PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 [220] 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. New Problems with the Lude
  2. Grey cast iron sleeves and forged pistons?
  3. Vaccumm pressure stayin at -757
  4. Inlet manifold gasket
  5. Inlet manifold removal
  6. obscure transmission problem
  7. Noise after rev
  8. Tubonator
  9. Boosting a 4th Gen lude
  10. For all you with turbo.
  11. My Steering wheel shakes while accelerating...HELP
  12. airbag module question....need help!!!!
  13. Question about high flow cats
  14. Need some Opinion and Advice On Repainting Preude Wheels
  15. exedy clutch
  16. rattle clanking noise in 2nd gear when making right turn ONLY
  17. SRS computer??
  18. ABS Light on, but blinks no code when checking?
  19. tire size recommendations???
  20. BB4 JDM Headlight Harness Suggestions
  21. Lude Census
  22. Worst valve adjustment EVER....
  23. How high can you safely raise the rev limit on an h22a1?
  24. Si and Vtec rod bears differences???
  25. 92 Prelude S swapped to JDM H22 AC problems
  26. queston about bearings
  27. question about disapearing oil..
  28. coil-overs???
  29. How do I increase HP (92 Prelude Si)
  30. 91 Prelude si swap
  31. flame when shifting at high RPM
  32. broken sensor?
  33. how do you become a unrestricted user?
  34. do any of yall know JDM BB2 ?
  35. lie most...
  36. power antenna switch
  37. new user
  38. Turbo prelude overheats when idling!
  39. Motor Doesn't Idle - Compression Check and Leak Down Test
  40. The Official H series Camshaft Thread
  41. check out the new ebay crap, hows this supposed to work for tuning
  42. Rear Speaker Deck Removal??
  43. Can a p72 work with a h22a JDM
  44. Looking for Shop in Illinois
  45. please move to moderator's corner
  46. p13 ecu problems. HELP ME the car will not start!!!!!!!!!!!!!!!!!!!!
  47. whats better h22 or h23
  48. new h23 what should i buy first?
  49. Gude Cams
  50. Third Brake Light
  51. Help with weird tapping/ ticking noise
  52. Suspension Problem?????
  53. fuel pressure / cat or gutted cat
  54. up & down idle
  55. blue flame
  56. 3rd gen q
  57. h22 cam shafts
  58. problems after install of new intake
  59. could someone throw me a few photos of a 96 lude interior?
  60. What do you Prelude owners use?
  61. Si VTEC fuel pump specs
  62. check this out dc makes you lose horsepower?
  63. PLEASE HELP!!!!!!!!!!!!!!!!
  64. anyone have a major leak in the car from ac?
  65. 97 intake fitting 93
  66. 94' Prelude side View Mirror
  67. Stage 2 cams and valves ?
  68. why is 3rd gear grinding?
  69. Tranny Horror Story
  70. Vafc Mounting
  71. H23 Torque specs on the rod bearing caps and mainbearings?
  72. H22A4 Block question
  73. JDM cap and rotor????
  74. ok just got a 87 prelude
  75. N/A s0unds go0d
  76. tachometer probs
  77. *HELP?!*CLUSTER QUESTION
  78. Fuel rail adaptability
  79. help about throttle bodies?
  80. looking at preludes
  81. sputtering after heavy rain for initial run at low speeds
  82. a sqeaking noise from the front left tire...?
  83. Exhaust
  84. Need Some help, Problem with 5g lude
  85. Thermostat for 92 JDM h22
  86. h23 block sleeves
  87. clutch smells real bad
  88. car studders cant figure it out
  89. 5th gen header
  90. ABS system comes on even during summer
  91. Ignition Coil Test?
  92. Knock sensor problems
  93. 92 prelude check engine light on
  94. Won't Start Sometimes
  95. swap h23 head on f22 vtec
  96. Fuel injector cleaner good or not?
  97. Progress Technology coilovers??
  98. f22 vtec
  99. from f22 to h23 or h22
  100. idling too low
  101. Tranny question
  102. Cigarette Lighter busted in my 95 PreLude
  103. Lower Control Arm on 4th gen. preludes supposed to be curved?
  104. b20 exhaust flange question
  105. need to know what kind of lube goes in the lude
  106. 4bidden shifter settings
  107. Difference Between SH and Base Under the Hood
  108. Premium gas...a must or an option?
  109. can i use crowe stage2 intake cam with stock exhaust cam
  110. help me pass emmisions
  111. 1993 Prelude electircal problem
  112. I need a front suspension arm thing??? for a 4th gen.
  113. need help before towing....
  114. car turns off while driving please help!!!!!!!
  115. dicky speedo
  116. h23/h22 header..?
  117. H22 Euro r
  118. ac smells terrible
  119. need help with pulleys!!! ASAP!!!
  120. Is it difficult to change wheel bearings???
  121. HELP: Transmission Problem
  122. Greddy evo2 adapter?
  123. HELP: DSM 450cc + AEM Fuel Rail
  124. WTB: B20A5 For 90 Prelude Si
  125. clicking coming from clutch or tranny??
  126. Prelude Quater mile?
  127. finding motor?
  128. manual tensioner and timing belt install
  129. 1st Gear blues
  130. Low A/C Idle
  131. Turbocharger Decision time
  132. Need Any Special Tools To Replace Wheel Stud?
  133. HID color chages?
  134. is the engine in the 2.2 CL the same as the prelude?
  135. walbro fuel pump not working
  136. Where to Buy quality stuff...
  137. Cams and Emissions
  138. clutch hours
  139. Hey everyone, quick question...
  140. 92' prelude si jdm h22a just got back from the track (times inside)
  141. Ingalls camber kit (anchor bolt for front)?
  142. Springs help
  143. pullies?
  144. ECT sensor fails and/or MCL isnt up?
  145. OT: San Diego area Luders check in!
  146. cyber motorsports
  147. fabricators
  148. juss got rearended !!
  149. Quick Question/opinion
  150. H23 and F22 tranny gears interchangable?
  151. The main components to the bottom end
  152. does anyone know where i can get a vtec head
  153. 4th gen rod bearing?
  154. F22 sohc non vtec... Should I put a F22 sohc vtec head on?
  155. Honda/Acura sports car market
  156. custom turbo people??
  157. H22 Head on a H23 block Help!!!!!!!
  158. buying lude
  159. would you do this
  160. coilover problem???
  161. i have a part i need to install and i need to know why it has to do with pully
  162. Anyone have stock springs lying around (5th gen)?
  163. hp racing exhaust
  164. OEM piston questions.
  165. 2.2 Cooling System
  166. Advise on H22 vtec problem
  167. Question on valves, head gasket setup ASAP!!!
  168. i have a question
  169. h22a1 head on a h22a4 block
  170. msd cap for h22
  171. 5th gen throttle questions?
  172. 3rd gen q
  173. racing seats and weights?
  174. Fuel Filter
  175. Forged wheels?
  176. H22A Tranny Noise When I Let Of Gas Pedal While In Gear
  177. Car just turns off while driving Please help!
  178. Spyhunter Modifications
  179. getting emissions today and brake lamp light won't go off..
  180. How much should I mill the head on my h22a4?
  181. 95 prelude noise on takeoff sounds like tire screeching as if i were spinning them passenger side fr
  182. Error codes 12 and 13 and the ABS light came on...on my 93 SI?
  183. Links to a badass prelude video!
  184. belt tensioner h22a need desparete help
  185. f22 mods
  186. Went to Irwindale Drag Strip today
  187. is a swap a good idea?
  188. What do I need to do, to put a H22 vtec head on a H23 block?
  189. Emissions (if anyone lives in texas plz help)
  190. Clicking sound when stopping
  191. 88 carb'd prelude idle control screw
  192. Would you buy a car wit 95k miles?
  193. h23 to h22 exhaust question
  194. Battle of the imports!
  195. do i need to resurface my flywheel if I.................?
  196. Best place for Oil Presure Sensor install?
  197. Poor performance for stock 2001
  198. help tRANS
  199. smsp header?
  200. I want power locks........
  201. sawblade rims
  202. Getting prelude, Have questions
  203. Did 5th gen ludes have leather interior option?
  204. Power Stearing Leak
  205. wheel help
  206. Keyless Entry FOB for 5th Gen
  207. what other car?
  208. car keeps stalling
  209. Just ordered all of my stuff...thoughts?
  210. Throttle body spacers on EBAY
  211. Front lower ball joint boots
  212. h23a1 tranny have syncros?
  213. alloy size and width?
  214. hey guys, im a little short on cash, any mod ideas??
  215. Buying '93 4WS, need help fast!
  216. my h22a is burning oil
  217. ooo aaa...... skunk2 mani supposedly out for real now, lol....
  218. ZEX DRY NITROUS
  219. 6X9 Sub in Si
  220. error code 43 *fixed*
  221. 5th Gen Mugen Exhaust System
  222. memory button driving me crazy
  223. vtec problem?
  224. help with installing A/F guage in H22a4...
  225. Why isnt my car running 15 flats.
  226. 5th gen gauges in a 4th gen prelude?
  227. help with putting vafc1 on to jdm h22a
  228. CA 'enhanced' smog test results
  229. question
  230. Transmission Mount (4th Gen)
  231. What place is the best to get a f22b?
  232. i got my H22 today!!!!! and im in love with it btw lol
  233. How can I tell if it's the rotors or tire balancing?
  234. i have a stupid question lol plz answer i don't know anything
  235. Quick Transmission Torque Specs for a 5th Gen
  236. Removing A-pillar in 98 Prelude???
  237. Calling on all members for help on this one > NEED ECU pinout for JDM Euro ATR H22 OBD2a
  238. Dyno ?
  239. Throttle body 5th gen anybody have one
  240. Engine cut out
  241. whats the best Clutch and Flywheel setup?
  242. thermal classic and stealth
  243. Failed Emissions, need help.
  244. satan i need your wisdom!
  245. (searched) what center console trimmings will fit on a 92
  246. Help with buying a 4th Gen.
  247. Examples of 2nd gen preludes?
  248. My piston rings are shot, what now?
  249. difference between h22 and h23
  250. cv joint will not go in!
