View Full Version : Honda Prelude
- BB6 window visors
- radiator hose for half-sized radiator
- Got a Problem
- Seats and Steering Wheel
- stiff shift (auto)
- foglight writeup??? (searched)
- HELP! Frustrated.. Under dash Wirings hurting my neck.
- H22A1 and H22A4 Oil pan
- I need someone to do some tuning
- Retrofitting JDM 1 Piece Headlights for the 4th gen? *searched*
- h22a4 rod journal diameter?
- JDM headlights and HID's
- What is the brand of the OEM gaskets (head, valve cover etc)?
- Knock off Mugen MZ3x or something similar
- Heater wont work!?
- sputters on vtec
- Infinite Baffle 2 10's 4th gen
- spark plugs configuration
- 98 lude SH shift linkage problem?
- broken bolt how bad is this?
- Is it just me?
- 4th gen radiator support replacement.
- CV Joint problems already...
- readiness problems
- fuel problem?
- White exhaust?
- Shift Boot Modification with Skunk 2 Shift Knob/4bidden
- how do you reset the ECU
- 98 Prelude Auto (SS) won't shift from 1st to 2nd
- 5th Gen auto-5spd swap??? what do I need/ bad idea/good idea
- installed brake lines and now problem with pressure. help asap (searched)
- battery too small?
- what would be the best piston for h23
- So i found out i have an oil leak..
- Seafoam?
- H22 leaking brake fluid
- F20b head on a H22b?
- valve caps
- I just need some input/thoughts
- Accord (5spd) internals swaped into H series case????
- New radiator for 4th gen
- Forbidden short shifter review
- auto manual conversion ?s
- Best ECU for F22B?
- Squealing sound
- 85 si prelude engine swap ?
- tenzo r a/f ratio gauge
- Help on clutch! Insight please!
- reverse sleve exloded
- any drilling needed for asr sub frame brace
- how to remove rear bumper on 5th gen?
- Re: does the h22a v tec use a map sensor or an air flow meter
- Going to FIRE BOMB THIS FREAKIN CAR
- how to check for diagnostic code
- Bleeding brakes - I can't get air bubbles out of the Right side Front and Rear only?
- type s pistons in my h23
- does the h22a v tec use a map sensor or an air flow meter
- Clutch flywheel combo
- h22a Runs like bad
- C.A. BAR Legal Swap Question
- 96 overheating all the sudden
- Parting out my Totaled 94 VTEC lude
- who's boosting with stock internals?
- Will a M2b4 bolt up to a base 5th gen?
- Valve lash on H23
- Putting in a Zex Wet Kit soon. Couple Quesions
- Exhaust won't slide into place on the Cat
- BB4 FRONT center speaker? wtf?
- Question? Side Skirt
- Acura LS wheels on 97 lude
- sport steering wheels with Prelude compatible air bag?
- 99 honda prelude shifting problem please help...
- CV Axle keeps coming out!!!! PLEASE HELP
- Whats the Difference between H22a And H22a4
- h22 need help on what i should do next
- Fuel Efficiency Project, 97 auto
- Flywheel question
- radiator question
- vlave springs, jge,skunk2,crower,supertech
- Coolant Line Mod
- 5th/4th/3rd Gen LED tail lights
- Jun cam specs... can anyone confirm
- looking for a ecu for the fifth gen prelude
- so what exactly does the IACV do?
- Reasonable trade in value for my car
- Clutch/Acceleration Problems
- How to install HID's on my 4th gen?
- Timing Belt concerns. Honda giving me the run-around!?
- 98 prelude type sh motor swap
- Major Probelsms Please Help!!!
- Bearings
- JDM H22 swapped in now throwing CEL code 22
- 5-Speeders
- Front tow hook on a 5g prelude???
- Timing belt kit?
- My idea for a dual exhaust setup....
- KMS valve springs and retainers
- H23a1 Boost? has anyone done it and if it can be done succefully?
- airbags?
- engine missing 3 quarts of oil since the last time i changed it
- considering a gt3582r .63 a/r turbine
- cat-back system help!!!
- Sparco Springs? Anyone heard or seen them?
- little h22 help please
- EGR problem???
- valve clearance question...
- i think my timing is off
- FS h22 stuff and audio
- How about a little Halloween E-Beer for the Lude forum?
- 97-01 aftermarket motor mounts
- 97 jdm h22a into 97 lude - Help please
- 2000 Prelude drives terrible......
- any info on mahle pistons??
- h22 driver side engine mount bolt
- Are Brembo blanks better than OEM rotors?
- V-tech not engaging on 1997 prelude?
- Clutch problems
- JDM shift knob for 5th gen?
- crank pulley bolt
- Prelude won't start
- Air conditioning
- need engine help asap
- Scratchy/Rattle sound from under car 94 2.3
- Check engine light
- WTB: h22a4 crankshaft
- alternator going bad from missing ground?
- ihard shifting
- F22 Block with H23 Head Is it Possible and any Details or examples
- H22a Crankshaft sizes....Where does Type-S fall?
- Prelude carbon fiber interrior
- h23a1 turbo manifold?
- H22a4 Swap not performing...
- 4ws problem
- h22a timing belt problem
- removing the oem ruber brake lines... Need help asap!!!!
- 1990 si overheating
- Sidemarkers measurements?
- I need a write up for a/c
- Voltage Problems
- place that sells just a starter solenoid
- How come there arent any letters on my crankshaft?
- vtec solenoid
- msd window switch
- JDM lights peeling!!!!!!
- noob question: burnout
- still have CEL
- 97-01 jdm h22a obd2
- JDM H22A into '92 Lude SR
- I might in luck... h23a1 closed deck?
- Do H23a(Non-Vtec) Headers fit H22a(VTEC)
- Jdm h22a distributor
- H22 doesnt want to turn over!
- Need some advice from my fellow 'Luders...
- bottom end problems
- What springs is everyone using for 1" drop on 92-96 preludes
- 4th gen jdm headlight installation/convertion?
- does 92 parts fit on a 97 motor?
- is a auto to 5 speed swap hard?
- Big time problems
- 5th gen owners..where did you put your sattelite antenna?
- Compression Test
- driver side headlight (searched)
- What is the smallest size rims and tires that I can put on my 01 prelude sh
- Is is true that acetone is a good fuel additive?
- 92 gauge swap to EL display
- jdm h22a speed limited?
- Starts then turns off.
- EDM Preludes
- picture help
- code 43 and ecu blows fuses
- good luck
- Audio Help!
- Something we would all like to have... better steering feel
- what is the tq spec for arp head studs
- is there a different head gaskets for h22 with block guard
- please help me with my lude, I need it runnin asap
- building an h22
- fixin my h22
- I NEED HELP WITH MY LUDE
- Low enough to need camber kit?
- HELP!! broken t2w4
- Vtec wont engage after accidentaly hitting it before car warmed up
- 4th gear popping out, anyone know how to adjust shift linkage to fix this?
- Prelude taking Friendly Fire
- Shop recomendations
- Someone check my Sparkplugs
- 95 Prelude intake mani help
- changing console/dash light color?
- Centre beam, how important?
- $2500, is this a good price for the Prelude?
- 4th/5th gen hood props the same?
- FOR SALE: 2000 Honda Prelude
- 89 prelude b20a5, knocking
- Stock Feel Spring Rates
- The Official 5th Gen Prelude Picture Thread - No comments/Replies/Flaming
- The Official 4th Gen Prelude Picture Thread - No comments/Replies/Flaming
- Car died last night - coolant all over road + loss of power - any ideas?
- Solution to the Picture Thread
- Flywheel replacement
- JUN Header?
- true h23vtec or h22
- h23 swap h22
- Resistor Box? OBD2 DSM injectors on OBD1 H23
- overheating? not sure...
- Recommened ignition upgrade??
- Exedy Stage 1 or OE?
- Rod Bearing
- Corner Fog Lights
- The sound of Piston hitting valves
- 98 lude with idle problem
- motor mount play?
- YET ANOTHER HONDA-TECH SCAMMER!
- HOW TO: Remove that Annoying SRS Light - The correct way.
- Removing Balancer Shaft Bearings
- got spark, and no fuel, but here the fuel pump
- WTB 5th Gen Manual Swap
- Removing back seats
- Need help finding!
- Stock Filter Sensors for 5th gen
- vtec not engaging, cant figure out the problem H22a
- Water temp, fuel gauge not working
- possible fuel problem?
- Power Steering Removal Question
- good deal?
- Check Engine ATTS Light
- Dsm injectors in 5th gen prelude
- JDM lights
- Question about P28 ECU w/ Hondata S300
- Apexi Vtec controller (4th gen)
- debating between exhaust (4th Gen)
- Help with Picture Thread
- Upgrading grounds
- 3" exhuast and na for a couple months
- Just wanted to make sure.......
- Moving Fuel Filter
- bumper clips
- f22/h22
- Wierd Smell?
- h22 trans needed
- H23a w/ type s piston...?
- which wire for air fuel gauge?
- h22 gurus: PLEASE HELP!!!!
- 97-01 DC Sports Headers Difference between Base & SH?
- idoling question?
- JDM Foglights, Installation?
- stock 5th gen (dyno results)
- timing belt replacement? Hard or not? 01 Prelude
- check engine light on
- Oil leak, need help
- Burning Oil..???
