View Full Version : Honda Prelude
- A/C went out? Need help
- h22a swap...no cel!
- What kind of rims do you have?
- f22b1 swap, obd2 to obd1
- SH Front Lower Ball joints, are they both the same on each side?
- How do i get my lights to look like this!!!!
- H23A BlueTop Dizzy swap help
- Bad Luck with 99SH
- 1994 Prelude Si motor issues questions
- PLEASE HELP!!!!
- Need to install a coolant temperature gauge
- Type s cam ?
- I have a fully built H22A but I just have 2 things left to get cams an cam gears
- what i did for my vtec wires and external coil does it look i'll right?
- diy 94 si courtesy lights :) mayb this will help
- Safc-II
- Help...1998 Prelude not starting and no CEL present
- Prelude sounds like valves are hitting and car is bogging
- Help on Turbo Size
- Correct Tranny Info....PLEASE
- H23a blue top obd2 dizzy to obd1
- pillar pod
- clutch slave cylinder issue, help!
- Worn rocker arm PICS. Advise needed!
- help need info
- 1986 Prelude
- crank pully bolt will not come out.
- 92-96 prelude LCA's
- 93 lude. hellpp A/C expansion valve
- radiator install
- 91 honda prelude si pulley system
- balancer shaft elimination kit
- 1999 HONDA PRELUDE FOR SALE!!
- Buzzing or Humming noise...
- 97 Prelude
- H22 Crank in F23 Block
- I lost my crank pulley bolt!! what bolt ot get now??
- having problems with obd2 to obd1 distributor wiring code
- new guy, but not a noob
- G22 Build
- 96 h22a obd2 with 95 obd1 swap
- 92 Si Speedo help PLEASE
- Porsche calipers on prelude
- Air cond.
- h22A4 obd2 to obd1 conversion
- piston,piston ring, rod bearing replacement
- H23A1 compression test
- what is required to do a tranny swap
- What cars are similar in looks to a Honda Prelude?
- recommendations for JDM H22A swap
- Rediculous Over heating Problem!!!!
- Need help getting engine installed in norther NJ
- Help with H22A part number
- This badge too curved for BB6 rear windscreen?
- electrical problem? please help
- shifter cables
- car dies at idle but runs right.
- Steering wheel swap
- Is triptronic prelude worth for a project?
- how much can I shave off my h23 head??
- 92-96 honda prelude?
- will it work and fit
- Rear end clunk/pop
- A/C idle issue this is different then just idle issue.
- Tuning a Prelude SH!!!
- 97-01 Shift linkage interchange
- clutch line kit
- looking for your opinions, how would you boost my car and with what?
- Need help with sub-gauge cluster...
- advice on engine paint
- HIN Boston 2010!!
- JDM H22A with bent connecting rod.. what else could be wrong
- Overheating Problem. please help
- dizzy placed in 180 out..
- Prelude keeps turning off
- need info H23A1!!!!!!
- need some info
- 5th Gen OBD1 Swap Help!
- jdm h22 swap issues help!
- Possible idle problem.
- H22 questions
- neuspeed strut tower bar
- H22 Timing belt tensioner question
- Rocker Arm Asy
- fuel pump question
- swapped jdm h22 into 93 si
- F20b timing belt?
- bad Cat & misfire-which comes first
- 91 honda prelude 2.0 si
- 4th Gen Prelude At N.E.D. (And tire pressures)
- H22a4 issues please help
- water leaking when starting heater/AC in passanger side
- Alternator change?
- knock sensor compatibility
- A/C servicing question?
- h22a1 swap to jdm h22a
- stupid spark plug question
- HOW-TO .. turbo Intercooler & IC piping installation that clear fog lights .. 4th gen
- K series into a BB6?
- My 1995 Prelude Was Stolen This morning help bay area
- help
- Idle problem - When is the EGR supposed to be open?
- catalytic converter-OEM or aftermarket
- In car vid, and pics of my prelude race car.
- H22 timing belt walking off??
- H22 starts but dies shortly after..
- JDM BB6 headlights?
- 88 Prelude Clutch Problems
- Biggest tire size for prelude 97
- new owner of a 99 sh (with a blown motor)
- Auto to Manual Swap
- Are these optional rims?
- help! f22b cylinder head on h23a!!
- H22 Auto Tensioner Question.
- advice on changing auto to manual
- 93 Prelude
- 91 lude spring options
- 97 Lude in limp mode. any suggestions?
- 17x9 rims on a 92 prelude
- super bog!!!
- o2 sensor question for cel 43
- High Temp reading-Changed thermo and sensor-no help
- Transmission!!!
- i searched first...prelude in super street
- WIll lowering springs from a Acura Vigor work on a 2001 Prelude?
- comp. ratio's....
- Is my Walbro 255 dying?
- max cam size in a h22 ?????
- I need some info on my JDM h22
- Knock Sensor issue! Jdmh22a->usdmh22a4swap
- 93 check engine light.
- Milled head, how do you set the tdc?
- JDM H22A EGR, Cleaning???
- Time budget Prelude build?
- Anyone Know how to change inner tierod?
- 1992-1995 prelude to a 1997-2000?
- Radio, Clock, Interior Light stopped working
- Type R Recaros on 4th Gen.
- usdm to jdm climate control
- Just purchased a 92 prelude
- OEM muffler
- Cam gear tuning? what would b a good base tune maby 2 or 3 degree for this sick setup
- leaks when clutch is bled
- Converting automatic tensioner to manual
- how can i tell which honda this header is for?
- High speed shimmy boggled!
- Venom Performance Control Mo, buy or not?
- 4th gen supercharger?
- H22A4 Compression Test
- Distributor Troubles..
- Stubborn Axles!!!!
- Black Housing Headlight's, anyone tried them?
- Wicked Tuning !!!!!!!!!!!!!!!!
- need help with tranny problem.
- Can you adjust the headlight on 4th gen?
- What could this sound be
- anyone know what the thread pitch is for temp sender?
- h22a4 tdc and timing question
- 1989 Prelude SI flasher relay location
- My Sh suspension
- 97 Prelude smoking
- Coolant system question.
- NEED HELP! DANGEROUS AND SERIOUS AND IDK HOW TO FIX!
- H22A: How do I tell what year?
- innovative alternator relocator help
- 90' S 2.0 Rattling under hood at 2k RPM
- 90' S 2.0 Engine overheat/Cooling fan problems
- h cams bisimoto
- ATTS questions
- shift linkage problem?
- h22a4 question, timing
- h23a1+h22vtec head
- 95 prelude, specific wiring
- 99 base. Front wheel bearings?
- bent valves
- which wheels for my 98 lude? DC2 or EP3 CTR wheels?
- prelude head swap
- odometer reset
- Timing belt question?
- JDM P13 ECU Code 36 delete?
- b16 ecu on a h22
- 98 sh with H23a vtec now. Ecu?
- H22A PROBLEM
- H22A P13 questions
- H22a OBD1 into OBD2 99 Sh lude
- clutch or Transmission Failure??
- 00 Prelude with H22A swap won't rev past 5000 RPM
- what all can be damaged by using the wrong coil?
- idles low then stalls H22A1
- h22 acting up help
- problems with prelude
- 97 Starter Removal?
- wats better individual throttle body's or upgraded intake manifold w/big thrttle body
- Humming again after bearing replacement...
- help oil leak bad
- h22a (type s/sir)???
- D4 light is blinking, CAR WONT START, 2000 Prelude Auto...Please help
- H22 Torqs
- 84 prelude suspension
- blowing black smoke when i hit v-tech? any thoughts?
- head gasket
- newbie help
- 12:8 compression how much timing do it i need
- Sh final drive and gears in a m2j5 tranny ?
- dc sports 4-2-1 collector mod help
- Next Mod for Turbo Prelude? Intake Manifold?
- Megan Racing Header
- How do I remove the lower balljoint on the steering arm
- still wont start, just cranks, no cel
- Any feedback on the "engine restore" from the autoparts stores
- 92 Prelude Restoration - progress todate
- Expert Opinion Needed
- ok, still wont start, replaced a bunch of stuff
- Extended ball joints ?
- simple ecu question
- 15x8 0 off-set fit a 4th gen?
- How to cable tie open secondary runners? pic request...H22
- car wont go any lower?
- ebrake?
- F22b dohc swap complete! More problems now...
- Simple MAIN RELAY question for a 4th Gen Prelude
- My timing belt doesn't look so hot...
- Tail lights short to power?
- how hot do the main relays get? my zip ties wont melt will they?
- Looking to buy a 4th gen
- type sh swap to base.
- prelude sunroof switch rewire to cl switch
- 96 lude UCA
- What CEL code is this?
- ECU Chip Question.
- Trouble programming keyless entry for bb6
- B23A1??? Need info.
- H22 build
- block internals help
- H22a Swap "ecu help"
- p13 4ws
- Anyone have used 97-01Prelude SH Lowering springs for sale
- headlight problem!! please take a look.
- 92 prelude S
- RPM and heat dependent screeching noise
- H22A swap questions!!
- JDM Gauge Cluster.
- H23A1 safe mode?
- 92 honda prelude
- So I might buy this new Prelude SH
- car is driving weird help please
- ATTS compatiable with OBD I
- New Tranny
