PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 [121] 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. tires worn. camber or toe
  2. AFR question on a H23
  3. arAuto shift problems
  4. possibly rings?
  5. JDM Type S Lip Part Number WANTED
  6. jdm p13 ecu
  7. has anyone tried using the passwordjdm intake on their h22??
  8. How do you check if the motor mounts are bad?
  9. HELP......................Brand new............
  10. JDM headlights....
  11. Ignition switch problem?
  12. blower motor relay
  13. Flywheel pin broken, what to do?
  14. ***the official prelude supercharger thread**
  15. engine swap
  16. alittle bit of help guys
  17. turbo lude???
  18. Help Installing external fuel pump
  19. "Headlights-on" Bell not working
  20. 5G Trans Problem
  21. Brake question
  22. Crazy tach, spark cutting out, car turning off
  23. Half core radiator?
  24. Stage 1 cams, profile size
  25. DC or Type S Headers
  26. 2001 Prelude rear suspension making thumping noise over bumps.
  27. Coolant Overflow Reservoir. Relocated battery. Now what? 4th gen.
  28. Headers High-Flow cat and exhaust
  29. Code 8, Top Dead Center Sensor???
  30. Wheel Help
  31. Honda Challenge National Championship race report & pictures.
  32. h22 block h23 oil pump
  33. fuel issue
  34. ECU Q's!
  35. Timing Belt issues
  36. Kamikaze Header?
  37. valve springs
  38. not sure my iab's are opening
  39. H22 isn't so enjoyable hot...
  40. H22A Timing
  41. PGM-FI Main Relay
  42. Odd Low RPM Startup Problem....H22a
  43. Need some help with a BB6...
  44. h23 wireharness on h22 engine p13ecu
  45. 96 prelude si. jdm h22 swap
  46. how EXACTLY does VTEC work???
  47. Energy Suspension Kit
  48. is this the right spring rates for me?
  49. How-To: 95-96 Center console hazard button rewire
  50. Brake light???
  51. Transmission Q....Shift Arm Lock Bolt Removal
  52. Camber Kit
  53. Broken Clutch Master Cylinder?
  54. Low RPM knock (almost stall RPM)
  55. CEL from egr on skunk2 manifold h22
  56. Are H22's open or close deck?
  57. Civic condenser in prelude
  58. Need help understanding this carfax
  59. HELP!!!!!!! h22a1 in 94 SI i have probs
  60. 92 prelude si with jdm h22a automatic
  61. Oil line setup questions.
  62. Will NSX brake rotor work on a 5th gen
  63. The use of traction bar (already searched)
  64. h22a4 fit in 96 prelude?
  65. Strait pipes.. well not exactly.
  66. nothing coming out of my vents. what controls which vents the air blows out??
  67. I hate those door ac vents
  68. Re-using Bearings..........
  69. yellow lens film/tint headlights?
  70. anyone have a p13 basemap?? cant find any that work
  71. h22 vtech not working all the time
  72. h22a vtech problem
  73. help! I think osaka stuck me! the new engine ID code has been grinded off! H23vtec or F20b?
  74. check engine light
  75. my prelude has been run on regular octane fuel for the past 2 years
  76. knocking sound right after starting engine, but then goes away??
  77. Reassembling suspension (searching with no luck)
  78. Is my 5th gen running to hot???
  79. megan exhaust for 4th gen SI
  80. question for SMSP and/or RMF
  81. Just installed an SMSP Header, Question about Tuining
  82. building a head....
  83. brakes squealing, only 2000 miles old
  84. where to get a tune?
  85. Need Help with electrical problems
  86. Insight on the Prelude...
  87. h22a running lean
  88. Removing the Supplemental Restraint System (SRS). How to deal with the light.
  89. H23 AT Hesitation/Smoke *Searched*
  90. Before I hit the road
  91. GC and Koni combo...tophats ?
  92. Transmission line??? (I know, you probably think im annoying)
  93. Knock Sensor...what size socket??
  94. Safe To Use?
  95. Quick question
  96. 17"x7.5" Wheel Size on a 5th gen?
  97. pic request on Heater Hoses on the Firewall for 94 Lude
  98. 4th and 5th Gen 4-1 race header...
  99. Knocking badly
  100. my A/C problem ??
  101. Blue or Black meshies? And is this a good lowering kit.
  102. brake adjustment after rear break install?
  103. what coilovers to get?
  104. Is this a real megan racing header?
  105. 93 prelude FLOOD problem
  106. new pads/rotors do i need to bleed?
  107. 95 Jdm h22a accord with p13 Erratic idle, IAC valve problems?
  108. help a brotha out with iacv
  109. Finishe Type-S swap...few Qs
  110. anyone got a hondata s100 or s200 i can use for a few days?
  111. What motors will swap into a 89 prelude?
  112. 89 prelude back fireing and sputtering like crazy
  113. Clutch chatter/Clutch problem???
  114. H22 Exhaust Manifold gasket
  115. 4th gen linkage
  116. Fast Clicking noise when breaking....
  117. AC Pressure Switch
  118. Where to put tranny fluid H22
  119. HELP! my VTEC doesn't work
  120. Srs, search and read everything
  121. Skunk Instake manifold install (searched)
  122. Traction Control Unit
  123. hks carbon-ti cat-back exhaust?
  124. Cam lobe worn and rocker worn bad.. JUN cams.. any clues? (Exhaust mid #1)
  125. Rebuilding a b21?
  126. synchronizer...?
  127. installed mfactory FD (4.64) w/ si 5th gear on an m2f4
  128. New O2 didnt fixe CEL 1 , now what ?
  129. Well.. Shit.. Turbo = no? yes? *picture of problem*
  130. About Root79
  131. carbon fiber sparkplug cover?
  132. obd2 h22 into 93 prelude
  133. Can I remove a fan on the radiator?
  134. H22A4 Block Help
  135. need to know size of stock h22 exhaust pipe?
  136. AEM Fuel Rail Question (searched already)
  137. Coolant ?
  138. LCA's for BB2. does anyone make them?
  139. New Clutch and so many to pick from ?
  140. Squeaky Wheel?
  141. *** john_d *** is a scammer!!!!!
  142. h22 grinding gears at redline
  143. turbo prep
  144. painting wheels
  145. 98 Honda Prelude -Base- Question
  146. Honda pins for wiring Vtec
  147. complete h22a motor in an Si?
  148. my JRSC ordeal!
  149. HELP, Fluidyne problem...
  150. Distributor options for Prelude H22
  151. 85 Prelude TPS
  152. HOW TO: Make your own STRUT BAR: DUCE CO.
  153. whos car is this? and whats their tire size?
  154. F22a - Vtec Head
  155. White smoke on my Prelude 1995
  156. Check engine light after msd ss coil install
  157. CEL, Searched-EGR & Fast Idle
  158. eibach pro-spacers
  159. wtb-one headlight
  160. Chipped OBD1 PO6 for H22a4 in a 92 Prelude Si 4ws
  161. 1997 prelude questions
  162. Why All the Frankin'engines?
  163. turbo manifold
  164. IAB Butterflies question?
  165. EGR block off plate
  166. EGR Issues, Running out of options
  167. Carbon midwing/Duckbill for 4th gen ludes?
  168. B20A related to other B-series?
  169. Type-S Valve Adjustment
  170. SCREECHING noise on start. H23A
  171. prelude bb2 suspsension Q's : (camber kit) for H&R ON toE-kico HP's
  172. HELP! CEL P1259 - VTEC System Malfunction
  173. code 45 problem?
  174. H23 port and polish
  175. BB1 BB2 BB3 BB4 ? Can some one explain what these mean exactly.
  176. What octane Gas u running in your Ludes ?
  177. 4bidden short shifter 5th GEN
  178. Anyone know the stock front sway bar size for S & SI?
  179. whats this? engage clutch and it leaks!!!
  180. tranny problems, pops out of 3rd and clicking... :(
  181. Cant fugure out how to change my front headlight low beam bulbs....
  182. f and h tranny. need help
  183. what just happened
  184. Custom Wheels!!!????
  185. vtec controller install
  186. WHAT trans in all motor Lude ?
  187. air conditiong problem please help 96 vtec prelude !!??
  188. Why am I on 10 post limit? What happened to my posts?
  189. will 93 h23 headers fit my h22a1??
  190. What's the CARB number on your DC Header?
  191. B in the H??
  192. noise on start up
  193. main relay vibrating, no fuel pump prime, no start
  194. solenoid?
  195. h23 and h22 intermediate shaft
  196. Rear Wheel Squeak (Bearing)
  197. H22a tranny M2B4
  198. P13 OBD2 indentification
  199. TRANNY SWAP!! need advice asap!!
  200. Not sure which NGK Spark Plugs to pick up for my 97
  201. 97 prelude clutch
  202. turbo lude wont run right after fueling up!
  203. h22 SH head vs H22a head?
  204. crank pulley went on vacation
  205. h22a4 - type S pistons - need type s head??
  206. Vtec not workign after cams are in
  207. ACCORD/PRELUDE Transmission Compatiabilty????
  208. for Steering wheel owners and had ot take out the cabel reel
  209. balancer shaft belt install
  210. Refilling AC
  211. TB and Manifold Bore but to wut specs
  212. Tach bouncing...need serious help
  213. 5 Gear Grind
  214. Alternator belt to tight?
  215. V-Tec controller settings???
  216. Gauge pods for my 92 lude!
  217. what is this???
  218. heater door (searched)
  219. AC not working correctly
  220. m2y4?
  221. i searched!! h22a4 w/f22 crank and rods? is this possible
  222. need help: vafc2 problem and problem with a local norcal shop
  223. throttle body trouble after crower stage2 camshaft install?
  224. F22B H23?
  225. AC question
  226. 1993-96 Prelude VTEC Peak and hold 345cc (can anyone verify this item #)?
  227. h23 tranny to an h22 block
  228. ok i searched for hours and hours please help
  229. 01 prelude SH tranny question
  230. f22b1 in a lude?
  231. OEM CD Player sometimes plays CD's "static-y"
  232. 1989 honda prelude si wont start just put $400 in new parts wtf is wrong
  233. Are the h22 and h23 slave cylinders the same??
  234. swap wait time
  235. What are these? (specific to my application)
  236. Possible Engine swaps into a third gen
  237. trying to build my motor need help
  238. Bringing lude overseas
  239. Need Prelude engine and wiring help!
  240. hit a pothole
  241. attarco
  242. How to upgrade your grounding system for cheap. (5 HP gain)
  243. decided to do the swap from AT to MT.....
  244. SRS light on (searched)
  245. which starter is this?
  246. BB6 front clip??
  247. anyone ever tried bar's products?
  248. Wiring harness Difficulty!!!
  249. help me pick a muffler!! want a dual tip
  250. 2.5in vs 3.0in exhaust on turbo lude??
