PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 [166] 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. My Prelude VTEC 2.2
  2. Injector question
  3. '88 Prelude - Check Engine Light flashes as RPM increase
  4. Apexi Silencer
  5. H23A1 oil amount
  6. 3rd Gen bushing group buy
  7. Aftermarket Injectors
  8. Intake manifold removal on 97 SH
  9. WTB ATTS oil pressure sensor
  10. 4th gen vs 5th gen valve cover
  11. Disadvantages of running a stock head on 11.5 to 1 compression
  12. Quick question to turbo h22 guru gays!
  13. Gas Economy
  14. Car is slower after diffrent cams, valvetrain, and .020 mill. Please help..
  15. track time h23/vtec
  16. swap question
  17. loose timing belt
  18. prelude charging system problems
  19. cars dead;cant put in neutral
  20. Ignition system
  21. H22 swap
  22. how much does OEM LSD take?
  23. radiator swap tonight.....how to do a proper system flush
  24. Throwing code 67 please advise.
  25. auto trany change over
  26. turbo prelude ecu question
  27. click noise on start (5th gen prelude)
  28. s2k starter button in a 5th gen, where oh where to put it
  29. Serious Issue with 90 prelude SI
  30. 94 prelude Si tranny problems
  31. weird noise while starting
  32. meegan racing
  33. paint?
  34. knocking sound... after a spin out.. need help!
  35. bi-xenon hid question
  36. 5th gen Euro R swap: No Spark! help needed ASAP!
  37. center rear speaker for 1994 vtec
  38. 97 Acura Cl with a H22 i have a oil question
  39. JDM Headlights yellowing.....
  40. Transmission gear ratios
  41. Speedometer Gauge Cluster!!?!
  42. does h23 intake manifold or h22a intake manifold fit 1991 f22a1 motor?
  43. 4th gen spoiler/wing
  44. 1991 prelude 2.1L b21a1 si help!!!!!!!!!!
  45. What is this and is it needed
  46. head games
  47. how to make an accord lip fit
  48. 92 prelude. Where do i put the OEM foglight Switch?
  49. Lean Racing customer service?
  50. i need pics of turbo manifolds for a h22
  51. F22 to H22?
  52. Front lips part II for 4th gen
  53. Prelude noob questions
  54. does 96 honda accord and 99 prelude have the same suspension springs...thanks
  55. Wrist Pin install on type s pistons
  56. anybody selling STOCK suspension spring for 99 honda prelude (non SH)...all sets of 4
  57. help with shocks?! important question
  58. B21A1?
  59. 92 Prelude with H23 motor
  60. ATTS light!
  61. Passenger door wont unlock
  62. JDM Fog Question
  63. front main and front balancer seal
  64. how do you bypass a knock sensor
  65. Having problems with my 87 lude. timing?
  66. drilling carbon fiber
  67. sun roof conversion.. searched
  68. turbo now?
  69. What is the best toolkit to start out the collection with? Working on a 5th gen
  70. What's Wrong?
  71. QuickCompression Questions(searched)
  72. Need help QUICK
  73. water pump replacement
  74. Base Idle??
  75. prelude lip ?
  76. TEIN EDFC
  77. H23 turbo set up
  78. Pulley kits
  79. OEM LIP KIT
  80. Lip kit
  81. Mugen Radiator cap/ Mugen fan switch/ Mugen Thermostat
  82. Possible suspension mods
  83. H22 integra turbo manifold
  84. VTEC problems
  85. All of your Tuning custom Basemaps/calibration files here (link to site)
  86. wrong camber....
  87. 4WS steering wheel adjustment (need a guru).
  88. Vtec Problem-Turbo related???
  89. anybody know were i can buy h22 headbolts
  90. need help with the e brake assembly
  91. JG Engine Dynamics 303 Camshafts For H23
  92. Looking for guys with retrofitted HID projectors in a 5th gen...
  93. h22a with h23a mods
  94. 4WS code 20?
  95. questions with h22 head swap to a h23
  96. CEL when using ZEX nitrous kit
  97. 97 SH what size is the oil drain bolt?
  98. 2000 Prelude correct injectors?
  99. 93 prelude turbo 4 sale cheep
  100. pic request
  101. autocrossing the lude
  102. stock prelude with cam gears
  103. rear wheel drive
  104. 1986 Prelude 2.0si
  105. sometimes car won't start
  106. will a b16a1 crx swap fit in an 88 prelude
  107. 5w20 in h22a?
  108. fuse box
  109. help with brakes
  110. v-tec malfunction
  111. Camber Kits!
  112. who's running the balancer shaft belt removal system.
  113. Replacing clutch
  114. weird rpm drop
  115. OBD2 F20 Distributor on OBD1 H22A
  116. Mugen rear spoiler
  117. Hondata Calibration files
  118. Old Prelude Engine Price?
  119. Need help with a short shifter
  120. h23 Emanage
  121. Those with Accord Euro R engine swaps, how happy are you with its performance?
  122. Valve fitment between H22 and H23
  123. Ford Fusion!!! 5th Gen Lude COPYCAT!!!
  124. Difference on Type S cams vs. Stock/jdm cams
  125. side markers
  126. front lip
  127. Wierd Vtec Problem??
  128. Rear quarter panel rust Question
  129. which ecu is best
  130. usdm ecu or jdm ecu?
  131. steering wheels
  132. port/polish, can i still use the headers i just got
  133. Camshaft Holder Tool
  134. Can anyone kindly tell me what means BB1, BB4, and BB6 for 4th gen prelude?
  135. Anyone have problems removing an axle?
  136. trying to wire vtec ????? confused
  137. What is this?
  138. engine code
  139. AEM Big Brake Kit
  140. Question of the month: Who....
  141. f series bare block weight
  142. 4th gen jdm headlights
  143. installing a push start button in '01 SH
  144. lower control arm problem
  145. Which turbo is better?
  146. Where can I find a TRACTION BAR (4th gen)???
  147. AEM REAR big brake kit 5th gen lude
  148. 1st Annual Pacific Northwest Type R's and Tight Cars BBQ
  149. full race questions development on 5th gen prelude traction bars
  150. usdm vs jdm cams
  151. finally got around to dynoing my car again
  152. Type SH Lightweight Rim question
  153. Difference between Base and Sh
  154. EGR Fix it questions...need some help.
  155. i just need to know if i got this rite
  156. when do i get full access to honda tech
  157. external coil wire q's?????
  158. a/c relay
  159. engine problem...
  160. 1990 prelude engine compression?
  161. 5th Gen Retro fitted projector headlights...
  162. suggestions on axle nut removal?
  163. I think I've been giped on my VTEC motor swap?
  164. axels
  165. wheel adapters/spacers, please advice me....
  166. Blue Gauges
  167. suspension squeaking
  168. electrical problem
  169. Which is the best route? (a theory question)
  170. Mugen Shocks on a Prelude?
  171. Safely disable 4WS?
  172. who to custom build my 89mm pistons?
  173. engine code
  174. Mugen Front Bar for BB4's
  175. Tire rub 18" rims 98 Prlude
  176. JDM CC???
  177. Hawk HPS VS. Carbotech bobcat better?(searched)
  178. Exhaust Smell
  179. Just curious
  180. Rod bearings question
  181. What does everyone use to clean their Prelude??
  182. H22 auto tensioner to manual tensioner conversion?
  183. Where can i get 4th gen prelude SE wheels?
  184. Idle prob...odd
  185. Help with DTC's...
  186. vtec vfac de wiring back 2 stock
  187. h22 and h23 turbo
  188. crower cams but need a new clutch?
  189. 4WS alignment, need help for my local NTB alignment "specialist".
  190. Exhuast help!
  191. Looking for a JDM 97-01 Prelude
  192. Recommendation for the best head gasket for a boosted H22
  193. 95 prelude with p13ecu wire question????
  194. 4th gen buddy club front lip still available?
  195. jack stands....
  196. Upgrading The External Ignition Coil
  197. I win... crank pulley fun...
  198. 1st gen
  199. Horses
  200. Filter Fury
  201. vibrations!?!?!( i searched)
  202. Rubbing and click sound coming from RH wheelwell
  203. Stock flywheel weight on a h22a? M2B4 gearbox?
  204. how much power can a stock h22 lsd hold
  205. overheating
  206. lowering my car
  207. gonna get rims, and i need some info
  208. idea....read
  209. spring insulators for a 97
  210. whats the verdict on the manual tensioner?
  211. best spark plugs for h22a
  212. whats the best complete computer tunning system under 500 for h22a4
  213. 4th Gen VTEC Calipers clear Volk AV's???
  214. non-SH neuspeed springs on a SH, fit???
  215. which tire size is better
  216. hittin the dragstrip....
  217. custome 2.5 DC header collector?
  218. Grinding noise/low idle
  219. carbon stuff on bumper (searched already)
  220. 13" wheels on a 5th gen
  221. Your exhaust preferences will help decide my muffler.
  222. JDM OBD1 H22a Oxygen Sensor...HELP!
  223. no power to the car
  224. 92 prelude --> BATTERY KEEPS DYING OVERNIGHT
  225. what are some ok rotors and brake pads for 4th gen?
  226. Need help clearing up confusion on Compression test
  227. what are these things?
  228. Replacing valve seals
  229. Center Console Armrest
  230. Trouble with my '01 tranny/clutch
  231. just swapped h22 in 92 prelude
  232. Can I remove this black box?
  233. greddy vs moroso catch can
  234. Anyone try these brakes?
  235. what motor oil
  236. Has anyone done this?
  237. Add 5 horses this weekend?!?!
  238. help please! struts problem
  239. Type S Pistons Vs JDM H22A Pistons
  240. Fast Idle Thermo Valve - anyone NOT running one?
  241. Tuning Session in Atlanta, GA Sept 16-19th
  242. 96 honda prelude radio code?
  243. I think I have a problem?
  244. integra or civic mirros on a prelude?
  245. HELP NSX caliper to 01' prelude
  246. itr tranny
  247. anyone got a write up or tips for installing lsd/spool
  248. 92 prelude wont start when cd player's hooked up!!???
  249. tunning the h22
  250. Compression Ratio Dropped. Est. HP/TRQ loss?
