View Full Version : Honda Prelude
- when i step on the gas in gear its like im in neutral, just revs?
- safety on stock engine a turbo kit w/out intercooler
- spoon strut bar don't fit help!
- 3 bar question
- changed radiator..AC went bad
- Would LOVE a VE table for H22A
- power shifting problem...
- Valve lash specs
- body kits for my prelude
- Climate Control
- 92 to 94 interior conversion
- RPM Drops at 5200
- Lights problem=teh sad
- Is there any easy way to loosen the timing belt w/o taking it all apart?
- im looking for a balance shaft eliminator kit
- eat ecu problem
- Cylinderhead Question
- help new master slave no pressure
- installing water injection, H22 JRSC
- prelude weird idle...
- wiring diagram
- Rear Window Seal Question
- Eibach Sportline or H&R Race with koni yellows TOO LOW??
- 1983 engine problem
- weapon R header??
- those with AEM pullies and multiple power amps, I need advice
- Need some trouble shooting tips for problems.
- EG H22 - wont start need help
- What ECU's work for '00 SH Lude?
- Does anyone have an h22 head
- intake manifold: searched
- wheres the Intake Control Solonoid Valve?
- EL Gauges installed. Problem with turn signal indicators... *searched*
- 97 Prelude Idleing Too Low???
- between 7-8 grand to spend? what should i get?
- help with radiator hose
- Clickity Click
- idle adjusting HELP
- condensed prelude how to's/troubleshooting
- J.D Power reliability, help please!
- Anyone got a place for an oil pressure gauge?
- Odd 4th gen intercooler question...
- Lean Racing shifter installed......review and install with pics
- is it worth it? Help me..
- type-s pistons
- Reserve gas light???
- Monthly "hold" charge *need ya'lls opinion*
- Removing H22A4
- got tranny repairs done, Reverse still weird
- CEL #12 and #23 .. help clear them ..
- Peakboost h22...anyone have one?...need some info
- High rpm's...whats wrong?
- Black smoke, help
- NPM- is coming up soon.
- broke a wire under the hood
- a roof skin...
- side maker help
- Tire size for my prelude
- fourth gen preludes: what year models?
- can someone run a vin # check for me
- Cam Gears
- Supercharged h22? anyone got any pics?
- Wiring map need a lil help
- code P0740...need help please
- My lude lags in the begining of gear.....
- T-belt question hanging off alil bit
- where do you launch with your 92-96 honda prelude SI?
- Did 5spd swap, now slow leak in clutch lines...
- inexpensive ways to speed up a carburated 82 prelude
- 94 prelude vtec axle
- surging at idle
- whats this part number
- Taking my car to Gainsville International Raceway
- shocks and spring 92 to 96 fit to prelude 97 ???
- 4 wheel steering
- Antenna + Clutch questions
- What other prelude sites do you go to?
- ECU code 41- primary oxygen snensor heater
- new transmission???
- misshifted...
- H22 compression test
- Whats This???
- my lude wants to die
- Toyota Tranny in Prelude
- using msd blaster coil without msd box, makes any different?
- Broken wheel studs!!!!!
- Camshaft installation problem
- Slave cyclinder replacing need diagram ASAP PLZ
- 3rd Gear Vibration
- Tranny woes
- need help with budget Header decision
- H22A Head Gasket size
- S2000 swap
- JDM engine...
- Where can I find a ECU?
- Integra Type R Seats in Prelude 98?
- Type S cams vs. Euro R cams. any difference?
- DC sports Headers
- dash colour conversion
- Need to re-tune after DC Collector Mod?
- AC problems - and it is getting hot outside -- possibly a relay?
- Update on the Prelude-powered mid-engine Mini
- H22 Clutch Install
- intake gasket, Sealant??
- clutch pedal all the way to the floor??
- H22A5 compression ratio
- Assistance needed in accord type r front lip install...
- does 98+ lude suspensoin fit any other car?
- Broken Timing belt .............possible damage? What a fucking day
- Exedy OEM replacement on eBay
- First Gear Engaugement Issue..
- old lude A motor B20 swap need info
- Im gonna miss all the luders!
- crap guys, i dont even know what header i want now...
- Help: Buying a WW RS full kit
- 92-96 mugen bumper
- stereo and fan not turning on every time engine is started
- where can I find a H22a spec sheet?
- VAFCII
- Front cross member spacer increase
- first few swap questions
- upper control arm camber kits...
- Does anyone have a prelude which doesn't burn oil???
- help! ceiling liner rattles
- Snapped timing belt 1991 2.0 Si Prelude
- Necessity of AC Fan
- DTR header for H22 anyone?
- Cam Specs // Factory // Type-S // Skunk2
- Need torque specs for h23 head bolts
- Clutch sounds like crickets
- suspension makin weird noise?
- RMF H22 header (fits 5th gen prelude chassis with no mod's or removal of the crossmember)
- need info on the studs that go through the valve cover
- S-AFC II knock settings
- ATF Amount?
- difference between the camshafts
- Reverse lights stay on even if I'm not in reverse
- Clock acting up, other electrical gremlins
- 01 h22a4 oil pans
- normal idle?
- Blown head gasket in a 90 Prelude...
- Possible Head Gasket Problem?
- How to Tell (PICS)???
- Goin to the smog ref soon, any last minute tips? (00 H22A4 in 97 Acura CL)
- Temp goes up when car isnt moving
- what powers the oil pump in a h22
- Rough Startup
- need picture of starter (in car)
- h22 and h23 oil pickup
- Type S 64mm T/B?
- h22 flywheel help
- h22a tranny
- new a/c compressor
- My Lude is Burnin oil ..... please help
- something with top speed
- good mechanic in socal??....
- HOW TO: Pass OBD2 Inspection with an OBD1 Motor
- Need Some help with performance parts! What to get?
- Which Springs???
- Need help
- Mufflers for boosted ludes?
- Quaife LSD in '01 Prelude - Help from the guys that have one
- o2 sensor location
- Help High Idle Problem
- re-use exhaust manifold gasket
- m2b4 lsd tranny
- Why are there no h23 wire covers??
- Exhaust Setup Questions
- my lude smokes and smells bad when it hits vtec
- Short Throw shifter lever
- cel problem?
- sersors questions
- stock lug nuts + volk TE-37? is this ok?
- New 1995 Lude vtec ....First mods????
- electrical problem, but what is it?
- Dash light brightness Help
- towing a dropped car?
- lots of h22 problems??
- H22 exhaust manifold in a H23 head
- Generaions of Preludes?
- how are the vaccums setup on an h22A
- h22a4 questions
- Question about 5th Gen prelude Valve Cover
- type s cams
- planning to run open header @ the track. does it change a/f ratio?
- 95 JDM fog Light Help!
- Looking to buy a Prelude need some advice!
- accord lip on prelude
- need information how to install a turbo kit
- h22a4
- pic request: CLEAN 4th gen lude.
- New Clutch: downshifted hard, now clutch pedal sinks to floor.. Shuttering probs., etc..
- Engine Trouble
- Hlep: Interior Gauge Light Problem!!
- car wont start?
- Hondata s200 Dyno Results! It's about time!
- NEED TORQUE SPECS FOR CAM HOLD DOWNS H23
- Question on toe alignment!!!
- battery alterantor problem
- Limp Mode?
- Can someone Please host these Turbo prelude vidz?
- Swap Or Not Swap?
- having trouble starting car
- VAFCII Vtec Engagement Problem
- Will attaching an o2 sensor to a test pipe cause a check engine light for obd2 cars?
- Exhaust Speed
- radar detector stealth install
- how many sersors are in the h22a4
- Anyone bought anything from "Deckedlude"?
- Sunroof not opening??????
- After timing belt change, V-tec sound change
- Coilover Install questions
- Vafc II and govorners
- need advice on a couple of CELS thanks
- About to buy another Honda...A Lude this time around.
- CEL code 43 - Fuel system delivery?
- Putting in a mechanical oil pressure gauge
- motor question
- Something wrong with my 5g SS prelude!! PLEASE HELP!
- I have a 91 prelude alb with a b20a1 it has obd 1 ecu connectors !!!!! with a pk3 ecu with led flash
- Someone help me find the radiator Im looking for...
- what engine is this one.
- bumper
- water in transmission?
- Can't shift into second at high RPM's
- where to find cheap transmissions???
- Fuel system upgraded
- Stock 4th gen lude VTEC quarter mile times
- i need help with my h22 swap
- Length difference between 4th and 5th Gen headers??
- question about ob1 usdm h22a4 to jdm h22
- Diagnosing Vacuum Leaks
- reset ecu... deck led messed up now
- JDM h22 arrived - exhaust question
- Need help with Vafc wiring!
- witch air filter recommended
- Help with manual tensioner
- engine swap questions
- JDM fogs worth it?
- No Oil Pressure Please Help
- HELP jdm h22 engine vin starts with a 3??......
- s2000 valve springs in h22
- Energy suspension master bushing set for 5th Gen anyone?
- Installed OBX stage 2 cams.. need help dialing them in
- Need some Lude' advice *searched*
- My prelude on the Dyno
- Bad oil leak??
- Type S strut bar onto 5th Gen Prelude SH
- Turbo on Auto/Tip 5th Gen Prelude
- after tranny repairs is it worth keeping ur car????
