injector help!
  189. oil
  190. knock sensor
  191. h23a1 intake manifold on f22b
  192. jdm cluster
  193. Front Upper Strut Tower installation problem
  194. This was in my oil pan and now no pressure??
  195. valve cover gasket
  196. What engine harness is this?
  197. rear lower control arm bolt
  198. Would it be possible? B20A5 to H22A1 Conversion
  199. Clutch feels wierd HELP
  200. Chipped p28 h22a on h22a4 motor
  201. CEL Check Engine Light staying lit...
  202. type-sh block
  203. JDM H23A Vtec Blue Top Mystery Motor, True Facts, Questions?
  204. Ever consider a new engine assembly from the factory?
  205. 97 Prelude, Can I Use Smaller Civic Radiator?
  206. How do I change out my shift boot?
  207. 3 small orings in cylinder block gasket kit
  208. central jersey jdm h22a and lsd tranny owners only
  209. Passenger Side Air Bag Blockoff's
  210. Actual opinions needed, Is this a fair price...?
  211. Normal compression #'s for an H22A4?
  212. About to hit 100k....need some advice
  213. S2000 throttle body on H22 engine - Will I have install woes and gains?
  214. Is this bad??
  215. best oil help!!!
  216. Carpet weight ? Sound Deadening ?
  217. BB1: Seeking Advice on H22A VTEC Swap
  218. swap help!!!
  219. h22a throttle body gasket?
  220. Need help with my H22
  221. Rim Size
  222. How to remove door/window frame trim?
  223. another clutch question
  224. nos....
  225. ok something wierd...
  226. Cold Air intake question
  227. My Belts Came off Today!
  228. Installing axle...
  229. car shuts off after i accelerate
  230. where and how much $? convert H22 idle pulley to H23
  231. im just wondering...
  232. h22 gap size
  233. what size rims to use for race
  234. h22a
  235. Help! Intake manifold question.
  236. Synthetic Oil
  237. question!
  238. can you smog a h23a
  239. 93 prelude f22b auto
  240. test pipe with WS II, how does it sound?
  241. Replacing Rear wheel bearings
  242. CEL code 90..keeps coming on and on
  243. 4th gen temp gauge overheating
  244. AEM Short Ram + Air boost valve
  245. check engine light
  246. shaky suspension
  247. New Cross-Drilled Rotors from 88Rotors rusted after one day.
  248. how much and what kind of turbo for h23 vtec??
  249. Electrical Problem? HELP!
  250. 215/60/16 fit 4th gen?
