PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 [150] 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. will a skunk 2 throttle body fit on a EURO R manifold
  2. Rebuilding the 2.3 beast!
  3. wuts wrong,my lude keeps boggen?
  4. Megan header for $100 on ebay? real or not??
  5. h22a1 80 shot direct port???
  6. Help>interior fogging up
  7. Question about Prelude speaker system
  8. Swaping my stock H22A manifold for Type S one?
  9. performance question
  10. sleeve up h22a4
  11. euro r IACV adapter plate
  12. Vacumm hose diagram for H22A motor?
  13. 97 Prelude SH Turbo
  14. anyone ever wet sand their headights?
  15. '01 Prelude Mystery Leak
  16. Emergency- Please Help
  17. injectors for boosted h23a1?
  18. vtec problem
  19. Oaks Racing Prelude update
  20. 85 prelude leaking coolant. what part do i need to replace? many pics inside
  21. Help choose injectors for a N/A build H22
  22. 5th Gen Slanted exhausts?? Who makes them
  23. sputtering motor after MSD box install
  24. transmission question
  25. h22 in my ek, was running fine, now issues, clutch related? (posted for more views)
  26. F22 turbo help
  27. Need some pics of cams
  28. Somebody Finally did it...
  29. JDM Foglight help
  30. Where to buy OEM 5th gen floormats?
  31. Dash Lights - 1st Brake & Hand Brake, 2nd ABS, 3rd 4WS
  32. ATTS light coming on
  33. Any Damage To Motor??
  34. the discontinued blues
  35. Anybody thought about trying out 4.64 Final Drive?
  36. h22 downpipe question????
  37. Official Prelude soundclip Thread>
  38. Wheel Hop - need suggestions.
  39. Manual Tbelt conversion -does this look right?
  40. h22 timing belt slack at TDC?
  41. Suggest a good air filter...
  42. Adjusting Ground Controls
  43. Couple of Lude questions, mostly F20 VS H-series
  44. how to disable the rev limiter
  45. H3C to H3 conversion
  46. skunk 2 intake mainfold vs jdm port match and polished
  47. 2001 H22a Turbo Questions
  48. does HONDA make
  49. BUILDING MY NEW H22
  50. CEL + ATTS Light on Testdrive
  51. car is running really rich and dies when you let off the throtle
  52. Crack in cf lip
  53. H22a is puutting! Any ideas why?
  54. jdm h22 firing order!
  55. SMOG
  56. help w/ timing
  57. H22 JDM Type S Manifold?
  58. replacing fuel pump
  59. 4th gen prelude SE auto to manual swap... in socal
  60. s2000 steering wheel
  61. dyno sheet
  62. Help Prelude not Running Well
  63. will this size fit?
  64. manual tensioner install. problems. help
  65. engine question
  66. H22A Recall?
  67. more questions....
  68. VTi-R 4WS playing up
  69. h22+f22 tranny with turbo
  70. dc sport exhaust
  71. What to do for tuning and a head gasket?
  72. where to go
  73. belt screeching
  74. Euro R swap and need driverside mount?
  75. Spiratic tachometer, car sputters in 1st, 2nd, 3rd gear... died also at a stop light.
  76. 4th gen painted tail lights
  77. cam identification help
  78. ABS light
  79. h22a2 pistons
  80. will a 94h22a1 tranny work in a 97 obd2 prelude
  81. bolt thread specs/sizes
  82. what injectors should i run in my h22 NA build motor
  83. sticky seat belt
  84. quiet exhaust systems, or mufflers. yes i searched.
  85. *pic request* FUSE BOX DIAGRAM for 94 SI Lude
  86. Help with base map Hondata H22A JDM engine
  87. H22Z
  88. Need help figuring out weird noise from the engine bay
  89. tail light dash light emergency!
  90. Air filter
  91. xenon lights
  92. just bought an 89' Si 4WS for $250
  93. Honda Alarm System
  94. Where can I buy an exhaust flange?
  95. transmission flush
  96. tranny fluid
  97. JDM Type S Manifold will work on H22A? And what does it give such as Power/tourqe?
  98. Idle ??
  99. Megan Racing Rear Strut/Rear Tie Bar
  100. anybody want to post some pics of an aftermarket shift knob w/ stock boot?
  101. Injector questions
  102. Legend Calipers...
  103. My messed up shifting? Tanny? or Cables?
  104. RPM Surge Problem (maybe TPS?)
  105. obx tie bar
  106. Cross Floor Bar
  107. Euro R Intake Manifold & Flywheel..
  108. Problems with 5th gen
  109. f22a1 auto to h22a1 manual Swap can it be done PLEASE HELP
  110. h22 with type s pistons n camshafts
  111. Whine after new Honda belts,tensioner,adjuster fitted to H22A?
  112. 5th gen Suspension Setup
  113. backwards shifting, please help
  114. 5th gen axel back
  115. WTF is that badass sound?
  116. Oil leak above cat??
  117. AEM V2 Intake 4th Gen Question/Pictures?
  118. exhaust
  119. turbo kit?
  120. quick question: feul rail compatibility
  121. free free free to any local from long beach or any one willing to pick it up
  122. dash lighting problem
  123. TEIN SS is it worth
  124. intake install...
  125. Pic request: Silver preludes
  126. Prelude Hood Damper / Bonnet Strut (searched)
  127. H22a1 block in my car?
  128. Windshield Wiper Torque Specs
  129. anyone have pics of a primered prelude?
  130. motor removal
  131. clutch/transmission
  132. Honda techs, get in here. IACV help!!!
  133. valve cover torque specs
  134. Wheel Stud Replacement: 92-96 Prelude
  135. quick muffler questions
  136. rear motor mount bracket question
  137. temperature gauge rad cap
  138. H22 Head on H23 Block?
  139. helping a friend, need some ideas
  140. d20 honda prelude 1986 oil problem
  141. crazy irratic idle
  142. oil on spark plug threads?
  143. h&r
  144. Got my JDM fogs. How to install with out.....
  145. Torque specs for a balljoint and swaybar link
  146. Rotor Rust/Paint
  147. do i need a camber kit
  148. replacing driver side axle
  149. passenger doors
  150. will 4th gen rear mount insert from energy fit the 5th gen rear mount?
  151. omni power? teinSS? or Ksport?
  152. Tranny weight
  153. need help
  154. 93 prelude dash speakers
  155. SRS system dash light
  156. Honda 93 brake lights issue
  157. FOR SALE
  158. yo i think its done- the engine i mean
  159. Prelude value question
  160. just found out today that my engine is blown
  161. 5th gen Camber kit question. (searched)
  162. someone with a 5th gen and a stock cat. need help
  163. turbo kit?
  164. prelude vtec brakes
  165. Prelude Type S cams
  166. stage 3 cams
  167. wheel hop
  168. Energy suspension bushing problem
  169. help chaging cat and sensors!!!!
  170. H22 Build Problem
  171. NEVR-DULL Cotton Wadding Polish gets the haze off/out of your headlights?
  172. suspension
  173. Dyno Video of my H22 EK
  174. Help with which hoses to remove when removing Power Steering.
  175. Spun a Rod Bearing. what are my options?
  176. problem after timing belt
  177. IAB on a p28
  178. Need Help with a clutch
  179. tranny probs
  180. Are there different blocks for H23A1 engine?
  181. On this Rainy Day in Ga
  182. oil feed locations
  183. Some Spring Questions: 92-96 Lude on AGX's
  184. AEM EMS or Hondata
  185. Intercooler fitment
  186. anyone know where i can get aftermarket engine mount for 97 prelude?
  187. Need Motor Mounts
  188. COde 43 How to check if O2 sensor is faulty? Please help!!!!!1
  189. phearable p28 for 5thgen?/
  190. Need help with lowering car
  191. Anyone have pics of 4th gen with quick release
  192. getting my cluster out...HELP!!!
  193. s100 ????
  194. is lightweight crank pulley worthwhile for my H22?
  195. ***** Finally dynoed: 200whp All Motor nonVTEC *****
  196. a/f gauge with wideband sensor?
  197. tried everything !! NEED HELP NO VTEC!!
  198. soon to be 500+whp!
  199. intake problem. help?
  200. swapedge
  201. How low can i drop with 17s
  202. Orange and White from Oxygen Sensor
  203. 5th Gen ECU Wiring Diagram
  204. 97 Type SH Road Racing Performance...
  205. Swapping OBDI H22A into OBD II Prelude '96
  206. Need cables for my H22a Transimisson?
  207. 92 prelude stalls & starts after ten minutes & stalls..
  208. Downpipe Dilemma for h22
  209. Need custom exhaust setup info.. Please take a look.
  210. Autometer Tach Wiring Help Needed! (searched)
  211. Big Brake Kit on 93 non vtec prelude HELP!!!
  212. H23 manuel tensioner whine
  213. how can i flush the water inside the motor..
  214. 4th gen SE spindle nut size?
  215. Where is the EGR located on a JDM H22a engine?
  216. turbo h22 problems
  217. H22 All Motor setup need help, what to use? and some knowledge....
  218. wheel
  219. Missed Sift,Over Reved, Bent valves? Rings? my test results
  220. Bleeding My Clutch?
  221. how to get 500Hp on Prelude
  222. Which infinity speakers for 4th Gen
  223. trouble code p1259
  224. need some turbo help plz
  225. turbo and requirements
  226. quick question!
  227. Please help! Short shifter question
  228. Prelude City Lights...
  229. some stuff from 95 prelude si
  230. ecu problem?
  231. AEM EMS and 4WS??
  232. Rear CHMSL plate? 4th gen people help me...
  233. timing belt
  234. Monitor behind dash glass
  235. how are these compression results?
  236. Question on cranshaft pulley for 96 lude vtec
  237. Foggy headlights need help
  238. nervous about h22 swap HELP!!!
  239. tech head get in here, code 9 with odb1 ecu, odb2 ecu no code
  240. Prelude VTi-R Australia
  241. does anyone have mg racing header and exhaust?
  242. check engine 1,3,9 no vtec help
  243. Sunroof Rattle?
  244. type s cam part number
  245. Removing main seal
  246. EGR Removal???? can it be done and how hard?
  247. Nitrous install question..is it dangerous if
  248. RPM problem
  249. Idle vibration that stops when the heater is turned on
  250. Nullify motor mounts
