View Full Version : Honda Prelude
- acl bearings
- F20B6 in my 4th gen prelude
- H22A N/A build advice.
- car shakes when any throttle is used
- 95 Honda Prellude Interior Conversin HELP!
- 5th gen? Rear brake caliper bracket same as front?? OR???
- 96 prelude auto trans question
- need coil over for 90 si
- Reference Material
- knock sensor issue
- Intersting Balance Shaft Info
- jdm itr rims on 5th gen prelude
- I need a answera bout my TRAnny
- Help!!!!!!!
- 95 Lude turns over, let go of the key and it dies
- Keyless Entry
- 82' Lude with a B16 swap
- Advice for h22a rebuild
- Prelude Backseat
- ..:: WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Jan and Feb
- ..::: FOR SALE ONLY :::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Jan and Feb 2010
- Help! Car Shake When Accelerating
- JDM H22A into a 5th Gen Prelude
- DIY crank pulley replacement
- '92 lude. question about fuses/relays.
- New clutch not engaging?!
- missing coolant WTF?
- good deal on a 94 lude?
- adjusting rockers
- 96 H23A1 Repair questions
- HowTo: Bypass AFBS Amplifier (Acoustic Feedback System)
- considering a ct20 turbo
- 281whp/210tq - AV Tuning & Development NA Stroker
- Good Shops In Socal
- H22 Only runs good when at operating temperature
- Uh oh ! Transmission leak !!
- 99 Prelude suspension??
- What is a drop...
- Gotta New baby..
- clicking noise
- H23vtec is it worth it???
- ahhhh! oil leak from the oil filter housing on my 5th gen!!!
- answer my question, get five bucks. tax and shipping applies.
- Blue smoke after overhaul!
- 92 prelude rod knock ?!?!?!? Help
- lowerball joint/ tranny problem same time?
- quick question. about the midshaft
- Funny noise
- Would 225-50-16 tires look rite on a 16x7 rim?
- any opinions on ebay fogs and projector lights for a 5th gen?
- bearing noise coming from crank area
- OBDII to OBD0 coil wiring 3rd Gen
- Please help 92 instrument cluster lights do not come on!?
- 5G Trans Swap: Converting P5M Auto ECU to P5M Manual ECU Operation
- tranny issue please help
- 89 si with a B20A5
- 92 fog light adjustment?
- Merry Christmass to all of Honda-Tech's members!
- h22a4 vs h23, which is a better high performance build
- transmission problem
- srs question
- Really Need Assistance, Heavy Engine Bog.
- aem fuel rail help..
- help
- what trans. should be used
- '92 prelude
- Help pleaseeee...
- climate control issues
- Changed coolant - now engine revs up and down?
- honda prelude sh
- Post H22 swap issue: Sounds like TB is rubbing, but it's not the pump
- Noise...Without Cat...
- Stripped oil pan drain plug... tried some suggestions, need more help
- h22 sleeve liners/open or closed deck question
- i have a 93 lude
- How to integrate Ipod connection to stock 1998 headunit?
- need help with cams fast!
- 95 prelude h22a1 not starting
- Skunk2 70mm TB Question!
- LUDE RIP
- 95 prelude ecu codes
- BB4 Conversion Question?
- HID Help
- Engine overheating issue
- SiR S-Spec at Tsukuba HKS Hiper Challenge Rd. 4
- JDM H22a Build up
- will 97-01 prelude fuel pump work in a 92-95 civic??
- Please Help!
- Need Some Input Everyone!
- Skunk2 Throttle body sticking ?
- Need help with H22 high performance build
- 5th gen DUAL EXHAUST?
- Vibrant peformance adjustable timing belt tensioner............ has any1 use this b4?
- T2T4 trans. in 4th gen?
- why do 3rd gen preludes idle like crap?
- 91 prelude si wont crank
- aftermarket seat for bigger luder
- 2000 Prelude F22 Swap....
- Question before buying a Auto/Tiptronic 5th Gen Lude
- 5th gen lude~~Question about radiator
- 89 lude: Oil Leak from Injector port?
- does anyone know where to get a fiberglass hood from that looks stock?
- Msd Blaster SS Coil
- No clutch peddle at all
- H22A with OBDII???
- 1990 prelude help!
- S2000 Pedals on a Prelude? anyone do it?
- h23 build help needed
- IDK
- DIY windshield replacement?
- 5th gen: Rear LCA Bushing
- 94 Prelude S, No spark
- Frustrated and need help, slave cylinder
- HID's on JDM headlights??
- Are all H22's interchangeable ?
- help!!! i cant get in to reverse in my 99 prelude
- Need Help 1998 Prelude
- Advancing ignition timing any benefits?
- 93 prelude help..
- h22 and f22 slave cylinder same?
- 4ws
- Driver side door is not locking?
- What's The Normal Engine Tempture
- what is this parts name
- It is require to change automatic belt tension...?????
- Need your help. tranny issues!!
- puel pump?
- Bent connecting rod, dump the car?
- Synthetic blend oil
- retorque of ARP head nuts
- Just sending love to all my fellow luders
- h22 build so far
- NEED YOUR OPINON!!!: turbo setup
- what are the best Wax products for an Honda Prelude ?
- how to repair damage on an glassfiber bumper ?
- Engine Heating UP
- Timing belt? Fuel? Motor gone?
- How to Make Acceleration Smoother?
- Need help with main bearings
- Is there a J series swap yet?????
- Nippon Racing Type S pistons "?"
- 4th Gen Jdm HeadLight Bulb Size
- 2nd gen Kswap build idea :)
- whats wrong?
- Wrong radiator? Or something I need to do.
- Custom Front Motor Mount for H22!!!!
- Major Electrical Problem - Motor cuts out
- Axle Question
- need help about key ignition
- Can OEM wheels re-surfaced?
- 96' Prelude VTEC Audio/ Speaker Question?
- Forget H23 VTEC... try H24Vtec from OEM Parts...
- 93 prelude idea's
- does anyone have pics of 5th gen type sh rims on a 4th gen
- Blown Head Gasket, maybe?
- 92 prelude transmission
- vacuum line jdm/usdm question
- Check Engine
- 97 Prelude VTEC rpm engage
- Power Steering Pump Replacement - Whole or just bearings?
- i need help with a question about my h22 build
- A question of timing (service check connector) h22a
- 92 prelude f20a4 auto wont start
- Nub Question
- cold start issue
- Please help: Torque specs ESP traction bar setup
- solenoid question
- wiring external harness for internal coil dizzy
- resistor box/injector/OBD I/II questions...
- How Long without power steering?
- Stock Rim Weight?
- Crank Pulley problem almost corrected
- Prelude bottoming OUT on every lil bump!
- question 4WS on 1992 HONDA PRELUDE SI ALB/SR
- knock sensor on my H-22
- h22 all motor build!
- Misfired Cylinders...I Need Help Fixing It
- MSD Ignition Coil
- need help on how to remove fuel tank 93 prelude...
- Prelude BB4 With Ep Typer r, DC5 and SI 08 Rings
- Brakes Are Sticking
- Clunking when driving, goes away when i press in the clutch...
- hazard/blinker fuse blowing after i installed side markers
- H22 top end build
- Lude is stuck in gear
- Tri-Y Header Removal...
- Rotors
- turn signals and hazards not working
- 91 prelude si engine swap question
- 4th gen suspension question
- Good place for an oil pressure sensor?
- Weird noise when driving slow (1st gear)
- Help diagnose this problem
- starter from 98 accord fit on h23 tranny
- wire tuck question
- 5th gen with obd1 jdm distributor: timing?
- Prelude SH Key Question
- Compression figures in psi
- compression numbers for my jdm h22a..is this good?
- rattles?
- MAJOR Oil leak..help
- picture of 98 im
- blower diverter not functioning...
- JDM H22 head
- Car / Steering Wheel Shaking??
- Brake lockup
- help!! car not starting
- power steering question
- while doing an engine swap
- Prelude Si?
- P0300 P0301 P0303 cylinder misfire HELP!!!!!
- What is a factory spoiler worth?
- Leaking flex pipe fix.
- Funny ass prelude video
- 1994 jdm H22 EMISSIONS HELP! details inside
- 01' SH Upper Control Arm Camber
- Odd electrical problem. TPS voltage
- can i use f22a bracket
- h22a jdm swap issue misfire and knock censor. HELP
- h22a power steering bracket
- Type s LSD tranny
- 01 prelude sh new ecu
- What do the H22a Fidanza flywheel marks mean?
- high flow cat--no O2 sensor hole
- Looking for help..
- need a site for oem parts!
- my 95 prelude
- H23 Crank Walk Possible?
- Exedy stg I - how much torque does it handle?
- h23 turbo with a/c
- Hi-Flow Cat Advice
- DC Header Install Problem
- Quick egr port question...
- f22 engine harness wire up for vtec
- Fidanza flywheel ring gear issue
- H22A dizzy question
- Help
- Prelude BB4 "215 WHP & 161 WTQ Dynojet Build up, Track Time And More
- NEED HELP ASAP
- climate control knobs...?
- how to test coils
- Can someone take a pic for me....Please
- Clutch Problems, Any Thoughts?
- why do my seals keep blowing out?
- lip kit
- 2001 prelude sh ecu question
- Your input on Bisimoto cams for a H22
- Prelude 99 Sh issues
- Greddy fuel ctrl unit in 4th gen?
