View Full Version : Honda Prelude
- How do I check abs codes on a 96 SI
- Prelude engine swap
- Any good camber kits???
- h22 Build Up
- 4th gen vents?
- C&R radiator installed, but no pressure in radiator hose. Any idea?
- turbo'd 3rd gen
- INTAKE MANI question
- is 3'' gonna be too loud
- Hit the dyno at 147.8 with h22 in a 90 accord does that sound right?????
- H22a1
- h22 head
- tune up price?
- Injectors ???
- Installing coilovers
- Electrical Problems!!!
- High Oil Pressure
- How hard is it to install a new clutch?
- mahle gold pistons: frm friendly? new updates?
- Flywheel in Prelude BB3 F20a4 engine
- Can someone tell me what this is on my 96 Prelude S?
- Opinions and Wisdom wanted
- not getting any love anywhere else... help on exhaust breather system vs open??
- stock h22 mani.....throttle body opening bore...
- Can you convert an OBD-II head into an OBD-I?
- oil pump removal on H22A4
- H23 vacuum diagram
- b20a5 throttle body
- What about Megan Racing??
- strut and sway bars
- Radiator trouble
- Anyone ever installed JDM power folding mirrors on your 92-96 Lude?
- N/A question
- Hate to say it but...
- Head swap
- HELP!!!!!!!!
- what degree is it to set the timming for h22?
- Phantom Grip LSD???
- ECU question
- need help quickly...hate it when search is down
- how much oil does a BB4 manual trans take?
- clutch noise!!!!
- need some help with 5th gen
- Check engine light problem
- odd feeling/sound comming from tire
- radiator hose blew....
- Climate control vent switching issues
- Traction bar status for 4th gen???
- h22 with an accord fuel rail would it work fine ??
- 96 prelude si head swap
- 4th gen JDM door/window visors install help...
- Timing - wierd hum
- Jackson Racing supercharger kit
- ABS Sensor
- Limited Slip Diff. interchangeable
- rear upper strut bar any good? someone should do a DIY tutorial on how to make a strut bar
- SeaFoam
- valve spring pressure how much?
- Weird spot for a transmission to leak???
- prelude si 2.2L
- 16 psi?
- When VTEC engages?
- Anyone had A RHD Prelude Stolen In Socal? Check this out....
- Cams: Which would you prefer for N/A setup?
- battery in trunk question
- Anybody hit vtec @ 4700.....w/out vtec controller?
- grr jdm headlights
- .::Oil Weight::.
- Only revs to...
- Quick question...
- pic request: external coil mounted on h22a
- NJ junyard has a ludes...
- Need help in Wisconsin
- oil catch can?
- strut bars... grr
- 4th gen gauge cluster!!!
- Real OR Fake?
- Map Sensor Code
- Side exit Hytech header on eBay
- Rear Speaker Replacement??
- Magnuson-Moss Act ... I'm in canada...
- researched hondata or uberdata or different ecu
- how long before you need to replace fuel injectors?
- Injector resistors
- 5th gen springs on a 4th gen?
- flowmaster 60' series?
- BB6 cuts off when i stop.
- Problem.... with engine
- Too much for a lude?
- 93-95 lude vtec calipers...what else can i use instead
- anyone know if...
- Tranny swap on a 97 prelude vtec
- 5th gen Prelude door question
- cams, compression & headwork
- Changing ATTS unit fluid
- Loud clicking in vtec after valve adjustment
- F1 Racing(Gripforce)Clutch and Flywheel Packages(searched)
- How To: run OEM timing cover w/ aftermarket adjustable cam gears (pics/write-up)
- Problem: H22 345cc injectors won't fire (H23Vtec setup)
- h22 valve springs in a h23 head
- thin head gasket H22A?
- 5th gen intake (passwordJDM) will it fit
- Is it possible to... 5th AT > manual?
- how to wire up fuel gauge?
- California EO numbers
- Tranny grinds after 5krpms, what fluid should I try? H22A
- Gas Milege Gone Up a lot with new Oil
- after how many miles do you do a valve adjustment?
- Massive Oil Consumption
- AEM intake
- Which tranny?
- type S cams
- Blower motor relay location?
- where can i buy a h22a vtec pressure switch?? no vtec pleease help i need vtec
- Whats wrong???
- IAT Sensor location!?!?!?!?
- 235 Tires on a 4th Generation
- JDM fog light switch?
- Fuel Pressure
- painting gauge rings in 5th gen
- Digital AC panel JDM fitment in USDM
- help Crankshaft bolt/pulley
- HEY, I'M NEW...WHATS GOOD?
- jdm 1 piece headlight
- supercharged SH
- h22a ecu
- Whats A Good Clutch to put in my 98 SH??
- any one know were i can find plude video
- finally finished findanza flywheel and xtd clutch install (performance review)
- CAI recommendation for 98 S
- my "D" light is out on the clutster what bulb is it ????
- _Bring her to my mechanic? Good idea or wait?_
- Ideas and opinions
- Cracked Oil Pan
- 5th Gen Prelude Turn off check engine light
- catalyitic converter HELP!
- big brake kits.. whats everyone running
- Suggestions please...
- 4-2-1 or 4-1 race headers
- I need help with my camshaft setup with oversized vavles..
- code 9 CYP (Cylinder Sensor)?????
- how long do your NGK Iridiums 1X lasts?
- Lost Motion Assembly, Rocker Arm or simply "lifter" ?
- Car won't start... CEL doesn' t go ON.
- front grille
- titaniom rods in h22 lude?
- I'm still a little skeptical about my setup...
- Thinking of buying '93 Prelude Si 2.3L
- prelude o2 sensor primary/secondary?
- forged pistons for b21a1?
- Hit a pothole, bent a wheel, steering wheel vibrations, etc
- which atly do i use when doing h22 swap in accord
- Need Help Identifying A Tranny
- Tach Reads Higher Than engine Output
- burning oil?
- Friend crashed his lude. Need suspension help
- Are these rotors any good?
- throttle body questions
- h23 to h22
- exoticspeedinside
- Buying new suspension! But too confused!
- Recommended Parts to replace w/ new Koni Struts?
- replaced clutch and flywheel now car won't start
- a very sad day :(
- custom spark plug covers
- '85, possible float stuck issue
- ecu pinout reading
- electrical/battery/idle questions
- H22 Head Flow
- rod bearings discontinued?? what the @#$%
- h22- vaccum reading?
- Need info on main bearings and rod bearings
- Grinding going into 1st
- Using temporary P14 ecu with H22
- skunk 2 racing lower arm bar
- Prelude surging idle thread, where did it go?
- how hard is it to change a CV joint or axle. And will an H22 CV axle fit on a Prelude?
- 1997 honda prelude idle problem
- new prelude owner
- what to do next
- LifeSpan of turbo'd H23's???
- 5th Gen Prelude For Sale Long Island , NY
- gen4 vtir; question - country of origin???
- SH exhaust
- Smoking My Tail Lights. (I searched)
- Another Stupid suspension question
- i have a h22 build for turbo should i use my h23 or h22 tranny?
- where can I find aftermarket end links for oem sway bar?
- h22 oil pressure
- Wideband O2 sensor for Hondata S300?
- Sterio shuts off at idle but works above 3000 RPMS + more HELP
- CODE 36 and 12 on h22 what is it? HELP!!!
- Need help with IACV and FITV coolant routes.
- HELP: Where can i find lip kits for a 93 prelude
- vtech, feels a little weak
- Need name of hose
- h22 ECU question
- Wanna go with 18's... what size rim/tire and what offset?
- hpoa write-up
- Question about tranny swap...
- Wanted*** AEM Fuel Pressure Regulator Part# 25-303
- Air/Fuel ratio gauge installation
- S-AFC 2 VS V-AFC 2
- ecu Q
- 2.5" or 3" Piping
- AEM Fuel Pressure Regulator Problem
- Engine problem, grinding noise.
- 10g's+ rev limit h22
- questions about daytime running lights
- Picked up my car Saturday...
- God Help Me!
- Piggy bach ECU's?
- What Turbo should I wear?
- bad news. crashed my lude.
- Motor washdown question
- Common 5th-gen problems?
- Should I buy it? 97 prelude for $3000
- JDM headlights install, NEED HELP !!!
- What do i need to completly upgrade my ignition system.
- check engine light.
- Want a 2nd gen Prelude? Here's one for sale
- F20B head
- 4th Gen Off-Idle Problems
- HELP WITH WINDOW!!!!
- Skank2 Intake Manifold for Boost?
- Apexi Super Grounding System
- ForSale:: 2 1992 Prelude SI and a 2000 Yamaha R6
- 4gen ecu
- h23 oil passages
- 4th gen questions
- h22 Swap Questions
- i have a h22 for my 92 prelude the obd1 the h22 is like 98 i want the car to be obd1
- i want to get a set of cam gears what would you buy?
- Myriad of problem after head install.
- anybody know what's code 22?
- SportShift Redline
- Need good sites with jdm parts
- HID retro fit for 5th gen? *DIY*
- what can i exspect from...
- 97 Prelude and funny noise.
- Cat-backs: Which one?
- Help - head replacement?
- Tein H-techs on 4th gen
- searched...anyone know where main relay is on a 89 (3rd gen) prelude?
- Looking for Stock Muffler in NJ
- Chicagoland Prelude Club (non-tech)
- bleeding clutch - HELP
- headers- which one? (searched)
- Winter Driving
