PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Thinking about removing the balance shaft
  2. opinions on what to do for inspection sticker!
  3. h22a4 replace h23a
  4. need some advice on mods for my car!
  5. Prelude shift points changed suddenly?
  6. 97 prelude H22A4 vtec wont work ?
  7. 97 ecu questions?
  8. Is this the sign of bad oil pressure
  9. F20A4 Valve clearance
  10. 00 Prelude. EGR engine light code. Help please...
  11. Changing wheel bearings. Question about the hub
  12. Strong smell of gas from exhaust. Help!
  13. P13 ecu? wich one?
  14. Help with noise from Motor??
  15. High Pressure Power Steering Hose
  16. Function Form Coilovers
  17. camber kit with no instructions...
  18. looking at a prelude. help!!!
  19. I have 93 prelude it wont spark
  20. Clutch Question
  21. Anybody have Sweet Tow hooks on there 4th Gen???
  22. h23 to jdm h22 need help.
  23. im planning to do a swap?
  24. ATTS light on after tranny swap
  25. turbo kits
  26. Haynes manual?
  27. Rear Tie Bar Question.
  28. Ecu
  29. what oil to use?
  30. dsm?
  31. will h22a head gasket work on h22a4 block?
  32. 1987 honda prelude 2.0 si sohc
  33. Cylinder Head Rebuilt??
  34. Wheel Theft in MD...
  35. "BRAKE" light turning on when ABS engages
  36. My 94 prelude
  37. My 94 prelude
  38. My 94 prelude
  39. Cheap WINTER OiL swithing back to conventional
  40. Need help asap about h22 and frm material
  41. Tire Question
  42. scraping bad...
  43. can a type s trans fit into a 97 base model preldue?
  44. 94 VTEC H22A running rough suddenly
  45. can s typer trans fit in base model?
  46. Track time
  47. Vibrating noise
  48. windshield wiper fluid motor?
  49. 88 SI rev's up to 3,000 and the rev limiter kicks in.
  50. Ball joint removal
  51. Starter Problem?
  52. REar Wiper>>where can they be found
  53. Sigh:: Help finding this spoiler?
  54. Supercharger
  55. Torque wrench specs for h22 motor
  56. 90 prelude 2.1 si 4ws coolant system
  57. 5th gen will not idle! I've searched.
  58. washer fluid lines
  59. 5th gen Prelude 2.0i mainteinance questions...bunch of
  60. Door Lock Replacement?
  61. H22 transmission question
  62. Lightweight valve keepers
  63. h23 swap question???
  64. kyb agx adjustment question
  65. Need help, ideas and suggestions
  66. Tuning
  67. h22 idle problems
  68. need help, jdm h22a swap.
  69. VSS Problem
  70. brian crower cams vs skunk2 pros
  71. Clutch Problem
  72. p5m ecu question
  73. Will these wheels fit my BB6
  74. Check engine light
  75. My H22 build isn't running right. Also confirm my dist. to plug routing...
  76. Car wont crank after battery change
  77. Time for H22
  78. idle and timimg problem help!!!!!
  79. 4gen speed sensor location
  80. S2 Intake Manifold question
  81. Manual Advice
  82. jdm obd1 engine harness
  83. starting air valve
  84. Crankshaft Pulley Bolt access problem...
  85. can i change this hub to a thinner one?
  86. Can you raise the compression on a Auto h22a4
  87. 98 piston ring replacement
  88. How many time's a day do you hit VTEC
  89. 98 prelude auto transmission can't go into park
  90. Tested My JDM Prelude with G-tech Pro RR
  91. Rims/Tires Question.
  92. What ECU?
  93. Vibrations when clutch pedal depressed
  94. h23 engine mount pics
  95. idle high untill i come to a complete stop....
  96. My girl is shaking her stuff, and not the good kind.
  97. Tire sizes for 17x8 on 5th gen
  98. GEARBOX on H23
  99. need some help
  100. H22 euro-r
  101. will 97 front clip fit 92 lude...new to ludes
  102. question on spc adjustable ball joint.
  103. Do I need this? if so how do i get rid of it?
  104. I/h/e?
  105. High beam/DRL problem
  106. is my tps broken?
  107. engine surging after i clean throttle body..any ideas?
  108. anyone boost a h22 with a 16g turbo?
  109. How many preludes do you have?
  110. Question Regarding Throttle Position Sensor (TPS)
  111. light problems
  112. fuel pressure question
  113. h23a1 engine mods
  114. Car is winter stored. Whats minimum CCA(?) Battery I could use?
  115. F'ed up balance shaft
  116. idle problem, tried everything
  117. How's the fitment on the 94-95 accord lip?
  118. f23/h22 help
  119. Loud Squeek during cold starts
  120. correct ecu for h23a jdm vtec
  121. is it possible to not sleeve my block?
  122. Headstuds
  123. Skunk2 cams ?
  124. 15 x 8's 4x114.3 choices.
  125. What Fuel pressure Regulator for h23 vtec?
  126. BOV and Wastegate Vacuum lines
  127. HID retrofit
  128. Common coolant leaks
  129. cheap exhaust
  130. Baffled oil pans
  131. 4ws and abs removal
  132. Ok.....
  133. took door panel off, now power lock is funny
  134. Need Opinion On A Lude
  135. what axel for h22 in 92 prelude
  136. where to find good forged valves set for 92 prelude H23
  137. 1990 - Interior fan only runs on '4'.
  138. 2000 Prelude Intake Manifold?
  139. swapping throttle cable holder w/e its called.
  140. Front engine mount
  141. Need help enabling srs
  142. Door will unlock but not open
  143. Engine swap for 4th gen... 96 not included?
  144. SAFE Mode & Check Engine code nr. 4
  145. problm, need some help
  146. h22 rocker pad ware
  147. so thers a click under load
  148. h22 vs h23 valve springs
  149. TB questions jdm h22 and h23 usdm.
  150. How to aim/adjust 5th gen headlights?
  151. Abs light
  152. distributor
  153. Swap? Read!!!!!
  154. Whats a better engine: H22a or h23a vtec?
  155. Positives Vs. Negatives of Wider Tire.
  156. Possible clutch failure?
  157. purchasing your jdm h22a
  158. some parts for sale
  159. h23a1 pistons in a h22a block ?
  160. running lights not working
  161. jdm p13
  162. this soft brake pedal is driving me nuts-- i need help...
  163. Tell me what a 91' is worth?
  164. DC header question !!!???
  165. 99 prelude puts at idle any ideas
  166. Offcial emissions failure thread!!(h22a)
  167. spark plugs
  168. Going build H22
  169. valvetrain.....
  170. prelude swap need help!!!!
  171. 97 H22 prelude RETARDED CAM TIMING ??
  172. Search problems!!
  173. need help changing lights
  174. H22a4 Burning oil
  175. 95 prelude question
  176. Still Stumped - Need help
  177. H22A block, H22A4 Head w/A4 head gasket.
  178. h24 87-89mm oil in rad
  179. i need some advice
  180. Need Help Please
  181. how can you tell if your h22 is a type S?
  182. H22 Head Milled/Skunk2 Pro 1 Cams - Clearance
  183. coilover ?
  184. Rod knock at engine start but goes away in a sec
  185. Does bad VSS = less MPG
  186. oil pressure problem
  187. throttle rotor
  188. h23 fuel pressure
  189. O.E. block # on 89' Prelude, 2.0S, NEED SOME INFO PLEASE!!!!
  190. no spark or pulse
  191. The Rice Award
  192. H22A4 Block Difference
  193. vtec engage but redline at 6500.
  194. Easy Suspension question...92-96 vs 98 struts.
  195. building my h23a1!
  196. is the P0J ECU plug and play deal with a 5th gen lude>
  197. surging idle i tried it all!! 98 prelude hekp! going crazy
  198. H22 axle 1/4 inch axle play (in & out) ?
  199. 2.25" Front & Rear drop 2 low?
  200. swaped motor now clutch pedal is stuck on the floor
  201. High Pressure Power Steering Hose
  202. Type-S Pistons
  203. f22 frm or not
  204. h22a vtec engage
  205. wheel size
  206. H22A4 timing belt sliding off
  207. lips?
  208. HEATER QUESTION
  209. 4th gen rear brake pad
  210. Anyone ever powder coat shocks?
  211. car dies when steering
  212. Need help! Car starts then immediately dying.
  213. I NEED HELP!!!
  214. how do i convert external to internal coil??
  215. Do i have to remove both halfshafts
  216. How to get started??????
  217. how hard is it?(prelude SE center caps)
  218. PS leak...Huge Puddle
  219. Why wont my car STAY 'started'
  220. 5TH GEN PRELUDE TRANSMISSION SWAP
  221. dsm injector question?
  222. bent valves on a f22b
  223. obd2 engine harness to obd1? (searched)
  224. Clunking sound.
  225. did an engine swap, now engine having problem running
  226. what is this?
  227. H23 Tranny Stuck in Gear
  228. quick question about 5th gen prelude rack and pinion
  229. 4th gen brake swap: How To
  230. Compression numbers for Type-S bottom end???
  231. Salvage Title
  232. Runs Rough No Code
  233. Does a malfunctioning secondary O2 sensor affect performance?
  234. need help asap!!!
  235. Bolt sizes.
  236. Weak hand brake
  237. H23 IM in an F22
  238. mm on 91 prelude TB??
  239. hand brake light
  240. h22/h22a4 headgasket
  241. So what goes bad when...
  242. exhaust spitting oil/transmission issue?
  243. What are these called.
  244. accord tranny
  245. CF hood search
  246. Project prelude
  247. help my friends trans in his 93 prelude went out
  248. transmission code question?
  249. Cold Crank Problem
  250. Hi there!
