PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 [251] 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. anyone used or try ag-enginnerring p28 custom h22 mapping upgrade chip???
  2. need help takein out the stock cd player in 5th gen lude
  3. headlights wont turn on...
  4. 89 Prelude Fog lights
  5. no signal from knock sensor
  6. 92-96 drag prelude 750hp
  7. blew my rings again, time to rebuild what should I do?
  8. Tranny Tech Question
  9. mugen 4th gen bumper i want 1 bad
  10. Running lean with zex....
  11. Thermal R&D Stealth vs Classic dB ?
  12. cleaning/polishing exhaust ports
  13. Tranny removal problem..help (H22 tranny)
  14. Neuspeed & Spoon
  15. brake fluid flush...
  16. 'Angel Eye' or 'Halo'headlights
  17. Diff between type sh and base model 97+ preludes?
  18. 97-01 Prelude Leather Seats
  19. FS prelude drag 2 turbo orange county 714
  20. Engine Response Wanted!
  21. Suspension Balance (Reducing Understeer)
  22. CEL 9 and 43
  23. Brakes locked up, ABS light on
  24. Can I run without air filter?
  25. broke my knock sensor
  26. Dowel pins on H22 Need them or not???
  27. good compressoion on h22a?
  28. just a few questions
  29. 88-91 Stock Intake Canister
  30. all YOU guys
  31. Eibach springs switch
  32. 4th gen heated seats
  33. Prelude problem.. 5th to 2cd downshift ( oops? )
  34. Anyone know of projector headlights that arnt god awful
  35. How time consuming and hard is it to swap trannys in a 99 lude
  36. ive been gone for 2 years, nothing changed
  37. Brake Caliper Quetion
  38. why has all the Hytech h22a header threads been deleted ?
  39. Euro Accord Type R crank pulley
  40. Ignition Problem
  41. what is better for h22s
  42. 98 h22 model prelude
  43. prelude wont start
  44. conveting to jdm h22 in lude si vtec wiring problems
  45. best tower bars?
  46. Needed: 92-96 OEM Passenger Side Fender
  47. 92 4ws - power steering
  48. anyone ever take a 4g prelude f22 w/nitrous/cai to the track?
  49. Took the Lude to the track today
  50. Need help with 96 prelude swap into 97 accord
  51. STR Fuel rail Installation (For The Mechanicly Inclined)
  52. 4th gen brake duct vents. Who has them/made them
  53. P72 ECU on a H22A?
  54. AEM Pulleys -Impression and Mishaps
  55. SKUNK2 h22 intake mani install help!
  56. about to paint my rims gunmetal
  57. got my comp test! still a couple ?s
  58. '88 AWS engine light
  59. Alternator Question????
  60. Best hood for 4th gen
  61. comp test and bleeding clutch?
  62. Help! Greddy Evo s pipe is drooping!
  63. Ran my car tonight...
  64. Is this all?
  65. OT: what happened last night halloween
  66. bonnet spacers??
  67. Electric Water pump?
  68. h22 bypass autotensioner?
  69. my car feels like its slow some time
  70. skunk2 intake manifold. h22a..............
  71. new to the scene ?'s
  72. good buy?
  73. AEM Intake vs. Knock off
  74. Running rich?
  75. Prelude Intake System?
  76. is a rear strut bar necessary?
  77. factory 5th gen cd player problem
  78. cf mirrors
  79. Turbo HELP!!!!
  80. My h22 dyno....few questions
  81. Whats up, New to the board.. here's my ride...
  82. 19 inch RH CX multi's on 5th gen
  83. Happy halloween!!!
  84. 4th gen Mugen bumper
  85. Need some advice!
  86. turbo Q's
  87. Eibach Springs... settling
  88. prelude si h22 swap NEED VTEC!!
  89. what the best intake manifold for my 97 prelude VTEC?
  90. Catch Can Location
  91. Just recieved my greddy turbo kit.....
  92. Electronic Turbocharger for $130!!! OMG!!
  93. Dyno: H22 463 Wheel HP @ 14 PSI Pump Gas :)
  94. accel injector
  95. Which would you prefer?!?!
  96. serpentine belt?
  97. Guys with STR fuel rail on h22/23???
  98. Front anti-sway bar sizes for stock AX class?
  99. Would you buy a Prelude with a salvage title?
  100. Hondaddict's Turbo H22 EG, dyno numbers inside....
  101. Corey Jacobs, you in here?
  102. AEM Pulleys
  103. PLEASE HELP!
  104. H22 or H23 tranny on my turbo H23 block HELP
  105. TRANNY CODe help ??m2a5??
  106. H&R SPort springs for 4th and 5th gen Preludes. Are they universal??
  107. Switches in the door jams
  108. 92-96 Prelude Lip
  109. Anybody knows details about dyno measuring?
  110. prelude h22a jdm ecu
  111. when starting in cold morning >>>>problems weird sound
  112. what is the pin out for the o2 sensor for a 95 h22a jdm into a 1992 prelude si
  113. Which Cam Gears for H22A ?
  114. best clutch for money?!?! help...newbie to manuals.
  115. h23 with f22a tranny. need info
  116. 5 gen SS to run 12s....couple of questions
  117. best header for gen 5 lude??
  118. Searched all over.... Need help with stock P13 OBD1 vtec / iab settings
  119. h23-->h22 injector ?
  120. fuel pressure increases
  121. 4th gen and 18" with 40 series tires...
  122. prelude suspension
  123. 3rd Gen luders...need good h22 swap links
  124. 2001 Prelude with Neuspeed Sport Springs
  125. Is there anyone in New Jersey that can help me remove a swap???
  126. Intake
  127. The Prelude Mini runs! and I have a question.
  128. 97-00 honda prelude exhaust for sale
  129. cel 65- can I ignore?
  130. ??BEST PARTS FOR '01 PRELUDE??
  131. Can you guys/girls help me with my HID installation?
  132. 4 Lug vs 5 lug
  133. LSD
  134. HID Question
  135. oil catch can question
  136. HIDs4less....are they reliable?
  137. What company makes the pin out connectors?
  138. cel light staying on
  139. Anyone know of any 5th gen Preludes at a junk dealer near them?
  140. SR-V Lude 1/4 w I/H/E?
  141. Throttle Problem
  142. Engine swap into prelude
  143. 97-01 Prelude BaseBRAKE DISC SIZE???
  144. cleaning spark plugs
  145. Aem V2 cold air intake
  146. Possible LMA problem
  147. Help! Tokico HP or KYB GR2 with Eibach Pro Kit?
  148. exhaust
  149. Front Lip Part Numbers
  150. prelude idle
  151. HELP with removing the a/c in my prelude
  152. Low idle?
  153. h23pwr's prelude baseline dyno run
  154. sold my 93 4ws
  155. close gear ratios
  156. Yes or No? Custom Setup
  157. RAM HDX Clutch
  158. Got the car back together...(somewhat)
  159. right coast ht meet link....
  160. which prelude
  161. Limited to 120mph...in 4th..how to change
  162. h22a4 into 4th gen
  163. DIY safety
  164. Test pipe
  165. dyno numbers..already searched
  166. getting rid of my car
  167. 2004 s2000 is going to have a 90.7mm stroke
  168. Plan to work on the head: Best harmony of parts?!?
  169. Any one going to Tokyo Auto Salon nex year??????????????
  170. Transmission Question
  171. H22A Skunk2 StageII with Oversized Valves Question..
  172. turboing car need fuel management and turbo advice
  173. Type s problems.....please advise
  174. turbo mani for h22
  175. Radiator ? 4th gen and 5th gen
  176. Need help w/ my My Prelude 2.3 h23a1
  177. Turbo'ed Ludes I need your opinion with running a test pipe on my soon to be turbo'd lude
  178. Cam switching
  179. Can someone tell me what kind of rim this is?
  180. 4th, 5th gen axles
  181. 90K mi. check up...
  182. v-tec fuel injectors in h23, would it work?
  183. Power Discussion: Throttle Body Coolers : Will it make a real HP difference?
  184. 95 lude turbo ?s......
  185. recmend intake and throttle body
  186. I got band becuase honda tech is a bunch of fucks
  187. A-20 Flywheel
  188. Teins
  189. Need Information on a F22B what timing belt does it use
  190. what size bolt is this??
  191. how hard is it?
  192. any JDM USDM engine suppliers in or near cincy OH or Louisville KY?
  193. wiring harness for turbo timer install?
  194. prelude axles
  195. accord aem --> prelude brake pads
  196. h23 to h22
  197. what brakes
  198. Quick review on the JIC FLTA2 for 5 gen lude
  199. atts problem help please!!!
  200. One Piece headlight question.
  201. trouble with quaife install
  202. intake manifold 4 88 prelude
  203. 6 puck vs street disk streetability
  204. UPDATE ON CAR EXORCISM
  205. car not starting i am stuck
  206. My lifter fell out (H23)
  207. reinstalling tranny
  208. Competition Clutch or ACT?
  209. Prelude Si-R
  210. throttle blip hesitation on freshly built H22a1
  211. Weird Clicking Noise???
  212. H22a Supercharger
  213. tranny stuck in 5th?
  214. Weight of 5th gens
  215. jdm cluster install
  216. code 41 - oxygen sensor heater?
  217. Turboed LuDe HeLp~!
  218. Who makes a good sheet metal intake manifold for a h23 non vtec motor.
  219. OK...today I find out that my car is leaking coolant...what do I do?
  220. 2000 Honda Prelude RIMS! what offset and size rims do you have?
  221. My lude is dying!
  222. Brake disc screws
  223. what i did to my stock manifold
  224. how to remove 92 lude gauge cluster
  225. Good & Affordable Header?
  226. CEL 4 CKP....wtf?
  227. P14 question? help....
  228. Map sensor question, 99 prelude...
  229. CLIMATE CONTROL???????
  230. GudeH23A I have an Important Question for you!
  231. can someone answer me please?
  232. anyone know where i can get a egr plate cover for a h22?
  233. Honda OEM Oil Filter
  234. jdm guage cluster?
  235. Prelude SI questions
  236. '94 OEM Prelude wheels/rims
  237. radiator cap fitment..
  238. knock sensor IS bad for a built engine
  239. 4th gen 3 piller pod replacement gb once again
  240. installed rear anti roll bar - do I need new endlinks?
  241. Wheel offset for 5G ?s
  242. what should I pay for a 99+ motor?
  243. Opinions on RPS street clutch
  244. need help with a complete rebuild of a 92 h23a
  245. Quik question for tubo luders with v-AFC
  246. re-installing driveshafts
  247. car back fires...
  248. Chicagoland Prelude Club
  249. Ideal offset for 18's on a 4th gen?
  250. DriveshaftShop Stage 2 Axles((trouble))
