View Full Version : Honda Prelude
- 92 prelude battery charging issue
- help plz
- Piston 2 rod bearings... wore very weird
- 94 honda prelude 4ws reset
- Procedure for re-oiling auto tensioner
- Turbo questions
- 1992 Prelude F22A1 Surging Idle
- Headers
- Kaizenspeed walk stopper work with balance shaft belt
- K series coils
- Timing belt walking off tensioner idler pulley
- What engine do I have? And why is timing belt different length?
- Obx header or??
- I need help!!!!!!!
- Looking to gain a little power in my h22a4
- H22 starts and immediately dies, need help fast, any input appreciated
- will h23a vtec bluetop injectors work with a 2001 stock obd2 ecu?
- Fans won't turn on
- 2001 Prelude Proper Build
- New T-belt, How does my timing look? PICS
- 93 honda prelude wont stay running
- Frankenstein
- broken axle? help please.
- help! my old jdm h22a timing belt has 117 teeth. what do I do?
- Built na h22a with aem injector help
- Need help figuring out compatible parts.
- Can I run a map sensor from a b18b on my h22a engine?
- 93 prelude clutch problems
- 99 prelude
- prelude with h23 vtec timing off 4 degrees causing smog fail
- Honda prelude sh supercharger engine management choice
- 92-96 MK4 F22B2 Prelude Diagnostics
- Any help will be appreciated
- help and suggestions. honda prelude 98 sh
- Never seen this idle problem before.
- Need help please valve seal problem
- 97 h22a4 base prelude manual ECU issues plz help
- Check Engine Light on after Head and Valve Job
- Si 4WS Rack & Pinion Replacement?
- Jdm F20B DOHC VTEC
- Can you pull a tune from a Chipped P28 with Hondata s300?
- New prelude owner with a question
- 2001 honda prelude cel disappears
- 5th gen trans sensors affected by wreck?
- 99 prelude
- 3rd gen prelude rear decals ?
- 1989 JDM Prelude RHD 4WS
- 1988 honda prelude 2.0 si 4wheel steering.
- New Engine
- H22 transmission bolt stripped
- Need help with 92 prelude head light assembly clearance.
- just curious on oil pressure.
- Will an SH ECU harness fit in my Base model Prelude?
- Idle issues
- H23a3. ... Desperate for answers
- Very touchy throttle and idle issues
- G23 Build Help!!!
- h23 swap
- h22a4 swap with h23 SI r
- H23a vtec bluetop swap timing and smog problem please help
- 88' prelude si...buy it?? [bought]
- BC BR coilovers spring rates?
- My Prelude has hard starting issue
- Considering buying a 1998 prelude.
- five speed swap donor car
- H22a1 to h22a swap?
- Engine type? Base model 94 Prelude - S
- Car title question
- Prelude H22a4 to h22a or h23a swap crank angle sensor
- Custom RMF Header??
- Build ideas?
- whats the biggest bore i can go on my H22a block???
- where is this FAQ (lost/gone)?
- I press the clutch and the car stalls
- Car won't start! Need help uninstalling "Kill Switch" from 4th Gen
- flywheel bolts came loose
- Help, Power Locks stopped working!
- Misfire and Backfire
- H22 won't go past 5k rpm?? Help
- 5th gen Fog lights
- IACV unplugged and no code, 01' SH
- Oil Leak of Death
- Honda prelude
- ID725cc injectors on h22 install?
- h22 inlet manifold options other than skunk2?
- 01' SH M/T cold start idle issues
- Crank and no start, 5th gen bb6. Please help
- h22a4 turbo
- H22A4 Build up!!! NEED HELP ASAP!!!
- 92 prelude si with h22a4 ecu & harness question
- Neverending Misfire on Cyl 2. please help
- H23a Blue top vs H22a4
- 5th Gen Restarts While Driving
- Who is building solid H motors these days?
- Wiper linkage worn?
- which distributor for easy obd1 conversion
- Looking for input on where to buy a motor (h22a)
- m2s4 transmission help
- Help 98 Prelude With Yonaka 2.5" Exhaust Too Loud
- eeeeeeeeeek neeeed help
- F20B DOHC VTEC to F20A SOHC block
- Wich motor??
- 1993 Prelude Si flooding after cleaning intake
- Bad Temp Sensor or Something else???
- do i need anything
- Honda prelude automatic transmission to manual
- Someone spray painted my Prelude
- I want headlight HID retrofit service in Los Angeles for a 1998 Honda Prelude
- 93 prelude turning right on its own
- p1399 and p0301 p0302
- H22a4 intake manifold issues
- Radiator question
- 92 96 Prelude F22B Erratic Idle & Idle Drop FIX Confirmed
- Whats manual transmissions fit the prelude?
- Radius Rod
- H22a to H23a swap 99 prelude base coupe
- i have a crashed BB1 \ H22A1 whats a good swap
- stalling
- 2001 prelude with a f20b
- H22 Engine Harness Works or not? (Wiring gurus?)
- Fuel rail banjo bolt size
- Transmission stud casing broken off
- H23A1 issue
- Help what should I do about my ecu??
- engine stalls out once it warms up plus knocks
- 1988 Prelude ball joint bolt/thread/nut question
- 01' SH oil leak
- my Prelude won't start (please help me)
- 1996 prelude ABS light staying on
- Advan Carbon fiber Hood Doesn't fit Right
- 92 prelude with a h22a vtec 5 speed
- car goes into gear but wont move
- *HELP* 96' VTEC - replaced 2 injectors and it's running on 2 cylinders?
- I need help
- h22a problems need help asap PLEASE
- H22a NO SPARK NEED HELP!
- Is my Ecu Bad?
- Difference Between
- Lighter faster sunroof plugs
- H22a leaking water
- Name that header!
- starter wont stop spinning
- 92 SI with H22 problems
- h22 vs h23 headgasket? -kind of complicated inside!
- 98 Sh motor and 00 Sh motor difference?
- H22A Oil Pressure
- H22a teardown disappointing findings, what to do..
- H22 injectors
- K20 intake on h22
- Replacing Type SH with Base motor
- best bang for your buck 4th gen suspension mod
- 5th Gen Prelude Help Requested in Irvine
- H22a4 main studs
- h22 problems, help a noob out
- what relay is this ive searched!!
- 93 prelude leaking water
- What is this horrible clicking? Type SH
- 1990 rough idle start up
- I need help with this problem, Idle problem.
- How to choose between going n/a or boost.
- Bulgarian beauty H22A5 tuned to 200+hp with some rare parts
- Parts differences?
- Speedo Issues
- H22 W/ F23 Trans Help
- How much is a bb8 worth?
- Honda Prelude BB9, O2 wiring at C212 conn
- h22a1 issue
- Rattle Sound From Top Of Block
- 92 prelude oil everywhere
- Confused on ECU Wire Harness
- 93 prelude jdm h22a swap issues need help!
- jdm h22a euro r swap into 1998 honda prelude type sh
- h22 injector question
- Need Some bluetop swap help
- European Honda Prelude 98 5th gen
- upper control arms
- NPR Pistons in stock H (FRM) Block
- 2001 prelude. what type of suspension do you suggest?
- 92 Prelude/ Last and final issue.... i hope
- Removing IAB butterfly spindle/rod?
- H22A4 in '93 Prelude, Balancer now rubbing chassis
- 4th gen prelude
- prelude torque specs transmission
- Prelude Clutch Replacement & Release bearing Noise
- It feels good to own a Honda again.....
- Vtec misfires
- 93 lude si aws: 5spd/h22 swap... no fuel... wtf?
- Check Engine Light on, but No Symptoms
- boosted: intercoolers and piping
- Integrated Control Unit (ICU) 92
- Finally getting the Lude back
- HELP! How far can I bore an FRM H23a1 Sleeve.
- 93 honda prelude
- 93 honda prelude camshaft
- Could this backed out bolt be the reason for my low oil pressure...
- VSS problem help
- 1997 Honda prelude parts.
- Looking for Black 1999 Prelude
- Honda Prelude 92-96 f22b no spark
- front turn signal doesn't work sometimes
- Front upper ball joint replacement
- Help! Broken lug nut on wheel!
- 98 prelude wont star
- Semi Automatic Transmission with H22/F22 engine
- 01 prelude intercooler questions
- JDM h22 vs. USDM h22 oil pump
- 1997 with New Battery, New Starter, Not Over Heating and NOT STARTING (Argg)
- USDM NON VTEC H23A1 TO JDM VTEC H23A - HELP
- Coolant lose/dripping
- h23a1 can i run 300cc injectors stock h23
- Having Trouble after swaping JDM H22A IN 92 PRELUDE WONT START
- Possible stuck front brake caliper?
- Power to wires, but no hazards?
- 99 Prelude not starting
- Need a new axle and half shaft
- 95 Prelude Vtech Instrument Cluster Problem
- Valve clearance adjustments procedure question
- Best exhaust setup for f20a4
- f20b gt35r ball bearing turbo. need advice
- '99 Prelude Base Automatic - tranny finally went out
- P0420 code
- Question about fans
- Need advice for starter replacement asap
- Fuel Rail question
- Problem Prelude JDM H22A SWAP
- H22 pistons and rods
- 92 prelude questions
- H22 Valve Adjustment Video
- Power loss while driving
- h22 oil pan
- s2000 third gear in h22 trans
- Electrical problem help please
- h23a1 cant tell if its rod knock
- 87 2.0 SI Auto , Idle/Surge/Shake Issue
- high-volume oil pump
- good driveshafts?
- Help me read ABS light code on this video.
- New to the Tuner World
- 93 prelude h22a will not start at operating temp
- aftermarket temp gauge
- Dead lude need help please
- Mystery Coolant Loss
- Looking at a local 1999 and very interested.. Stuff to keep my eyes on?
- Need advice or the right tool
- jdm h22 p2t4 non lsd transmission fit h22a1?
- DIY Valve Adjustment
- No power to injectors
