PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 [225] 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. wheel sensors
  2. Prelude gear-nob
  3. PLEASE HELP! Need the WIRING diagrams for a VAFCII for a 2000 Prelude (NOT the instructions manual
  4. UNORTHODOX CRANK PULLEY
  5. Jdm h22 vtech swap
  6. h22a1 swap... Could i use wiring harness from a 93 prelude.
  7. need help with fans!!!!
  8. Another lame cel codes Question
  9. Seat Clips Broken
  10. 225K On A 92 H23A1
  11. Weird hesitation
  12. High engine idle on a h22 TURBO
  13. A/C AND OVERHEATING. IS THERE A CONNECTION?
  14. NORCAL (sacramento meet) y is there none!
  15. crank pulley?
  16. need clutch help fast
  17. coolant hoses
  18. 89 prelude won't start, need help!!
  19. Pully Question
  20. Euro R tranny on the H?
  21. 92 prelude Engine Swap?
  22. 4th gen offset question
  23. sway bar endlink quesiton.
  24. Speed shops by Region
  25. big clunking noise
  26. Location of speed sensor on a 91 prelude si??????
  27. oil on spark plug tips and connectors
  28. help with putting on a rear lower tie bar
  29. EXHAUST QUESTION?!!!HELP
  30. VTEC in a 91 Prelude
  31. searched prelude tires for stock rims 4th gen
  32. Vtec after dyno tune
  33. Weird and very bad idle...
  34. Best suspension for a 5th gen
  35. which computer to run?
  36. Getting through the firewall on a 95 prelude.
  37. Missing part, no clue on what it is called.
  38. H23 valve train
  39. Allmotor H22 catch cans?
  40. looking for h22 engine seats.. and a few other things
  41. Such thing as a (stock) V6 Prelude?
  42. OBD2 to OBD1: What is needed besides harness and ECU?
  43. Oaks Racing's 11.44 Prelude video
  44. lost keys (2001)
  45. Gauge cluster question
  46. H22A1 SMSP header dyno...
  47. i dont know if i should turbo or supercharge
  48. Tach wont go past 3000 rpm?
  49. flex pipe
  50. what to put in holes, that screws used to be in....
  51. Question: Just redid Brakes... Is it Suppose to be smoking???
  52. h23 cams
  53. what do h22 swap people do with there h23 after the swap?
  54. IAC TPS and other various things. help me!!
  55. i got new toys.
  56. speedometer only works in reverse....
  57. Rear main seal & Pilot bearing??
  58. prelude door panels.....is there a manual conversion....
  59. custom intake designs, for absolute most power possible.
  60. tachometer help
  61. 95 Prelude Headlights
  62. REALLY NEED HELP!!! A/C PROBLEM
  63. usdm ecu vs jdm ecu on jdm h22
  64. $2000 what to do
  65. Why did you choose the lude
  66. H22 HEAD GASKETS
  67. s2k exhaust on 5th gen lude???
  68. need help car will not start
  69. HELP I NEED HELP!!!!!
  70. Front Lip Install
  71. JDM H22 sensor question
  72. DOES ANYONE HAVE A RAZO RA57 SHIFT KNOB?
  73. Buying a prelude need HELP!
  74. quick question i have pics please answer asap
  75. I NEED A RADIATOR!
  76. alternator going?
  77. License Plate Holes...
  78. LUDE RIDING LOW
  79. rebushing the h22 rods to accept type s pistons
  80. car overheating help
  81. Brighter speedo/tach gauges....searched......
  82. Please help... blinking s3 light?
  83. Tire Question #2,032,011.. 215/50/16 on stock wheels?
  84. sluggish in the low rpms
  85. port and polish a head, about how much does that run for
  86. Question and Opion about Suspension
  87. Question and opion about stage 2 cams
  88. Help on removing the side mirrors
  89. cams w/turbo h23???
  90. LOTS of PICS H22a DYI ITBs
  91. what's the operating temperature supposed to be?
  92. Ignition switch???
  93. please help quick, or god will kill kittens. (CAMBER KIT QUESTION)
  94. h23 brake caliper question??
  95. 89 prelude si
  96. h23 bottom end gasket set??
  97. Prelude Links?
  98. h23 Radiator
  99. H22a4 fuel pressure at idle
  100. Is it worth upgrading to AEM V2 intake?
  101. Looking For Advise On Tranny Noise Of H22 With LSD.
  102. performance specs for 2litre and 2.3 litre manual 4th gens?
  103. I need a favor: I need to trade manual timing belt tensioners
  104. Stock H22A4 Duration
  105. Locked keys in '92 prelude. Can anyone help?
  106. Who has made 210+ WHP with OEM H pistons? Post your set ups here...
  107. Gasket kits differ?
  108. broken screw on block
  109. The little things
  110. ECU question
  111. Lightweight Battery
  112. Looking for a good/best suspension setup
  113. difference in valve adjustment specs between H23 and H22
  114. Wheel Fitment
  115. +20HP SPEEDCHIP HONDA PRELUDE 92 & UP (ebay item) ??
  116. Rear Lower Tie Bar
  117. JDM H22A into 2000 Honda Prelude
  118. Gauge Cluster
  119. Best turbo setup for stock internals h22a4?
  120. Headlights clear?
  121. Okay, everyone asks about the skunk2 intake mani, How about the Endyn?
  122. Car wont start H22a
  123. skunk 2 intake manifold
  124. failed emissions need help
  125. Recommendations for a shop to do maintenance in NY/LI
  126. why r dc headers so bad for a 5th gen prelude?
  127. Are my seats Recaros?
  128. clutch problem...
  129. Big B's stamped on the deck
  130. valves adjusted,still ticking and no vtec
  131. OVERHEATING?????
  132. Prelude Intake
  133. Electrical help
  134. my little journey
  135. arizona machine shops...
  136. very poor warm weather performance
  137. H22a oil pan gasket replacement
  138. Fuel Injectors
  139. Accord Type R cams
  140. h22 turbo manifold
  141. H22 in integra. need help
  142. 4th GEN JDM headlight bulbs .......
  143. stage 3 clutch in traffic?
  144. Car won't Start
  145. will i hit high 14's with this setup?
  146. engine swap question?
  147. h22a swap. from a place online. want help!!!!1
  148. what is a recommended fuel pressure for type s cams?
  149. SRS light!!
  150. Prelude 4th Gen Exhaust
  151. need a good tuner / builder in the CT area
  152. header question
  153. Rear brake upgrade on 4rth gen vtec?
  154. whats it mean???
  155. Turbo or Supercharger For Your Everyday Car????????
  156. Where does this part go?
  157. h23 tach signal
  158. Clutch Alignment Tool
  159. Hankook H405 and Falken 512 VERSUS Kumho 712
  160. catalytic converter question!!!!
  161. A little OT - Sioux Falls, SD Hydrolock
  162. Qucik Question - Apexi N1
  163. Transmission swap
  164. Question about Fuel injectors and Fuel Rail.
  165. Update on my Engine and Tranny work
  166. H23a1 Turbo?
  167. Si Exhaust questions.
  168. :::ATTENTION::: anyone who has bought anything from Precisionh23a
  169. Jun Cam Specs
  170. JDM P13... worth chipping?
  171. H23 VTEC dyno plot
  172. H23 VTEC Compression (Lets clear up all the mis information)
  173. Is this the quench pad?
  174. Turbo Camshafts
  175. Spark plugs?
  176. Radiator Aftermarket or OEM
  177. Need tips for h22 swap into 94 accord
  178. mustang gt throttle body on h22a, what year works best?
  179. how to REMOVE a 97 Honda Prelude Shift Knob
  180. bonehead move #4080
  181. need help guys!
  182. Fuel Ratio for H22 with cx fuelpump
  183. cam timing
  184. Opions please!!!! 92 prelude or 93 prelude? want to know what be the better year? what engine was be
  185. Bleeding the clutch
  186. Chromemoly rings
  187. Backfiring Problem...Please Help!
  188. Oil burn again
  189. WHATS YOUR HP???? 93 PRELUDE performance part sites??!!!!!!!
  190. Your opinion for my transmission.......
  191. will b&mcommandflo fuel pressure modifier regulator fit on h22a 95 jdm?
  192. Nippondenso Alternator...Generation 2 Prelude
  193. Bad Timing Belt!! Bad, Bad, Bad!!! Stop Moving! Stop it I say!!
  194. Ministock Prelude help
  195. Help please! asap..
  196. unorthodox crank pulley question...
  197. how to remove throttle cable from trottle body?
  198. Convert to leather seats? (5th gen.)
  199. Blower motor replacement
  200. gettin sleeved...
  201. Which is better?
  202. My H23 VTEC Buildup, a Review...
  203. horn fuse poppin
  204. am i already wired up for fog lights ????
  205. h series throttle bodies??
  206. Long term experience with JRSC
  207. header wrap
  208. ATTN: People who have taken out there a/c lines.....gotta question for ya
  209. valve tap (do i need diffrent valve springs and retainers)
  210. Catalytic light and battery light on
  211. BB6 Prelude Sterring Wheel Change
  212. resonable horses
  213. Greddy TT h22 wiring code.
  214. More type s piston questions ( honing, bore, OS )
  215. Are they still selling the SMSP header?
  216. need engine
  217. Zex Kit?
  218. Where to get a swa kit....
  219. cam gears
  220. I NEED HELP
  221. A Note to them moderators
  222. No vin plate WTF
  223. cutting valve cover for cams tuning.....
  224. Wheel Question
  225. piston to wall clearance for oversized type s pistons
  226. just ran my 93 prelude vtec (6.12.04)REDDING,CA
  227. Wiring Gauge Cluster
  228. Fuel question..
  229. HID kit questions
  230. Aem V2 Cold air '98
  231. anyone have any DIY for wiring remote start, alarm.. etc for 92 prelude.
  232. need some help
  233. 5th gen rad into 4th gen
  234. changing shift boot
  235. vtec fading away (getting weaker) help!
  236. Negative Piston to deck
  237. bought a vafc, should i return it and get a flywheel?
  238. Tokico Suspension Kits
  239. is WIDE really better??? 295's on a 5th gen!
  240. Motor Vibrating????
  241. a1 and a4 balance shafts the same?
  242. Piston to deck
  243. Decking the block 0.013"
  244. vtec wont engage help
  245. Another Turbo Prelude is out on the streets
  246. Wheels and slicks (smallest wheel size?)
  247. what size carsound cat?
  248. LOCKED THREADS
  249. Help on 5thgen prelude engine work
  250. best shift
