View Full Version : Honda Prelude
- cat question
- JDM Prelude - cold idle and shuddering issue
- JDM H22A Vacuum Question??? Please...
- Exhaust N1 vs. WS (Apexi)
- How the heck do u take out the stock head bolts??
- ANYBODY KNOW THE 0-60 AND 1/4 MILE TIMES FOR THE 1992 PRELUDE S??
- type SH shift linkage
- Where can I buy replacement shock parts for KYB AGX??
- need to find H23 exhuast flange
- Car shaking under acceleration
- AC Blower install on a 4th gen -- pos w/o dropping the whole unit?
- Code 71!!! Cyl misfire!!!!!
- whats the differnece between 4th and 5th gen trannys?
- Manual Swap
- 4 wheel steer and can some1 tell me how to remove the door panel???
- Which Alternator Belt???
- jdm vs usdm
- Flanges
- Odd Issue with Speed. Electrical?
- 95 lude gauge installation
- drag downpipe for H22
- h22 main journal problem
- Types of Rod and Crank bearings
- Cluch system question
- NO VTEC HELP!!!!!!!!!!
- Value On An '89 Prelude Parts Car??
- Common 5th gen problems?
- Strange codes..
- Need Help w/ Plugs/Wires for New Motor...
- boost with hondata on h22
- Help! just had ditributor replaced but car dies?????????
- Coolant pressure
- 3rd gen Vtec 1/4 mile run
- Why oh why does 5th still grind!
- timing belts for Prelude...
- How hard is it to remove a crossmember ??
- Tanabe Racing Medalion
- What I Need for a turbo
- Why is my gas efficiency only at 13 MPG?
- H22 owners, your emails are being received! ST Corsa cam gear run INTEREST ???
- engine mount?
- Best prices on exhaust?
- Need a H23 picture or diagram to find leak.
- Auto to Manual Transmission swap help
- Finally got the motor to the machine shop
- Cold Air VS Short Ram
- Will these wheels fit???
- no atts power loss?
- Help with CD player!
- Transmission vibrates car when shifted into reverse
- getting my valves adjusted, what should be replaced?
- Differences from 5th gen calipers to 4th gen...
- What rear bumper is this?
- A Little Distributor Help, Please: are they really all the same??
- car sounds like an oozy has no power
- f22 vehicle speed sensor on an h22?
- Code 12:EGR help
- h22 arp head studs
- cant get my rear discs off...
- How to tell if Seccondaries are working...
- Idle Surging
- High HC in smog test!!! need help ASAP!
- vafc or hondata?
- can someone help give me the prelude specifications topic that was here awhile ago???
- Head gasket changed - results
- VAFC instead of AEM EMS for JRSC?
- Can someone help me and tell me how to remove the door panel???
- Drag Strip Time
- remove back seat
- IACV valve
- clutch whines? ring Whine noise? What? help!!
- CEL. How can i pull the code
- URGENT HELP!!HOW DO I KNOW MY CAMSHAFT ARE TYPE S??!!
- Sulfur smell - trying to pinpoint the sourse.
- Blaster coil question?
- How much for timing belt replacement?
- Any one know the specs...
- Maxed horsepower for Prelude ?
- MUGEN EXHAUST
- Vacuum pressure seen at throttle body?
- Looking for a 84-87 Prelude
- ecu?
- Code 0715
- Prelude performance
- H22 head on an H23?
- front tire wear inside edge 98 sh vtech
- Prelude O2 Sensors
- Prelude Steering Rack Going On A 95 Acc Ex
- VAFC 2 Initial Setup?
- TEIN SS or Basic Coilovers vs. Eibach 1.25" springs & Tokico Illuminas
- h23 head swap
- Getting closer to finding a true FRM friendly Wiseco
- ST Corsa Cam Gears- locking pin
- Wierd Sound at High RPM's
- Ignitor Problems
- Hybrid Auto/Redstone Motors H23 VTEC Dyno *video*
- What is "liquid gasket"?
- knock sensor and MSD 6 BTM
- apexi world sport 2...
- ? on new turbo car
- Exedy clutch change
- check engine lite
- tranny HELP!!
- nose dive under hard braking
- how do i get this part out....
- n1 exhaust on prelude
- "T" connector on manual power steering rack
- ACT vs. Exedy: Which do you prefer?
- Checking Engine Light?
- were is the water pump on a 4th gen lude??
- vortech question
- d4 light flshes transmission codes
- prelude exhuast upgrade
- what do i do about a map sensor? h22a into 94 accod lx?
- Prelude problem
- Rotor Size
- need some help with brakes
- Official Vtec Wiring Guide
- Help with P13 pinout
- Radiator Fuse keeps blowing..spal fan
- new Rad, now car wont start
- Check Engine Light???
- Sensor question
- Sandwich oil adapter safe?
- h22 or h23
- Does the Spoon drain plugs work for the h22a?
- Getting EGR off!! 98 SH
- Correct PSI
- Stock Ignition limitations on Turbo h23/h22?
- Resetting timing.
- I am looking to buy an H22a or a1 can anybody help me on that....
- Question on Type S Pistons
- oh where art thou vtec???
- Can civic or del sol seats fit in a 4th gen lude. or how bout 5th gen fit the 4th gen.
- slight problem with water pump
- AC wont turn off in 5th Gen
- accord exhaust on prelude?
- 87 prelude?
- knocking.....?
- Tein HA vs. Tein Flex
- just installed drag kit
- 4th gen OEM foglight switch...
- Will 13x8 Bogarts clear 5th gen brakes?
- clutch cut ecu
- coilovers to springs
- power steering instalation
- 5th gen brake fluid is DOT3 right?
- Coolant Leak need help finding.
- **help**crower cam question for people who have them
- Oil Press. Problem
- Looking for stock cam and valve specs for B20A5 (90 Si)
- Is A Bypass Valve Needed For The Winter?
- H22a And L4 Motor
- tuneup problems, help!
- Crower or Skunk2?
- Who makes a good AC Compatible Header?
- racing seats for my 93 Si.....
- Oxygen sensor on 1997 prelude
- pcv valve (searched)
- Installing sending units for aftermarket gauges
- Crower Stage 3's with S-pistons?
- Car Won't Start! WTF? Any suggestions??
- what size belt on my h22a without ac and power stearing
- IAVC on H22A4
- 5th Gen VTEC Question
- Help installing new clutch.
- brake rotors
- 92-96 Prelude Climate Control.. Desirable?
- vacuum pressure. ppl W/ VAFC
- Where can I get some drag slicks?
- **Help me Identify the cams I got**!
- Type S tranny?
- NEW COILOVERS
- Throwing codes?
- auto transmission 2000 honda prelude
- rota slipstreams
- clutch smellin
- where can i buy a new distributor cap for my jdm h22
- Cruise Control Probem
- anyone had this prob.--head unit blowing fuse?!
- Replacing radiator in 92 prelude..?
- VTEC Controller
- Noise from the Rear
- tell me what do you guys think of this 95 prelude.
- topspeed header
- Removing ABS
- KYB AGX
- wierd screeching sound coming from distributor?
- MSD, Magnacor, or NGK which wires are better?
- what damage could have happened?
- VTEC controller
- Wiring to the ECU
- Any daily driven All Motor 4th or 5th Gens running mid to low 13's???
- Does CAI effect gas mileage??
- leaky sunroof
- Accord with H22A swap, Axles binding due to pressure from lowering and clicking?
- Hollowing out clogged cat.......Question
- New head gasket - break in period?
- Parking lights?
- length of 97+ h22 stock header vs 93-96??
- The Official "Why VTEC doesn't Engage" Thread
- differences between the 96 h23 block and 95 h23 block
- pinging/tapping sound at high rpm
- jun ecu...
- JDM Shotgun Exhaust...opinions
- what muffler sounds good on a 4th gen prelude?
- looping power steering lines
- auto harness with h22 5spd...need more help
- Hankook tires
- turbo problem
- Running Lean?
- Clutch Freeplay
- Bulbs
- 97-01 Prelude Suspenion Question????
- need help on my 2001 prelude
- 5th Gen Guage Pillar???
- HELLLPPPPPP!!!!!!!!!!!!!!!!!!!!!
- wet or dry?
- Anyone use 87 Octane (Regular) in there 5th Gen Prelude?? Opinion's?
- Rear view mirror
- Prelude VAFC
- ran my lude
- BB6 Spoon Strut Braces
- What tranny is this?
- JDM Cluster
- Quaife LSD?
- F20C crank in h block?...(i searched and didnt find a definate answer)
- HONDA meet?
- Has your car broken down before?
- prelude of ep3??
- Engine Stand, which bolts
- Easiest way to pull h22 5th gen
- Finding a hole
- N/A or Turbo
- Clutch problem- Pedal related I think.
- Question on after cat exhuast?
- Mugen Steering Wheel
- ? on the 255lph walbro fuel pump
- Brakes help!
- Catalytic Converter inlet and outlet size....searched
- valve clearance question for h23
- air fuel gauge
- drop forks...
- How do I check the "check engine" codes on a Prelude SI?
- Vtec not working
- JDM Auto Tranny LSD
- Those of you with the AEM V2.. was it worth it?
- Another problem, hopefully last one...
- Carbon Fiber hood questions....
- Help with an ECU question
