PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 [137] 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. need help fast with a simple electrical question
  2. H22a4??????????
  3. timing belt
  4. Half shaft question
  5. question about hood spacers???
  6. 4gen lude or 5th gen
  7. changing over interior colors
  8. big brakes and wheels...
  9. lug nut thread size
  10. Will a 94-97 Accord intermediate shaft work in a 4th gen Prelude?
  11. how many people have rust?
  12. clutch parts for swap
  13. need some opinions
  14. cv boot question?????
  15. lost laptop w/aem ems software where can i find it.
  16. New Clutch for 01 SH
  17. JDM H22 TCM (TCU) same as USDM H22 TCM?
  18. turbo and manifold question
  19. REMOVING EXHAUST
  20. 5lug conversion for 4th gen writup
  21. 91 prelude fan keeps running for a long time please help
  22. why doesnt the 4th gen vtec exhaust fit on the non-vtec prelude
  23. VSS
  24. Adjusting timing on h22 , need some diagrams, tips plz, searched !
  25. obd 1 vtec controller from b16 civic work on prelude h22?
  26. stock grilles
  27. RPM Dr0p?
  28. Distributor cap for JDM H22??
  29. sh prelude turbo
  30. Tanabe exhaust owners read...
  31. 1997 Prelude
  32. can you put a spoon chip on a auto prelude
  33. H22a1 many probs aaahhhh nightmare
  34. Can anyone tell me where it goes.....
  35. H22 EuroR Intake Manifold
  36. smog check needed click here
  37. question about MTF/ATF
  38. rdx swap
  39. temp/fuel gauges
  40. What weight/type of oil should I put on a 97 SH with 148k miles?
  41. Projector retrofit??? Difficult?
  42. where can i get valve keepers?
  43. ENGINE restorer?
  44. i just bought a 1994 prelude si!!!!
  45. dented trunk pan
  46. damn.. water leaks.. guess where?
  47. help!!! ecu tuning for a p28 in an h22a1 vtec at 4700rpms good?? i dont like it someone please help
  48. Need help with tranny question
  49. big rain...sunroof & windows down :(
  50. What parts do I need to replace for an engine build?
  51. jdm foglight circuit wiring
  52. Type-s cams vs. stage 1 cams nad stage 2 cams?
  53. s2000 wheels on a prelude 5th gen?
  54. check engine light
  55. Are ARP head stud bolts the same thing as head bolts?
  56. Type S headers vs DC headers
  57. Blown timing-belt on my 97 lude
  58. can someone tell if theres any way to tell h22 apart
  59. TB question (swapped out H23 for H22A4)
  60. '94 prelude si not firing all cylinders *HELP*
  61. part's needed 5-speed conversion
  62. 92-96 v.s. 97-01 Turbo Kits
  63. control arms
  64. 1/4 Mile Times
  65. Looking for H22 or H23 blocks 92-95
  66. 98 prelude SH suspension (struts?) recommendations?
  67. how do i clean my stainless steal header?
  68. question: "how to take tps off of the h22 tb"
  69. TPS and IACV
  70. a little help..throwing codes 3 and 12
  71. H22
  72. H22 tranny
  73. Needs help the handset attachment for the 4th gen
  74. gearing questions *already searched*
  75. Installing the jdm hiro lip. How do install this?
  76. Question about a H23a
  77. CD player question
  78. Do you have this
  79. need help....which terminal
  80. Wheel sizing question
  81. Quick Q(mtf)
  82. p28 auto ecu
  83. my crazy type s camshaft problem? someone please help?
  84. Which one?
  85. baring h22a with aftermarket pistons??
  86. Sequential shifter in Prelude 4G
  87. Gutting the Lude
  88. Transmission swap kit from Honda.
  89. exhaust manifold nightmare!
  90. Parting out my 94 Prelude S model with VTEC stuff
  91. my radio is retarted..
  92. Weird problem: CD player only works when trunk is open...?
  93. ABS sensor search
  94. ECU + Butterflies = Confused
  95. Help!! Failed Emissions (VA)
  96. head bolt h22a4 ARP, Stock, Old Ones?
  97. targa top 5th gen
  98. Must See: Upright manifold for H22 Preludes and Accords (a/c and p/s compatible)
  99. the balanceshaft problem of f22b!
  100. opinions on the Phantom Grip and Quaife or just aftermarket LSD in general!!
  101. Picture request: rear hub for a 96 and 98
  102. is my prelude retarded?
  103. air from climate control vents smells
  104. Who says the dc header does not make power..?
  105. why does one of my front tires wear out faster than the other?
  106. need help from some pro mechanics!!!!!!!!!!
  107. Kosei 16x7.5..43+ offset w/ 215/50 good on 5th gen? A very low one..
  108. picture request greddy front lip and WW sides and rear
  109. Prelude front lip. Appearance or airdynamics?
  110. Going All Motor and Im bone stock
  111. h22a tranny rebuild ????????
  112. Please Give me some help here !?!
  113. MSD SCI+ Ignition
  114. 92-96 maryland prelude owners please help, need to borrow part for inspection!!
  115. simple question from a b-series guy
  116. what ecu did you put in your prelude SH??
  117. h22a
  118. Knock Sensor Help
  119. SRS Light Trouble Codes - Lets get some info on them....
  120. I have a 2 questions I need answer about my turbo setup
  121. The mystery lives
  122. H22 Coil issues, JDM to USDM conversion problems
  123. H22 crank pulley keeps coming off
  124. how to tell it is type S cam?
  125. Help Diagnose Problem
  126. Need a spoon engine convertion.
  127. just a teaser. CF hood and lip added while the car is down
  128. Question about bearing support on intermediate shaft
  129. transmission shift arm question
  130. OEM 4thgen Prelude Suspension Specs
  131. JDM vs USDM pistons
  132. ES Mount Install
  133. mugen exhaust, difference in part numbers
  134. JDM Fog lights/EL cluster dash harness
  135. 17" wheels vs. 18" wheels- searched!!
  136. P13/P28/P72 with an H23?
  137. tightening the e-brake
  138. cleaning out engine bay
  139. Type SH Intake manifold ???
  140. 1992 Si Wiring Harness (did I screw myself...)
  141. Unusual voltage drops
  142. Problem with E Brake adjustment
  143. Pic of a 5th gen with a roof rack?
  144. water leak
  145. Check Engine code 9 problem
  146. radio install on a 97 prelude
  147. 94-96 EL Gauge Dash harness
  148. What size throttle body is best for a N/A build?
  149. JDM Option?
  150. how do i get the dash lights to reset/turn off
  151. Ignition Switch
  152. Needs AC lines
  153. Hood
  154. Installing jdm EL in US Dash
  155. need help on universal bosch o2 sensor install
  156. 88-91 sterio dash mount kits?
  157. I Need Help ASAP
  158. Help identifying engine
  159. real or just made up
  160. prelude lsd
  161. Went to the track last night.
  162. How to jerry-rig the 4pc corners in the 4th gen
  163. Timing Belt Installation Question
  164. 92-96 prelude lip
  165. Someone that KNOWS help me
  166. ECU wiring
  167. Best price on a greddy turbo kit?
  168. help overheating at idle but goes away when reved
  169. What's the worst case scenerio of not having a resistor box?
  170. post if you have a aftermarket steering wheel on a 5th gen
  171. Few question on my completed h22 to accord swap
  172. type s pistons and cams.....
  173. H22a2 drinks oil?
  174. Cold Air Induction Kits...
  175. gas milage?
  176. Car will not start; thinking I don't have the timing right
  177. Just picked up a 95 Prelude have a couple ??????
  178. what size are h22 injetors
  179. Valve Lash Adjustment specs
  180. 88 Prelude SI 2.0 - Timing Degree?
  181. Targa top prelude?
  182. CP Pistons 10:1 Dome Displacement
  183. Valve Tap
  184. type S cam
  185. anyone ever brake an axle and still have it?
  186. Anyone got a good pic of the slave cylinder line
  187. One more Axle Question
  188. brake light warning light staying on
  189. What exactly is the clutch switch?
  190. need help beefing up my f22a gen 4 lude
  191. longer time to start
  192. cam install problems type s
  193. got caught slippin
  194. 4th Gen Prelude Custom Tail Light Tutorial
  195. Camer kit for 00 prelude?
  196. A/C Compressor interchangable?
  197. Black box removal...
  198. Best LSD on market for 5th gen lude?
  199. Greddy turbo kits??
  200. how to wire a fuel pump????????
  201. Timing problem? belt stays on edge of cam gears. pics inside.
  202. JDM Headlights pass state inspection????
  203. Questions about cams/turbo
  204. Engine swap?
  205. 5th gen Need Help QUICK PLEASE!
  206. steering wheel
  207. Poly Mount Installation
  208. Where do you buy your header?
  209. Aluminum retainers
  210. Swaybar
  211. where to shop?
  212. New rotors old pads ?
  213. Burning Oil
  214. Right direction of 5g OEM wheels ?
  215. noob ask a noob question...
  216. Looking at a '94 lude...opinions?
  217. 01 prelude sucking too much gas!
  218. Axle question
  219. h22a1 obd1 motor into 5 gen lude using obd1 ecu (searched)
  220. Lowering Blocks. What?
  221. Anyone with a Jdmh22 in a 92 si
  222. is it safe to raise compression with a thinner head gasket?
  223. jdm foglight question
  224. Car turns over..then stalls???
  225. F/S: NEUSPEED RACE SPRINGS
  226. H22A Auto Transmission Gearing Questions
  227. H22a(jdm) vs H22a(usdm)
  228. P13 question
  229. Anyone have pics of World Sport 2 on 4th Gen or with Accord Rear Lip?
  230. removing head - anything else besides the bolts to undo?
  231. OBX Reinforced Radiator Hose Kit
  232. Dr side rear caliper problem
  233. Honda Prelude Techs PLEASE help!
  234. question my tact no working
  235. Car shuts off while driving...
  236. USDM H22 rod bearings?
  237. H22 Hesitation **its been searched**
  238. Help with JDM h22 in 92 Prelude Si
  239. H22 or H23?
  240. h23 turbo question
  241. Ignition coil question
  242. OEM lip kit
  243. Code 71 - Cylinder #1 Misfire
  244. 89 si in a 94 accord lx?
  245. Gas rag in the throttle?
  246. h22 engine weight
  247. will not having an ECU and motor in the car make the whole electrical system turn off?
  248. few random 4th gen ?'s headlights/turn signals/idle/pcv etc
  249. H22 lsd feedback
  250. Metal? for h23 block on majestic honda
