- My prelude died
- base model or sh? how to tell
- 86 Prelude 2.0 Si Rear Brake Disc Replacement
- h23a1 -> h22a
- O2 Wiring Diagram?
- Wheel bearing for 5th gen
- Axels - H22A civic HELP!!!
- NO SPARk
- Both Doors Rattle?
- Must have's for installing JRSC
- Bang for the Buck
- Suspension Question
- Prelude Seat Question
- vtec not engaging? car rattles a bit
- Name of paint?
- carbon fiber hood and trunk, s2000 seats
- Need camber kit step by step
- Swaping an h22a
- Type S piston rings
- code 9 ? car runs fine but thowing code 9
- need intake help
- type s cams
- tire rub
- What is a 92 SI COMPRESSION supposed to be on each cylinder?
- Helpin a friend out (Navi sys)
- Intake manifold gasket
- Difference Between Cams
- ::The Official Prelude 1/4 mile thread::
- Header question. How bad is this? Take a look at pic
- *URGENT* Prelude 4th Gen. seat compatibilty question!
- 5th gen BB6 passenger side mirror cracked...
- 2Fast 2Furious Fog/Smoke Blowing Fenders??? Anyone Know?
- How much i can bore a stock TB?
- Do I need to increase fuel? NA, ~200whp getting SMSP
- does anyone know for sure if 5th gen axles will work in a 4th gen???
- Exhaust help
- crankshaft prob
- left front wheel and Steering wheel vibration..?
- Ok Lone Luder I have a question only you can answer.
- how to remove AC and cruise control
- code 23 knock sensor! code 7 TPS
- Stock catback: whats it worth?
- accelerator pedal vibration
- How long till it blows?
- I have 8 codes.....
- 5th Gen Weapon R Headers?? anybody have them?
- Hellp need with wiring for my swap. F22 to H23
- Engine Ticking
- doing h23 vtec...need step by step asap
- Odds and Ends.
- mugen exhaust
- Exploded view of throttle body?
- Oil Sending Unit...
- 2000 h22 in a 96 accord. i need help
- Best Cold Air Intake, exhuast, headers for 95 prelude vtec?
- Smoothing the rough edges om my H22A4!
- wiring harness
- looking to make 375 whp off 18psi..will this do it??
- Civic Proportioning valve and master cylinder use on Prelude!
- installed prospeed header monday...read
- greddy TT
- Timing Belt keeps breaking
- 99 Prelude mechanical advice please
- Which engine is best to turbo?
- Questions about strut bars. Yes I did search before posting this.
- exhaust
- does the H23 have IAB?
- Centerforce Clutch
- h23 vtec build question
- turbo h22 how much boost safley?
- ABS to Non-ABS?????
- camber kit clearance
- my car dieddd one me, pleasee helpppp
- trannsmission leak...sos....sos....
- anyone bought the 4-1 sh header off ebay
- who has 250whp?
- tein s springs...
- Broke a water pump bolt
- Do I Need To Get A OBD1 Distributor When Converting to Hondata
- Clutch and Flywheel Install...Is This A Good Price?
- sputtering noise when shifting gears or downshifting
- b20a prelude block with b series vtec head possible?
- Pics of regular exhaust system for 89 lude
- How to remove crank gear?
- Speed Sensor Question
- fuel rail problem
- which model hondata???
- need help split radiater
- intake ideas
- Prelude Value
- broken distributor cap bolt + more?
- SpeedO Question
- For Those of you with the ss tranny. Maybe some hope
- h22 header on an h23?
- Who actually has/had an H23 VTEC
- Prelude purchase crisis!
- Valve lash too tight = lean?
- H22 Tranny Questions
- JDM Headers...ARRGGHH
- adjusting nut problem/question
- Need help on Advancing & Retarding my Cams on my H23
- H22A4 Rods Codes
- h22a and a 23A head swap
- prelude injectors or accord?
- 88-91 prelude tranny
- JDM axles same as USDM?
- h22 distributor cap...
- help - engine tick from h22a4 - troubleshoot
- H22a Swap from an H23
- Quarter Mile Times
- JRSC question any problems?
- Mugen chip
- Tein H-Tech Springs (instead of Pro-Kit or H&R sport)?
- Engine and Tranny
- turn signal doesnt work? 5 gen lude
- b16 swap
- Tranny Funky
- Solid Motor mounts???
- Here's a new one..
- How Much Torque Would This Setup Make?
- H23 Oil Pan
- Hmm... new car time.
- So I installed kyb agx's and eibach springs today
- Nasty Burning Smell
- D21A1 CYLINDER BLOCK OIL
- please help! fucked up idle!
- Drag Gen 4 instalation Question for 5th Gen
- Going Price for a 2001 prelude EBP with 44k miles
- What should I set my NGK Temp 7 BKR7E Gap At? Built H22A See Setup Here
- 4ws problems again
- Vaccum leak?
- car shaking under acceleration(searched)
- vented hoods
- Exhaust Help- Stock to B-pipe
- Tsudo exhaust
- timing a h23
- 97 Prelude Sh Ecu vs. 96-97 Prelude ECU...LOOOK!!!
- Normal Problems Inherent to Preludes
- 18" wheel - Best Tire Size
- Michigan Prelude owners...
- Help with Neuspeed Short Shifter
- help please my h22 out! idle issues, and mount/ or axels
- CAMS for h22
- h22 in 01 accord
- Help! Need P13 pinouts!
- My Spring build-up...
- H22A LSD Tranny ID
- Remove ABS??
- KYB AGX question
- What suspension do you recommended for an SH?
- 3rd gen Soot crap (carbon most likely) Pics
- New Member With a much Needed Question
- jdm h22a wiring
- 90 Prelude engine swap...what works?
- 92-96 vs. 97 radio installation....please help.
- OLDER PRELUDE MOTOR MOUNT KITS
- Running rich
- Ok WTF just happened? Hit vtec and possibly fried ECU.. pls read
- Clutch Blown
- How low on sleeves can I go?
- Anyone please help!!!>...
- type s cams in a jdm h22a
- laggy at full throttle
- need help with 97 lude
- am i missing something
- cant decide if i should sell the lude?
- Gear Grind
- Exhaust size...
- Where is the H22 Knock Sensor located?
- any one know what is a good motor to put in a 1988 honda prelude it is a project
- P1
- part question
- What generation/model of Prelude do you drive?
- Exhaust
- Havent posted in a while...still happening though...
- Cyl head & Rod bolts torque?
- b20 head
- Im a newb with a newb question...go figure
- JDM H22 Dyno - Pictures inside!
- ECU Fuse
- Secondary butteryfly ECu pin out Please help
- need some H22 specs
- how do i get rid of electronic air contol CEL????
- clutch master cylinder
- Wheres the break booster vacumm hose?
- apexi vafc
- I cant get into Reverse!!!!!
- Good sites for a replacement K&N filter for 5g prelude CAI
- steelies for 5th gen?
- what kind of shocks ????? SH???
- help i have an automatic
- denso iridium..
- Need help from someone using Zex nitrous
- i need a part out of a bad h23 head
- 4th gen flywheel..will it work on an h22a4?
- Are C-pillar tie bars worth getting for 4gen lude?
- how do i...
- camber/ alignment questions
- rotor question
- h23 to a h22-wiring harness
- Exhaust systems?
- What header should i get?
- sorry posted as thread.... h22a civic itb's
- 3" inch piping on jdm h22
- Suspension Question?
- Squeaky Springs
- NEW TURBO
- Maybe going from 4th gen to 5th gen.
- How many SH's are on the forum?
- Horn help
- Car smokes when i Hit vtec!!!
- stock 2.2 vtec g/box problems
- What is the most amount of miles you seen someone get on a timing belt?
- 2.2 vtec 4ws and abs light problem
- Prelude help - NEW 2 DA LUDE
- Mods are planned, but what brands?
- high octane gas
- All Aluminum
- straight pipe or hollow out the cat?
- JDM Auto h22 same as 5spd?
- Is it smart to???
- Shift Knob
- write up on changing clutch???
- ? about turbo sh
- best ecu
- o2 sensor extension question..
- Type s Pistons A or B
- flow rate of h23 injectors?
- Installed new gauges....i need some help!
- Got a lude' but stock stereo=sound of dying animal
- non 4ws to 4ws
- crank pulley bolt
- best lude for 5g
- sunroof question
- 4Gen 4lug to 5lug ?
- H22a4 @ 89mm bore for turbo?
- newbe
- 4th vs 5th gen?
- h23a valve clearance + data sheets + any infos
- No spark
- K-series 'lude?
- Lookin for a nice pluge wire cover???
- Spoon p13 vs. stock p13?
- prelude sh vs integra r
- Replacing corner front corner light!
- VAFC 2 wiring
- idle problems after turbo install
- JRSC and stock clutch?
- h23/22 clutch
- stroker kit??
