PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 [208] 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 3" DP
  2. H22A (next step)
  3. walbro installation and quick pricing Q about p5m
  4. will this be a camber problem???
  5. Weird noise.
  6. 97 prelude...extenal coil to internal coil....
  7. dule stage vtec ECU
  8. Dry Sump for preludes automatic 5spd tranny
  9. Prelude Tuning! Lets get deep on this one.....
  10. removing charcoal canister
  11. Power chip info needed on 93 lude
  12. power steering fluid
  13. 91 lude mods?
  14. build or buy.
  15. clutch noise ?? plz help !! only when hott Maybe ?? act clutch jun flywheel ??
  16. The heat of the Prelude..?#!
  17. RHD Progress and Help sourcing parts!
  18. Vin Inspection Help
  19. Too high of compression for boost?
  20. No Heat (winters gonna suck)
  21. ANyone have some reccomendations on racing seat harnesses (4 or 3 point)?
  22. Please help me ive got a check engine issue
  23. Prelude Headlights
  24. whats this sound?
  25. SOCAL Throttle body bore shop?
  26. Anyone know where I can find racing harnesses cheap in bergen county, NJ?
  27. Difference between a JDM p13 ecu and a USDM p13 ecu?
  28. Is there any interest in Jun cams+valvetrain ?
  29. generic coilovers
  30. +100 Hp turbo kit
  31. 300hp?
  32. IMMOBILIZERS???
  33. Take picture of your SPEEDO SENSOR Connector for me!!!!
  34. Coilover Install
  35. 4th gen fog lights
  36. Question regarding 5th gen Prelude and popularity
  37. How to remove VSS (vehicle speed sensor) JDM H22A manual
  38. HIDs
  39. HELP! Flywheel bolts stripped!!
  40. Bolt-in Roll bar
  41. cold weather and vtec pressure switch
  42. winter tires?
  43. JUN cam impressions
  44. 91 Prelude ECU code 9
  45. How do i remove COMPLETE Pedal Assembly?
  46. 92-93 EL Guages and difference from 94-96
  47. Where can i find (service check connector) on 92 lude?
  48. Oil burning problem!!!
  49. prelude's weight?
  50. runs terrible when first started up (question)
  51. distributor install
  52. 4ws sway bars ??
  53. your feeling on usdm fogs and cheapest prices u found online for them
  54. aftermarket clutches
  55. camber kit choices
  56. Bushings????
  57. motor mount inserts
  58. Flashing Oil Warning Light
  59. p13 ecu
  60. Clutch Prob
  61. b20a3 swap for b20a5?
  62. changing timing belt crankshaft pully bolt
  63. Vss jdm vtec
  64. Replacement Axles
  65. 94 dead dash problem
  66. where is the oil filter located??
  67. 5th gen wire harness question
  68. Wheel question...
  69. Engine Swap Advice Needed
  70. H23VTEC Build VS. H22A1 Build (yes I searched, no I didn't find what I want)
  71. Car is running stronger w/new mods!
  72. where does o2 sensor wire go to?
  73. p72 question
  74. gauge cluster or vss ?
  75. Where to get H22 longblock from?
  76. 5th G ss
  77. tuner shops in az
  78. sup. maybe a 5th gen owner soon.
  79. stock camber adjustment?
  80. Can AEM EMS be used on OBD-0
  81. ANYONE WHO HAS DONE H23 VTEC LOOK HERE
  82. my car back fires ?
  83. I NEED HELP WITH PRELUDE 89 PS PUMP
  84. tranny
  85. Engine Sputtering and O2 sensor question- h22
  86. 5th gen front bumper q
  87. H22A HEADER QUESTION?
  88. skunk 2 manifold in eg hatch
  89. Will I/H/E pass smog?
  90. cold weather and e-brake light?
  91. Mugen Exhaust Question
  92. Acura & Honda OEM Part Number Websites!!!!!!!
  93. STock or aftermarket alarm problems! help
  94. How much should I pay?
  95. H22A Intake Manifold studs / Hondata gasket / Problem
  96. ARP head stud Explanation Please!
  97. what car should i buy???
  98. Compression?
  99. Gains on porting H22A IM
  100. ECU/Hondata question
  101. what mileages 2 do Major Tune ups??
  102. AEM V2 INTAKE 95 LUDE AND RADAR LASER DETECTOR WHATS GOOD PASSPORT 8500 X50 ??
  103. backseat keys
  104. 93 prelude vtec tranny help!
  105. VTEC lower, most inner crankshaft pulley
  106. jdm sidemarker mounting and measurements, free beer!!
  107. Bracket that holds the swaybar broke. I have a track event this weekend!!!
  108. Anyone know what this is???
  109. How do you attach pics to your post???
  110. Rim wieght
  111. oil brand mixing
  112. Fuel Pressure Regulator? (solution?)
  113. Do I need a camber kit? *pics*
  114. Another EuroR IM install
  115. starting issues / strange sounds/ battery ok
  116. fuel rail
  117. 4th gen fog light housing
  118. NEW CLUTCH SLAVE-HELP?
  119. Removing PS from H22
  120. How Long Should It take...
  121. air fuel gauge not working properly?
  122. How much does those part cost...
  123. Is TPS specific to engine or will any Fuel Injected one work?
  124. Longevity of boosting on stock internals
  125. where did u guys get ur camber kits?
  126. interior latch...weird question...
  127. engine management for basic bolt-ons?
  128. Anyone seen these B4
  129. prelude dyno #s
  130. 97+ prelude cf OEM style hood - Washington DC
  131. Washington DC area Carbon Fiber hood sale
  132. civic seats in 5th gen lude?
  133. cel code 36
  134. removing p/s container
  135. H23 vtec DIY WATER PUMP walkthough (searched)
  136. prelude h23a resistor box same as 90-93 resistor box?
  137. h23 manual tensioner
  138. is the same crankshaft h23a1 and the h23a2 ?¿?
  139. 92-95 JDM cams or 2000 cams???
  140. tubo or no turbo for an H22A?
  141. Tyres
  142. need cat converter.
  143. Tein ALFiT oil filters
  144. Question on rim fitment for prelude
  145. loud knocking?
  146. strange noise/feeling... any help?
  147. CEL light on after new cat installed
  148. making h23 Vtec
  149. sevice manual in format pdf h23a2
  150. suspension and brakes for sale 92-96si (non-vtec)
  151. Going to be a classic?
  152. b21 flywheel?
  153. Is there some way to adjust the e-brake on a 5th gen?
  154. Lets see some interior pics
  155. 5th gear clunking / grinding
  156. quick question on the 5th gen
  157. 5 lug conversion- detailed question
  158. About that P2T4 transmission...
  159. H22A3 ( any info )
  160. New Car Decision and Potential
  161. want some opinions on doing the collector mod
  162. Auto transmission problems
  163. NepTune in control
  164. control arm question
  165. Question about dead spot in engine..
  166. Tein HA
  167. Installed VAFC2 in my 95 VTEC and car boggs and backfires, HELP?
  168. timing belt
  169. noise after oil change
  170. Fuse keeps blowing?
  171. cel codes
  172. short ram or cai ?
  173. h22a coolant bypass? pics inside...help!
  174. lights?
  175. Camber kit question on 5th Gen??
  176. Prelude Dizzy Question
  177. OBD1 or OBD2?
  178. engine rattle
  179. h23 exhaust manifold on h22 head
  180. Does your 5th make noise even when it's not on?
  181. skunk2 stage1 cams vs Type S cams
  182. 4th gen calipers, vtec same size as si????
  183. tanabe underbrace interchangable?
  184. Distributor making funny noise
  185. Skunk2 cam gear bolt interference?
  186. H23 non-vtec, H22, H23 vtec Turbo questions
  187. Prelude Transmission Question
  188. 4th Generation JDM RHD Dash Conversion??
  189. Where do you put your jack when jacking up your lude?
  190. How low is your car?
  191. dc header question
  192. Going to tackle my shock knock today
  193. I need lots of pics of VTEC engine bay
  194. timming belt S on prelude
  195. turbo 3rd genners
  196. Mugen Bumper
  197. Burn oil
  198. any other 2g owners on here?
  199. Code 7 (TPS?) and car dying after revving...
  200. What is this on my H23 5spd. TRANSMISSION?
  201. EMISSIONS REMOVAL
  202. 97 gauge cluster in 93
  203. Dent fixable?
  204. Interior Carbon Kit
  205. Looking for a little Brake Help with a 1991 Prelude
  206. Optima Red Top Battery
  207. 5th gen headlight foging?
  208. Dose the Prelude gear box have hypoid gears in it??
  209. Whicjh type of gear box oil???
  210. h22 venom intake manifold
  211. 93 Prelude Vtech smoking
  212. Needs Help on Camber Kit
  213. squealing noise
  214. Need advise ( just recieved my H22 swap )
  215. 90 B21A1 Free Wheeling?
  216. Tires...
  217. Braided Brake Lines
  218. I NEED BRAKES
  219. 92 Prelude, H23A, smoke at low throttle, bad rings?
  220. Prelude SH
  221. Apexi World Sport 2 Exhaust
  222. stock gauges brighter?
  223. Stock cams or Type S cams for turbo????
  224. Most NA whp without opening the block?
  225. Gauge Panel
  226. Hondata
  227. h22 retarding at 5k...help
  228. electrical problem
  229. timin belt parts
  230. is dry nitrous safe
  231. h22a transmission
  232. Type S Pistons
  233. stepping on clutch causes my rpm's to shoot up
  234. 94 2.2 sohc; is there gasket from header to downpipe?
  235. what is the cheapest way to correct my prelude's rear camber
  236. prelude engine bay pic-post
  237. Possible to swap 5th Gen Sunroof glass into a 4th Gen?
  238. JUN Pistons and Rods
  239. Speedbleeder Size 95 Prelude Vtec
  240. Honda Accord F20b best choice for automatic swap?
  241. Electrical problems?
  242. Difference between projector headlights and hid's??
  243. Resurfacing the HEAD
  244. 97 NSX Calipers on my 4th generation
  245. engines tickes pretty loud
  246. hub ring size on 92 prelude, arospeed wheels?
  247. prelude hesitation
  248. Mugen accessories for sell
  249. Crower Cams
  250. 84, 1.8, 12 valve tuning settings
