View Full Version : Honda Prelude
- prelude 4 sale or trade
- M2F4 tranny
- HELP !!!!!
- Heater core
- NEED HELP WITH APEXI VAFC NEED STOCK TUNING SETTINGS!!!! 93 JDM H22A
- heater core leak
- F22 and F23 Tranny's
- Air conditioning problem
- 97 prelude auto to 5speed swap?
- Tranny Swap
- Helms manual!!! where do i buy this fricken thing!!
- h22 w/ h23 trans
- Where does this plug go? red-blk, yellow-red, white - located driver's side front
- Quick Question?
- Interchangable exhaust catback?? PLEASE HELP!!!
- Drive plate bolt(s) removal
- Blue box for Full greddy kit?
- swapping usdm h22a1 for jdm h22a, which dizzy do i use?
- h23 head/ f22 block ?
- problem with 97SH help!
- What's Wrong With My Car?
- Heated Seats in a BB6
- how bad will it sound?
- street tires ???
- Bad ECU???
- 380/380 Ground Controls 5th Gen Prelude Just Ordered! Opinions wanted please!
- H22A INTO 92 PRELUDE ?
- 5g SH suspension
- desmond regamaster
- Can my 95 Honda prelude SI engine swap with a 2002 Acura TL engine???
- should i trade my accord for prelude?
- A/C Center Vents Acting Goofy
- A/C
- Removing Alternator Belt
- EL Cluster Digital Odometer Modification
- help with replacing coolant temp sensor (etc)
- H23 timing marks on flywheel
- what exactly is the El-guage?
- Oil Leak - Searched & Already Replaced Oil Coolant / Dizzy O-Rings
- Piston Rings replacement HELP!!!!!! 92lude
- 4-1 header.....
- Having trouble fixing my leaky oil pan!!!!!! Help please!!!!
- Where is the FITV on my 96?
- how to remove a rear bumper
- aftermarket seats
- flywheel question????
- clutch slipped
- factory fit shift knob
- f22b transmission
- question about prelude/accord springs?
- Air Box Removed in a BB4
- 92 prelude havin motor problems!!
- AWD Honda Prelude?
- 5th gen downpipe
- Random tach issues.... plz help -_-
- Need centers for my rims, my got jacked -.-
- axle stage "x" for boost apps? (searched)
- 1986 honda prelude 2.0si vacuum help
- slim fan question
- harmonic balancer
- Camber adjustment Parts?
- ****Plug wires****
- Searched,,, IMMO on a type s obd2 ecu?
- h23a1 to h22
- any p/s pumps crossfit with 93 prelude sr?
- Euro-r swap into 97 type-sh
- Intake sucked up water!!!
- Sales numbers for US Preludes???
- FITV
- OEM rear bumper
- h22 Noob question
- TO ALL 5TH GEN PRELUDE OWNERS
- Sunroof Rusting
- sleeving my block with Dartons
- Honda 97-01 Prelude (SH only) Weapon-R Performance Header
- Why is the piston to deck height different between H22/H23
- G23 Code 17 on deceleration
- Removing studs from transmission case
- Type S cams...worth it?
- smog problems!
- ECL at 3000rpm / 40mph
- Need Help with WWRS side skirts!
- Wierd idle / ac problem... any ideas?
- Prelude on its way :]
- Heater Control Panel: AC Switch
- Engine Swap?
- Free Horse Power Tune Ups
- Steering wheel/SRS
- Frm sleeves
- H series...pilot bearing ?
- auto trans question.
- Cooling problem - how bad is this
- Looking for a H22 Vtec Engine
- Ign Switch went bad
- Tein HA height adjustment
- Please HELP! Motor Mounts 97-01 Prelude SH
- when putting in new pistons..
- Honda Prelude Turbo Questions
- 89 prelude 2.0 si timing belt PLEASE HELP
- is it worth it for straight pipe
- Setting timing on H22A with Advance Timing Light
- boosted..but not boosted....can u drive like this?
- any tried s2000/07civic si exhuast?
- rsx seats (PICS NEEDED)
- KYB GR-2
- Sunroof Swap.... how to do?
- My prelude at Putnam Park
- ebay header opinion
- Turbo parts
- Headers for Low-Mid HP
- How to take off the power steering belt?
- MOD APPROVED: Turbo Prelude for sale - fully built 500+whp ready - Delaware
- help with rear clunk...
- Prelude rim size...
- A.C.T. CLUTCH HELP!!!
- H23axle change and questions..
- PLEASE HELP!!! Idel Bounce
- Oil light blinking
- radiator fan
- SI for sale (jersey area)
- VTEC Problem!?!
- center console
- Spark knock on H22A4
- Whining coming from timing belt compartment
- engine bay hot
- Question about H23
- Replacing Wheel Bearings
- Is this an OEM Exedy replacement clutch kit?
- gotta pull the motor any good write ups?
- Trade your 98+ Prelude for my Streetbike? Deatails within...
- VIN NUMBER
- A question for thoes with aftermarket or non stock intake manifolds
- need help with idle problems
- 3rd gen H22 Video!!!!
- 96' prelude dash
- IAT SENSOR RESISTOR
- Header wrap
- Sway bar tearing out of frame. :(
- 98 prelude supercharging questions
- Calling all h22 guru's
- Vacuum Hose really annoying..
- Prelude Problems...Please READ and Help me out!.....Tranny I think?
- Need your suggestion
- I need h22 build help.
- New Radiator Question
- i need a little help. got any old headgaskets?
- Constant tires rubbing
- Part Numbers
- prelude died need help
- Noob need help!!!
- Timing Belt
- Is my H22 timing belt aligned?
- Manifold question
- Please help!! H22A4 OBDII engine swap to OBDI car
- Headers?
- No power starting up?
- b18a1 HELP
- ludfuse box help! ***pic***
- need help with best clutch
- turbo lude setup
- Power stearing leak please help
- firewall question
- Clutch Fluid Leaks
- tail lights stay on! ahh!!
- clutch slipping?? lsd broke?? need diagnosis help....
- IAB
- ? about coilovers
- 97-01 intercooler piping routing
- couple questions..
- Suspension Upgrades: Requesting Advice
- Phenoilc Intake Manifold Gasket
- Nopi Parts
- wanting to switch to EL gauges
- Brake help.
- h22 sputering,
- suspension problem
- JDM window visors
- Motor swap - DD - searched
- REBUILDING H22
- Legend brake upgrade question
- i know this is crazy but...
- Intriguing ECU Dilemmas, (ponderings) of sorts. Need some intelligent advice. (Searched)
- bore throttle body
- How to change the oil cooler o ring on an H23?
- swapping H22a4 into 92 prelude w/ f22 engine
- What causes a cylinder to lean out???
- skipping and bucking, and now wont start...
- Engine swap questions
- new honda manual transmission fluid?
- Are these any good for lowering my Prelude? (TOKICO Blues)
- help me make a decision. regarding the fate of a 92 lude
- Fog Light Switch
- Any one using OBX LSD on their prelude
- Prelude VTEC brakes interchangable with ITR?
- h22a1 compression test result, is this good?
- Cat bolts rusted on
- H22...cruising speed at 40mph, what gear is everybody on?
- brake light
- question on JDM Forged Piston
- fog light ? I searched
- Rim Consideration for my 5th Gen.
- hondata prelude
- Type SH- Intake Manifold removal
- lookin into gettin a prelude
- Brake Fluid question???
- Help! ASAP!
- El Cluster Conversion Problem
- 4th gen 5 lug conversion w/ Civic SI wheels
- OEM style headlight replacements for 5g!
- Help Fuel lines wrecked!
- Engine Code 21- VTEC Solenoid Problem (Searched)
- would a front strut bar help 5th gen preludes?
- v-tec callipers
- Heat won't turn off!
- gas question
- Accel injector issue????
- how far can i drop with this wheel
- HELP lude keeps overheating, air conditioner doesnt want to work and my abs is always on
- Clutch and flywheel decision. Need inputs.
- h23 build... need a little help
- installing remote battery jumper terminal
- headlight install diagram?
- O2 sensors
- Stripped screw on rotors?
- kamikaze header
- Aftermarket projectors
- Manual Tension Conversion...SEARCHED
- H22A ECU
- swapping H22 into 92 SI 5spd
- h23 timing question
- wiseco pistons and darton sleeves
- i need a link
- Vibrant Streetpower Sound Clip
- 2.25" drop... will it be ok?
- Aem Brake pads?
- ATTS - worth getting fixed?
- Bleeding Sequence
- Noise after Timing Belt / Waterpump Install
- Prelude Transaxle Question
- 99 engine into 97 lude
- stock ecu problem
- prelude turbo exhaust
- Need to confirm how to mark flywheel for ignition timing on H22A
- check engine light at 100kph
- H22 peakboost Manifold for Sale!!!
- acceleration problem?
- Extending e-brake lines for a 92 to 94-96 vtec console
- if i change calipers do i have to take it in to have abs reset?
- What motor mount will work?
- sh motor in a 97 base model??
